    3D Truss Models
    1.5k Posts 31 Posters 935.6k Views 30 Watching
    • jujuJ Offline
      juju
      Is there some way you can incorporate a method for exporting/importing settings (user defined layers for example) in your various extensions? I'm migrating to a new machine and this seems like a useful feature, even though it may be one that will probably not be used a lot.
      • medeekM Offline
        medeek
        Version 2.1.0 - 11.28.2017
        • Added Northeast hip set trusses.
        • Enabled advanced options for northeast hip sets.
        • Added energy/raised heels for northeast hip set (3 variants: wedge, slider and vertical w/ strut).
        • Added the option for open vs. closed end jacks.
        • Added the option for a drop in purlin frame.
        • Enabled a graphical user interface for Truss Set selection.
        http://design.medeek.com/resources/images/truss_su319_800.jpg
        http://design.medeek.com/resources/images/truss_su320_800.jpg
        I only plan on adding the midwest and california variants if requested.
        I don't want to toot my own horn but these truss sets are quite complex, I'm still amazed that I've been able to finally write the code to generate all of this geometry. At first it is a bit overwhelming but when you break it down into its components and slowly grind each one out sooner or later it emerges.
        I still have not added plates to the truss hip sets due to the complexity and the fact that it is low on the priority list for now. Complex roof are currently my biggest hurdle and I am still battling with how to best approach these from a systematic standpoint and then dive into the details once the overall layout is configured.
        Until I have complex roofs figured out the plugin is only about halfway there, but at least I've got my foot in the door and I'm making progress.
        When you consider that you can create one of these hip truss sets literally in seconds with all of the sheathing, cladding, fascia, gutters etc... and it is all geometrically correct, it is pretty cool. Manually it would take me well over an hour to try and generate this level of detail without the plugin, there is something to be said for automation.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          I don't know how to do it on a Mac but if your running Windows you can probably pull the settings directly from the registry and then insert them back in on the new machine.
          I will give this some thought.
          design.medeek.com
          • medeekM Offline
            medeek
            The reason I am taking so long with complex rafter and truss roofs is the possible permutations is making things very challenging.
            For example take the truss roof below:
            http://design.medeek.com/resources/images/truss_su321_800.jpg
            I'm assuming there are no interior bearing walls and we want to clearspan the entire building outline. I can get the basic roof and truss layout by creating to hip truss sets as primitives but that is where it then becomes very interesting.
            As you can see there are two mid-building girder trusses that then catch the mono pitch sub-girders which are each supporting two common trusses. Next to the sub-girders is a small valley set (half valley) that fills in the roof behind the sub-girders.
            The largest span is 36', which is reasonable. This appears to be the simplest way to truss this roof out but is probably not the only solution. A good truss technician could tell me how close I am to the optimal solution.
            Granted the complex rafter roof is not IMHO as hard a problem but it also has similar difficulties and issues.
            View model at this link:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            design.medeek.com
            • medeekM Offline
              medeek
              C'est merveilleux, merci beaucoup.
              design.medeek.com
                I will make corrections on the post above! 😉
                • medeekM Offline
                  medeek
                  French translation of the Roof Truss Menu:
                  http://design.medeek.com/resources/images/truss_su322_800.jpg
                  I will roll a sub revision so everyone can try it out.
                  design.medeek.com
                    It's a beginning! 😄
                    Have you a system of translation ?
                    Or I must edit some files ?
                    • medeekM Offline
                      medeek
                      I am still compiling the list of words and phrases, there are a lot of menus, too many.
                      design.medeek.com
                        That is the problem of very detailed program! 😉
                        Ps I can make an adpatation of this page in French! 😉
                        Only for the fun, (It's my hobby) ☀
                        So that will be a cool training for the future Panel's Truss Translation!
                        Yet made Twillight, Podium, FlexTools, Groboto (collector), ZBrush, SimLab Composer,
                        3DCoat (Manual), PolyBrush, Qubicle2, SUbD, Profil Builder2, Moi3D, GifCam, Monolith (manual), [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]Visualizer[/u:26zyq7ev][/url:26zyq7ev], [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]SolveSpace[/u:26zyq7ev][/url:26zyq7ev] etc...and so many UI, Manuals, curiosities etc...
                        I'm frightened by this list! 💚
                        • medeekM Offline
                          medeek
                          Wow, that is pretty amazing.
                          design.medeek.com
                            Look at your Private messages! 😉
                            • medeekM Offline
                              medeek
                              As the number of advanced options have increased (common trusses) the user input menu has slowly grown in size until it is so large that it often does not fit the screen of many laptops and smaller screens.
                              This problem has been well documented by a number of users for quite some time.
                              This weekend I spent some time putting together a new HTML menu for advanced options for roof trusses:
                              http://design.medeek.com/resources/images/truss_su323_800.jpg
                              I still need to work out the metric version and also all of the language translations but otherwise I think it is almost ready to roll out.
                              As you mouse over each of the options a 320x240 image will display as shown, hopefully clarifying the meaning or usage of each parameter/option.
