    Need help punching pattern into cylindrical object
    45 Posts 6 Posters 29.7k Views 6 Watching
    • boofredlayB
      boofredlay
      ๐Ÿ‘ Cheers.
      • ntxdaveN
        ntxdave
        @jql said:
        I used shape bender using the arc of rhe pie.
        I have used Shape Bender many times but not sure I fully get this part. Fully comprehend doing the curve to obtain the shape of the vessel but do not fully comprehend how to perform the taper.
        Press F1...thank me later
        • macleeM
          maclee
          In the end there's cleaning up to do to reach the last step as shape bender wasn't able to compress the bottom center part to an edge.
          When I bend my shape many of my petal cutouts get messed up, do you think it could be because I am working in real scale and I should start larger and then shrink it down? Yours stayed so perfect!
          My real scale is bottom c=22cm top c=64cm height 24cm
          Obstacles do not block the path, they are the path.
          • JQLJ
            JQL
            That should be the issue. Try scaling it up by 10 and then 10 again until Shape Bender doesn't cause issues.
            www.casca.pt
            Visit us on facebook!
            • JQLJ
              JQL
              The trick with shape bender is that the edge that is parallel with the component, must be in the vertical projection of the component's X axis. Then you can control the final result precisely like this (click the gif):
              www.casca.pt
              • macleeM
                maclee
                Using a single plugin: shape bender...[/quote]
                JQL, how did you go from the step on the right to the one on the left?
                [attachment=1:3hjnzs8x]<!-- ia1 -->Capture.JPG<!-- ia1 -->[/attachment:3hjnzs8x]
                It looks like perhaps he scaled it to match the size of the triangle?
                • JQLJ
                  JQL
                  Check the following gif.
                  https://i.imgur.com/RslKrqf.gif
                  www.casca.pt
                  • macleeM
                    maclee
                    I was just struggling with that part. Great how you used the bend tool again to create that triangular shape at the end. Lets see if I can pull it off now... lol
                    • boofredlayB
                      boofredlay
                      This is great JQL however when you have to trim the edges because of the overlap the original pattern is destroyed. I have been struggling with the right angle to make the shape "wedge" to a point so no trimming is necessary.
                      • macleeM
                        maclee
                        What if you trim the shape at the beginning with the original strip. Starting the trim at the same spot the shape starts to bend and then ending it at the width for the bottom circle ratio. It would possibly give a bit more control over the scaling of the pattern but the angle would only work if it was a uniform arc. Is this right?
                        • JQLJ
                          JQL
                          Share your model at the same stage boofredlay, I'm sure there is a solution.
                          www.casca.pt
                          • macleeM
                            maclee
                            Well I am making progress but still issues that seem a bit too complicated for me to figure out. Maybe I need a more simple pattern.
                            Link to file: https://www.dropbox.com/s/zovsd033cyixims/pattern_v4.skp?dl=0
                            • macleeM
                              maclee
                              sorry I deleted this post and updated it below.
                              • boofredlayB
                                boofredlay
                                Here you go but as you can see, the edges will never taper properly to a point. The repeating pattern is destroyed each time. I think the method I used originally works much better, slower but more accurate.
                                Bowl Pattern.skp
                                • JQLJ
                                  JQL
                                  I'd say you need a simpler section of that pattern. What you could do is probably make a section of half the pattern and then mirror it, create a section component and polar array it with the rotate tool.
                                  www.casca.pt
                                  • JQLJ
                                    JQL
                                    I'm sure you're right, but I'll give it a shot anyway.
                                    www.casca.pt
                                    • macleeM
                                      maclee
                                      Still making progress, I got my geometry all figured out, just need to accept the fact that I have to change the pattern as I go down. Maybe just a few simple leaves going back and forth for design and then of course I have to punch the holes. I am happy I got the pattern even just 2 rows of it at the top. Also hoping that I can round it off after I am done so it doesn't look so jagged.
                                      Thanks again for your help and ideas, they have been very helpful! Still not done but getting there!
                                      • boofredlayB
                                        boofredlay
                                        Have you tried the method I used in the video I posted up. That way allows for you to have your pattern along the taper at the bottom.
                                        • macleeM
                                          maclee
                                          I started it but I couldn't get my pattern to match the top and bottom and have edges connect, I think I need to do the same pattern you did to make that work. I will try it!
                                          • macleeM
                                            maclee
                                            [quote="boofredlay"]Here is the tutorial on Youtube: https://youtu.be/sQJoDYOCM0M
                                            This is one way to do it. I am sure there are probably others.
                                            Well it took me a while but I think this is the best I can do! I ended up using your method boofredlay, as the other way created a distorted pattern at the bottom which I couldn't fix, although I did find using the curve tool easier to get the shape. In the end I just couldn't fix it.
                                            With your method, I couldn't smooth the edges at the end like you did, it just distorted all the cutouts... any suggestions? The file is 22M yikes! Here is the link if that helps: https://www.dropbox.com/s/u9kzyhuvujywxho/pattern_v11_final.skp?dl=0
                                            A huge thanks to you for your help and sharing ideas! I would never have even gotten this close without it!
                                            Lee
                                            • 2 / 3
