    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 259.9k Views 79 Watching
      @oxer said:
      The plugin does not work on SU 2017, try with SU 2016 or 2015.
      If it doesn't work in SU2017, why did I get trees from it in SU2017?
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p613826
      It worked for Pilou with no problem either. Maybe we're doing it wrong.
      • OxerO
        Oxer
        Perhaps because you use Windows, mwm5053 & me work on Mac, the plugin works fine in SU2016 on Mac but in SU2017 it appears the issue that mwm5053 describes.
          mwm5053
          I just removed all website data in Safari and Google Chrome ( some plugins I remembered use web dialogue something or other ) like the Fur plugin that I had problems with on Mac but still no choice for choosing type of tree.
          Edit the Fur plugin does work in SU 2017 and OS X 10.10.5 Yosemite
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • L
            lgrahm
            I guess it's a Mac-related problem. I've tried to install it on both an iMac and a Macbook pro with SU2017 pro.
            Problem 1 is (as other have noted) that the menu is blank - you can't choose any tree type.
            Problem 2 is that the plugin dissapears when you quit and restart SketchUp! Yes, it's not disabled - it's not there!
            • K
              karllarsen
              @dave r said:
              @karllarsen said:
              It sure would be nice to know if this will ever work or its just a lost-cause?
              I don't really have a need for it but I just installed it now because of your post. It seems to work fine for me. It makes trees like it says on the box.
              [attachment=0:2trikxvl]<!-- ia0 -->Screenshot - 2_10_2017 , 6_47_08 PM.png<!-- ia0 -->[/attachment:2trikxvl]
              Great! Now try to EDIT the tree and tell me if you can ADD branches.
              Then, make sure you read the entire description of what is NOT working 😉
              Less is more.
                mwm5053
                Still having the same problem as lgrahm on my Mac with SU 2017 seems to work fine in SU 2015 however.
                2011 iMac
                V2 Twilight
                • LOAML
                  LOAM
                  Hi Dave R, can you explain the process of how you are editing already created trees please? This is a plugin that we have paid for and whilst it wasn't expensive we would like to continue to use it in 2017 Pro. As you discovered It makes trees fine, they all generate originally but you can not edit them once created as a large percentage of the sliders are listed as "NaN" and the redraw button does nothing and the ruby console throws an error.
                  Works ok though in 2016 pro.
                  Would really appreciate a description of how you got it working so we can try the same thing.
                  This post describes the issue we are running into;
                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p608575
                    jdcamc
                    The plugin works fine in the Windows version of SketchUp 2017 but it doesn't work for the MAC version of SketchUp 2017. I have both and the drop-down menus in both the trees and grass dialog boxes are empty in the MAC version. I can import a tree that I made with the Windows version into the MAC Version of SketchUp but when I select the tree, then right click to bring up the context menu, the context menu is empty, too. I am, however, able to turn on and off the proxy of the tree that I've imported into the MAC version of SketchUp.
                    • ppoublanP
                      ppoublan
                      I uploaded in sketchucation plugin store a new version that is working with SU2016 and SU2017.
                      • jujuJ
                        juju
                        Thank you, good sir!
                          How did you do it ?
                          I can't see an updated version ?
                          • OxerO
                            Oxer
                            The last version 1.10.14 doesn't work on Mac OS X 10.11.6 & SU2017, I can't select the trees in the list, this is empty. See the image.
                            EDIT: In SU2016 works fine.
                            • G
                              garystan
                              Hi everybody :
                                             Too bad there wasn't a version for Sketchup 8.  I would upgrade.....but Sketchup Pro is $700.  Right now, money is tight.
        garystan
                                jdcamc
                                Yep, does't work with Mac OS X 10.12.6 & SU2017 but does work with SU2016.
                                • G
                                  genesissaul
                                  thanks
                                  • C
                                    CassieFlo
                                    I am have the free version of this, I have both 2017/2018 versions of Sketchup for Mac. I can draw trees and change them from proxies to full render just fine, but I can't change the configuration of them. It takes me to the full configure screen but when I press the redraw button it doesn't do anything? Is this a mistake I am making or does it deal with compatibility issues? Any suggestion is appreciated!
                                    • C
                                      choppir
                                      Thank you, just bought it!
                                      Will you send us the plugin? Havent received anything on our email...Still just the free version on my sketchup
                                      • P
                                        pexin82
                                        I still waiting my 3DTree plugins License information to SketchUp.
                                        • jujuJ
                                          juju
                                          Through which channel did you purchase it?
                                          • P
                                            pexin82
                                            I buy it from: http://www.3darcstudio.com/downloads-files/24-3d-tree-maker-sketchup-plugin.html
                                            Here's Buy Now link (right, down) and i paid it in PayPal.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
