    Sketchup 13 undo bug
    30 Posts 13 Posters 9.5k Views 13 Watching
    • Bob JamesB Offline
      Bob James
      @dtrarch said:
      Hi Y'all
      I think Ive found the dirty devil. πŸ‘Ž πŸ‘Ž
      BG Sketchup Component Manager
      dtr
      I have the problem and do not have BG Sketchup Component Manager installed.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        If it's "Undo Add Layer Observer", it's related to Layers Panel. I fixed it and will soon release an update.
        As for "Undo Properties", it's not Layers Panel. But it's a generic name, it happens when a plugin doesn't give names to its operations.
          Pherim
          @bob james said:
          @dtrarch said:
          Hi Y'all
          dtr
          I have deactivated it and the problem persists... now is is even happening when I have just started Sketchup with an empty file and have not yet done anything. Seems I have to test my plugins one by one to find out which is responsible.
          • Chris FullmerC Offline
            Re-read the post right above yours Pherim. Jiminy suggests it is also possible that it might be his plugin - Layer Panel. Check to see if you have that installed.
              jiminy-billy-bob
              TT also found a bug that produces "Undo properties" in some cases with Layers Panel. I'll publish a fix soon.
                Pherim
                One question, is it enough to disable the plugin in the plugins/extension manager of the Plugin Store? I did this first and it still appeared directly after starting Sketchup, but when I played around a little with various tools it did not seem to happen again. I don't know if it was Component Manager or Layers Panel, still have to test that and see if it really is gone now.
                  jiminy-billy-bob
                  The bug should be fixed in version 1.0.1
                  http://sketchucation.com/pluginstore?pln=Layers_Panel
                  • ToboboT Offline
                    Tobobo
                    I had the same problem, and found that it was Vray 1.49. but now the undo command undoes two or three steps not just one. so I'm constantly having to repeat things.
                    It is very annoying.
                    Toby
                    Philippians 4:13
                    • E Offline
                      eddie
                      looks like uninstalling the component manager did it for me...so far. Took a while to find though since it was called BGScomposants...
                      Thanks for all your help everyone!
                      • onzkiO Offline
                        onzki
                        I just had this problem today.. can't find this "BGScomposants".. where is it located?
                        [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                        • onzkiO Offline
                          onzki
                          After a day of struggle of trying to work precisely knowing there's no undo available πŸ˜„.. I finally found the culprit (in my situation)- It's the luxrender plugin that I installed few days ago.
                          IMHO, I think the cause will vary (I use Sketchup 8), so as a tip, I suggest to always log or remember the plugins that you install so it's easier to spot the troublemaker πŸ˜„.
                            ltchest
                            Im using version 1.2 & still get the problem where Undo does not work. It just gives you "undo properties" and does nothing.
                            Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
                            RTX2070 + GTX1080, Driver 472.12
                              jiminy-billy-bob
                              Are you 100% sure it's caused by Layers Panel?
                                Glenn at home
                                I also had this problem as well and did have the Lux plugins installed. I have removed them and I think it has fixed the problem on my end.
                                  Jarhead
                                  So... none of the suggestions above worked for me, neither having a fresh install of SketchUp 8... So I determined that it must be something in the model itself.
                                  A clean new project doesn't have the bug, only some files that I work on from the get go.
                                  After cutting and pasting the elements of the file I was having an issue with, into a new SketchUp project, the issue isn't there anymore.
                                  I have Layers Panel & Layer Manager, and they don't seem to be the problem (evident by the fact that the issue persisted with a clean SketchUp install
                                    Sometimes people create models that have some corrupting issue. Copying the geometry to a new file sometimes helps. On the other hand, if you're still using SketchUp 8, that might be a clue, too.
                                    • 2 / 2
