    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 161.7k Views 79 Watching
    • LOAML Offline
      LOAM
      @dave r said:
      @oxer said:
      The plugin does not work on SU 2017, try with SU 2016 or 2015.
      If it doesn't work in SU2017, why did I get trees from it in SU2017?
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p613826
      It worked for Pilou with no problem either. Maybe we're doing it wrong.
      Hi Dave R, can you explain the process of how you are editing already created trees please? This is a plugin that we have paid for and whilst it wasn't expensive we would like to continue to use it in 2017 Pro. As you discovered It makes trees fine, they all generate originally but you can not edit them once created as a large percentage of the sliders are listed as "NaN" and the redraw button does nothing and the ruby console throws an error.
      Works ok though in 2016 pro.
      Would really appreciate a description of how you got it working so we can try the same thing.
      This post describes the issue we are running into;
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p608575
        jdcamc
        The plugin works fine in the Windows version of SketchUp 2017 but it doesn't work for the MAC version of SketchUp 2017. I have both and the drop-down menus in both the trees and grass dialog boxes are empty in the MAC version. I can import a tree that I made with the Windows version into the MAC Version of SketchUp but when I select the tree, then right click to bring up the context menu, the context menu is empty, too. I am, however, able to turn on and off the proxy of the tree that I've imported into the MAC version of SketchUp.
        • ppoublanP Offline
          ppoublan
          I uploaded in sketchucation plugin store a new version that is working with SU2016 and SU2017.
          • jujuJ Offline
            juju
            Thank you, good sir!
              How did you do it ?
              I can't see an updated version ?
              • OxerO Offline
                Oxer
                The last version 1.10.14 doesn't work on Mac OS X 10.11.6 & SU2017, I can't select the trees in the list, this is empty. See the image.
                EDIT: In SU2016 works fine.
                  garystan
                  Hi everybody :
                                 Too bad there wasn't a version for Sketchup 8.  I would upgrade.....but Sketchup Pro is $700.  Right now, money is tight.
        garystan
                    jdcamc
                    Yep, does't work with Mac OS X 10.12.6 & SU2017 but does work with SU2016.
                      genesissaul
                      thanks
                        CassieFlo
                        I am have the free version of this, I have both 2017/2018 versions of Sketchup for Mac. I can draw trees and change them from proxies to full render just fine, but I can't change the configuration of them. It takes me to the full configure screen but when I press the redraw button it doesn't do anything? Is this a mistake I am making or does it deal with compatibility issues? Any suggestion is appreciated!
                          choppir
                          Thank you, just bought it!
                          Will you send us the plugin? Havent received anything on our email...Still just the free version on my sketchup
                            pexin82
                            I still waiting my 3DTree plugins License information to SketchUp.
                            • jujuJ Offline
                              juju
                              Through which channel did you purchase it?
                                pexin82
                                I buy it from: http://www.3darcstudio.com/downloads-files/24-3d-tree-maker-sketchup-plugin.html
                                Here's Buy Now link (right, down) and i paid it in PayPal.
                                  You should be contacting the people you got it from. It's their responsibility to make sure you get the license.
                                    pexin82
                                    I have contacted several times already. It looks like I do not get my own license and someone taking my money. 😞
                                      pexin82
                                      ...And my payment 10€ is to PASCAL POUBLAN from PayPal. Where he is?
                                      Item number 100.
                                        You purchased it from the author's website. It's going to be the best way to get in touch with him. His last visit to Sketchucation was in August of last year.
                                        Unfortunately there's nothing we can do about getting you the license. It's up to the author to supply it.
                                          pexin82
                                          Thank you! It was very kind to answer my messages. 👍
                                            Good luck getting in touch with Mssr Poublan.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
