    Need help punching pattern into cylindrical object
    45 Posts 6 Posters 30.5k Views 6 Watching
    • JQLJ
      JQL
      I used shape bender using the arc of rhe pie.
      In the end there's cleaning up to do to reach the last step as shape bender wasn't able to compress the bottom center part to an edge.
      www.casca.pt
      Visit us on facebook!
      • boofredlayB
        boofredlay
        πŸ‘ Cheers.
        • ntxdaveN
          ntxdave
          I have used Shape Bender many times but not sure I fully get this part. Fully comprehend doing the curve to obtain the shape of the vessel but do not fully comprehend how to perform the taper.
          Press F1...thank me later
          • macleeM
            maclee
            When I bend my shape many of my petal cutouts get messed up, do you think it could be because I am working in real scale and I should start larger and then shrink it down? Yours stayed so perfect!
            My real scale is bottom c=22cm top c=64cm height 24cm
            Obstacles do not block the path, they are the path.
            • JQLJ
              JQL
              That should be the issue. Try scaling it up by 10 and then 10 again until Shape Bender doesn't cause issues.
              www.casca.pt
              • JQLJ
                JQL
                The trick with shape bender is that the edge that is parallel with the component, must be in the vertical projection of the component's X axis. Then you can control the final result precisely like this (click the gif):
                www.casca.pt
                • macleeM
                  maclee
                  Using a single plugin: shape bender...[/quote]
                  JQL, how did you go from the step on the right to the one on the left?
                  [attachment=1:3hjnzs8x]<!-- ia1 -->Capture.JPG<!-- ia1 -->[/attachment:3hjnzs8x]
                  It looks like perhaps he scaled it to match the size of the triangle?
                  • JQLJ
                    JQL
                    Check the following gif.
                    https://i.imgur.com/RslKrqf.gif
                    www.casca.pt
                    • macleeM
                      maclee
                      I was just struggling with that part. Great how you used the bend tool again to create that triangular shape at the end. Lets see if I can pull it off now... lol
                      • boofredlayB
                        boofredlay
                        This is great JQL however when you have to trim the edges because of the overlap the original pattern is destroyed. I have been struggling with the right angle to make the shape "wedge" to a point so no trimming is necessary.
                        • macleeM
                          maclee
                          What if you trim the shape at the beginning with the original strip. Starting the trim at the same spot the shape starts to bend and then ending it at the width for the bottom circle ratio. It would possibly give a bit more control over the scaling of the pattern but the angle would only work if it was a uniform arc. Is this right?
                          • JQLJ
                            JQL
                            Share your model at the same stage boofredlay, I'm sure there is a solution.
                            www.casca.pt
                            • macleeM
                              maclee
                              Well I am making progress but still issues that seem a bit too complicated for me to figure out. Maybe I need a more simple pattern.
                              Link to file: https://www.dropbox.com/s/zovsd033cyixims/pattern_v4.skp?dl=0
                              • macleeM
                                maclee
                                sorry I deleted this post and updated it below.
                                • boofredlayB
                                  boofredlay
                                  Here you go but as you can see, the edges will never taper properly to a point. The repeating pattern is destroyed each time. I think the method I used originally works much better, slower but more accurate.
                                  Bowl Pattern.skp
                                  • JQLJ
                                    JQL
                                    I'd say you need a simpler section of that pattern. What you could do is probably make a section of half the pattern and then mirror it, create a section component and polar array it with the rotate tool.
                                    www.casca.pt
                                    • JQLJ
                                      JQL
                                      I'm sure you're right, but I'll give it a shot anyway.
                                      www.casca.pt
                                      • macleeM
                                        maclee
                                        Still making progress, I got my geometry all figured out, just need to accept the fact that I have to change the pattern as I go down. Maybe just a few simple leaves going back and forth for design and then of course I have to punch the holes. I am happy I got the pattern even just 2 rows of it at the top. Also hoping that I can round it off after I am done so it doesn't look so jagged.
                                        Thanks again for your help and ideas, they have been very helpful! Still not done but getting there!
                                        • boofredlayB
                                          boofredlay
                                          Have you tried the method I used in the video I posted up. That way allows for you to have your pattern along the taper at the bottom.
                                          • macleeM
                                            maclee
                                            I started it but I couldn't get my pattern to match the top and bottom and have edges connect, I think I need to do the same pattern you did to make that work. I will try it!
