    Need help punching pattern into cylindrical object
    45 Posts 6 Posters 29.2k Views 6 Watching
    • pbacotP Offline
      Nice!
      • boofredlayB Offline
        boofredlay
        Here is the tutorial on Youtube: https://youtu.be/sQJoDYOCM0M
        This is one way to do it. I am sure there are probably others.
        Here are the plugins if you need them.
        Joint Push Pull Interactive:
        https://sketchucation.com/plugin/715-jointpushpull
        Mirror:
        https://sketchucation.com/plugin/762-mirror
        • macleeM Offline
          maclee
          Mirror:
          Wow boofredlay, that is incredible. I will give it a try although I think I have to watch your video a few times! lol Thank you so much for taking the time to do this. I really helped seeing such a Pro tackle this concept that I have been thinking about for ages! Finally being so close is great! Now lets see if I can pull it off... lol
          Thanks again and great work!
          Obstacles do not block the path, they are the path.
            boofredlay
            Happy to help. Good luck.
            • JQLJ Offline
              JQL
              The pattern isn't right but it was a 15 minute doodle.
              Using a single plugin: shape bender. Some kind of steped tutorial inside Skp.
              Shape Bender.skp
              www.casca.pt
              Visit us on facebook!
              • macleeM Offline
                maclee
                [attachment=0:3gpqdurf]<!-- ia0 -->Shape Bender.skp<!-- ia0 -->[/attachment:3gpqdurf]
                [attachment=1:3gpqdurf]<!-- ia1 -->Shape Bender.jpg<!-- ia1 -->[/attachment:3gpqdurf]
                Oh wow JQL another great idea! I tried shape bender originally but was going about it all wrong, I had created a kind of flattened pattern of it and then I tried to roll it up along the edge of the circumference, but that was a disaster as I couldn't get the pattern right. I even tried "unwrapping" the simple model to get the flattened object thinking that I could flatten it, punch the pattern in and then wrap it up again, but I couldn't get that plugin to work, it kept unwinding it for some reason instead of unwrapping it, so I gave up! lol
                This is a very clever way of using the shape bender and then tapering that edge on the bottom, very smart! And very helpful also to share the .skp file. Thanks so much! Great to see the starting point with the tile.
                This forum is GREAT! I was just about ready to give up...
                Lee πŸ˜„
                • JQLJ Offline
                  JQL
                  Lee πŸ˜„
                  Please don't... Stick around until the point you will be able to help others as others helped you.
                  The cycle must not stop πŸ˜„
                  www.casca.pt
                  • macleeM Offline
                    maclee
                    @jql said:
                    Lee πŸ˜„
                    haha, right! I have a feeling I will be posting quite often... Sketchup is such a fun program to learn and even more so when you have people helping you when you get stuck!
                      boofredlay
                      Using a single plugin: shape bender...
                      JQL, how did you go from the step on the right to the one on the left?
                      Also, your final shape has quite a bit of overlap. I assume this is not ideal for a 3d print. Curious.Capture2.JPG
                      • JQLJ Offline
                        JQL
                        I used shape bender using the arc of rhe pie.
                        In the end there's cleaning up to do to reach the last step as shape bender wasn't able to compress the bottom center part to an edge.
                        www.casca.pt
                          boofredlay
                          πŸ‘ Cheers.
                          • ntxdaveN Offline
                            ntxdave
                            I have used Shape Bender many times but not sure I fully get this part. Fully comprehend doing the curve to obtain the shape of the vessel but do not fully comprehend how to perform the taper.
                            Press F1...thank me later
                            • macleeM Offline
                              maclee
                              When I bend my shape many of my petal cutouts get messed up, do you think it could be because I am working in real scale and I should start larger and then shrink it down? Yours stayed so perfect!
                              My real scale is bottom c=22cm top c=64cm height 24cm
                              • JQLJ Offline
                                JQL
                                That should be the issue. Try scaling it up by 10 and then 10 again until Shape Bender doesn't cause issues.
                                www.casca.pt
                                • JQLJ Offline
                                  JQL
                                  The trick with shape bender is that the edge that is parallel with the component, must be in the vertical projection of the component's X axis. Then you can control the final result precisely like this (click the gif):
                                  www.casca.pt
                                  • macleeM Offline
                                    maclee
                                    Using a single plugin: shape bender...[/quote]
                                    [attachment=1:3hjnzs8x]<!-- ia1 -->Capture.JPG<!-- ia1 -->[/attachment:3hjnzs8x]
                                    It looks like perhaps he scaled it to match the size of the triangle?
                                    • JQLJ Offline
                                      JQL
                                      Check the following gif.
                                      https://i.imgur.com/RslKrqf.gif
                                      www.casca.pt
                                      • macleeM Offline
                                        maclee
                                        I was just struggling with that part. Great how you used the bend tool again to create that triangular shape at the end. Lets see if I can pull it off now... lol
                                          boofredlay
                                          This is great JQL however when you have to trim the edges because of the overlap the original pattern is destroyed. I have been struggling with the right angle to make the shape "wedge" to a point so no trimming is necessary.
                                          • macleeM Offline
                                            maclee
                                            What if you trim the shape at the beginning with the original strip. Starting the trim at the same spot the shape starts to bend and then ending it at the width for the bottom circle ratio. It would possibly give a bit more control over the scaling of the pattern but the angle would only work if it was a uniform arc. Is this right?
                                            • 1 / 3
