    Sketchup 13 undo bug
    30 Posts 13 Posters 9.6k Views 13 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      The bug should be fixed in version 1.0.1
      http://sketchucation.com/pluginstore?pln=Layers_Panel
      • ToboboT
        Tobobo
        I had the same problem, and found that it was Vray 1.49. but now the undo command undoes two or three steps not just one. so I'm constantly having to repeat things.
        It is very annoying.
        Toby
        Philippians 4:13
        • E
          eddie
          looks like uninstalling the component manager did it for me...so far. Took a while to find though since it was called BGScomposants...
          Thanks for all your help everyone!
          • onzkiO
            onzki
            I just had this problem today.. can't find this "BGScomposants".. where is it located?
            [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
            • onzkiO
              onzki
              After a day of struggle of trying to work precisely knowing there's no undo available πŸ˜„.. I finally found the culprit (in my situation)- It's the luxrender plugin that I installed few days ago.
              IMHO, I think the cause will vary (I use Sketchup 8), so as a tip, I suggest to always log or remember the plugins that you install so it's easier to spot the troublemaker πŸ˜„.
              • L
                ltchest
                Im using version 1.2 & still get the problem where Undo does not work. It just gives you "undo properties" and does nothing.
                Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
                RTX2070 + GTX1080, Driver 472.12
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Are you 100% sure it's caused by Layers Panel?
                  • G
                    Glenn at home
                    I also had this problem as well and did have the Lux plugins installed. I have removed them and I think it has fixed the problem on my end.
                      Jarhead
                      So... none of the suggestions above worked for me, neither having a fresh install of SketchUp 8... So I determined that it must be something in the model itself.
                      A clean new project doesn't have the bug, only some files that I work on from the get go.
                      After cutting and pasting the elements of the file I was having an issue with, into a new SketchUp project, the issue isn't there anymore.
                      I have Layers Panel & Layer Manager, and they don't seem to be the problem (evident by the fact that the issue persisted with a clean SketchUp install
                        Sometimes people create models that have some corrupting issue. Copying the geometry to a new file sometimes helps. On the other hand, if you're still using SketchUp 8, that might be a clue, too.
                        • 2 / 2