                              design.medeek.com
                                Help Image is a very very good idea! 👍
                                Very very first draft as you can see the "?" ! 😉
                                Veuillez choisir les options avancées pour les fermes de toiture
                                Roof and Wall Sheathing = RevĂȘtement de Toiture et RevĂȘtement Mural
                                Roof Sheathing = RevĂȘtement de Toiture
                                Roof Sheating Thickness = Épaisseur du RevĂȘtement de Toiture
                                Gable Wall Sheathing = RevĂȘtement Mural du Pignon
                                sub-fascia = Sous-fascia ?
                                sub-fascia type = Type de Sous-fascia ?
                                sub-fascia width = Largeur de Sous-fascia ?
                                sub-fascia depth = Profondeur de Sous-fascia ?
                                rakeboard = ?
                                gable overhang = Porte-Ă -faux du Pignon
                                rake board width = Largeur ?
                                rake board depth = Profondeur ?
                                outloockers = Débords ?
                                outlooker spacing = Espacement du Débord ?
                                outlooker size = Taille du Débord ?
                                structural outlookers = Débord Structurel ?
                                outlooker @ roof peak = Débord @ Pointe de Toit ?
                                heel blocking = Blocage du Talon ?
                                heel block orientation = Orientation du Talon ?
                                cladding = RevĂȘtement
                                roof cladding = RevĂȘtement de Toiture
                                hip and ridge cap = Capuchon de Croupe et de FaĂźtage ?
                                gable wall cladding = RevĂȘtement Mural du Pignon
                                additional options = Options Supplémentaires
                                soffit cut = Coupe de Soffite ?
                                roof returns = Retours de Toit
                                roof battens = Lattes de toit
                                ceiling gypsum = Gypse de Plafond
                                gutters = GouttiĂšres
                                dropped top chord = Panne Supérieure Lancée ?
                                  First glance! 😄 (must be refined)
                                  Veuillez sélectionner l'un des types de fermes suivants:
                                  Commun en W - Tunnel - Mono-Pente - Ciseaux - Empennage - Double-Pente
                                  Corde d'Arc (?) - Arceau de Barrique (?) - Polynésien - Bombé - Cathédrale - Plateau (?)
                                  Simple Ciseau - Simple Cathédrale - Shed - Voûte En Berceau (?) - Tunnel à la Mansart - Caisson
                                  Treillis - Cathédrale Symétrique - Studio en Berceau - Double Inversé - Corde ParallÚle - Charpente
                                  Remarque: Les types de ferme Shed, Arceau de barrique, Studio en Berceau et Double Inversé sont en cours de développement et ne sont pas encore disponibles.
                                  • medeekM Offline
                                    medeek
                                    Version 2.1.1 - 12.04.2017
                                    • Enabled a graphical user interface for advanced options of roof trusses.
                                    design.medeek.com
                                      new refinement! 😄
                                      • Commun ( Classique en w) - Grenier( Habitable) - Mono-Pente - Ciseaux( Entrait RetroussĂ©)- Empennage ( Ă  coyeau) Double-Pente ( AsymĂ©trique)
                                      • Corde d'Arc (Arc) - Arceau de Barrique (Arc triangulĂ©) - PolynĂ©sien ( tropicale)- BombĂ© ( entrait retroussĂ© variante ou Polonceau ) - CathĂ©drale - Plateau(Double ferme articulĂ©e)
                                      • Simple Ciseau - Simple CathĂ©drale - ClergĂ© (Contemporaine ) - VoĂ»te En Berceau (En voute ) - Grenier SurĂ©levĂ© ( Ă  la Mansart)- Caisson ( Ă  entrait dĂ©calĂ©)
                                      • Plat ( poutre treillis )- CathĂ©drale SymĂ©trique ( treillis Ă  deux pentes) - Studio en Berceau ( Ă  entrait dĂ©calĂ©) - Double InversĂ© ( double articulĂ©e) - Corde ParallĂšle - Charpente
                                      https://img15.hostingpics.net/pics/255775ferme03.jpg
                                      https://img15.hostingpics.net/pics/647757ferme02.jpg
                                      https://img15.hostingpics.net/pics/484019ferme04.jpg
                                      https://img15.hostingpics.net/pics/576001ferme01.jpg
                                      • medeekM Offline
                                        medeek
                                        I am trying to understand how the Mac .plist file works. Is it similar to the registry? I have a client that is having some trouble with registering (inputting their serial into the global settings) and having their system save the serial number.
                                        Unfortunately, I don't own a Mac so I am not much help. Does anyone use the plugin on a Mac and have had similar problems with saving the serial number? Where does one go to manually edit the .plist file and enter in the serial number manually.
                                        design.medeek.com
                                          glro
                                          not only that
                                          i had the same questions
                                          so i bought a mac: https://en.wikipedia.org/wiki/Mac_Mini
                                          sheap, you can use windows mouse, keyboard and screen
                                          there are a few things to modify in the ruby code por windows, to make it work on a mac
                                          • medeekM Offline
                                            medeek
                                            I am working on adding the heel blocking since it is an option listed in the advanced options.
                                            http://design.medeek.com/resources/images/truss_su324_800.jpg
                                            So far there has not been much call for this feature but a few people have inquired so I figured we might as well add it in for completeness. The red coloration is for clarity in the image above.
                                            I will probably add the option to allow for venting holes since this is fairly typical in my neck of the woods.
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 4 / 76
