    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 164.6k Views 46 Watching
      Have you also installed the latest LibFredo ?
      https://sketchucation.com/pluginstore?pln=LibFredo6
      Most of Fredo's tools need the helper files provided by his Lib.
      it is clearly explained in each of his tool's installation and usage instructions.
      Install it and restart SketchUp.
      Any improvement ?
        SK_Man_2020
        Thanks! That fixed it. I figured it was the missing library, but since the link at the head of this page is broken, I didn't know where to find it.
        Much appreciated! 👍
        • fredo6F
          Which link is broken exactly?
            I just fixed it !
            The LibFredo link in post-1 was foobar !!
            • fredo6F
              @tig said:
              I just fixed it !
              TIG,
              Thank you very much.
              I don't know what happened, because this seems to be the case in other main posts where I refer to LibFredo6.
              EDIT: It was the case: for whatever reason, the links to LibFredo6 page were no longer valid. I updated all posts with the correct URL.
                SK_Man_2020
                Thanks everyone. It's working great now, and very useful.
                Just one more question: If I have several projects open at the same time in different instances of SketchUp, each with it's own clock, will that accumulate time correctly in each one, as I switch between projects and work on each one separately? No conflicts?
                • fredo6F
                  It depends if all models belong to the same project or to different projects.
                  If same project, then, in principle the times should accumulate. I am interested to know, by the way.
                    SK_Man_2020
                    Cool! I'll do some tests over the next few days, and let you know.
                    The reason I ask is because I do consulting work (recording studio design), and I often have several projects from different customers all open at the same time, and during the day I spend time on each of them, which I'd obviously like to account for separately. So I'd be billing each customer only for work I did on his project, not for work that I did on someone else's project but that got added to his by mistake.
                    And on the other hand, I sometimes do have two projects for the SAME customer open at once (such as two versions of the same studio design, with different layouts, that he's going to choose from later) and I'd like the work done on both of those to accumulate on one single clock.
                    From what I see in your documentation, I should be able to do this by having a separate suclock file for each customer, and pointing all of the SKP models related to that customer to the clock that has his name on it. That should work in theory, right?
                    Anyway, I'll try it out like that, and like you know what happens.
                    This is a great tool, by the way: Thanks for making it!
                      @tig said:
                      I just fixed it !
                      Looks like our URL fixing last week has f-ed up things again 😳
                      Will look again Monday
                        I think Gábor has now resolved his self-inflicted injury !
                        All should now work everywhere, just as it should...
                        • T
                          thevzitor
                          "And on the other hand, I sometimes do have two projects for the SAME customer open at once (such as two versions of the same studio design, with different layouts, that he's going to choose from later) and I'd like the work done on both of those to accumulate on one single clock"
                          SK man 2020:
                          Yes you can choose to create a different SU clock counter for each project, and even if you have multiple projects windows opened (if you have enough RAM), the clock will adjust to the front window project timer. That's the greatness of this tool (thank you Fredo!) On the other hand if you have two projects for the same client, you can choose to add the timer of your second project to the first one already created. It does appear on the dialog when you create a new clock. You have the choice to create a completely new clock or affect the timer to an existing clock. Usually you have the list of the most recently active clocks/projects and you can choose with one click to add your new timer to an existing one.
                          Hope this is clear enough (?) Cheers
                            jdcamc
                            I'm having trouble getting the clock to work is sketchy 2018 pro. Here's a screenshot of the message I'm getting. I am assuming it's not available for 2018? Thanks! I have the latest version 1.9c.
                            • fredo6F
                              A SUClock project file has extension .suclock, not skp.
                                jdcamc
                                Here's a video of what it is doing. No matter which route I take, I get the same results - that the project file is invalid. I'm not sure what that means or why the sketchup file is considered invalid. I'm wondering if it has something to do with the sketchup file being 2018 version.
                                SUClock.mov
                                • fredo6F
                                  @jdcamc
                                  The SUClock information is saved in files with extension .suclock. This is independent from the Sketchup models, since several models can be attached to a SUClock 'project'.
                                  In your case,
                                  1. To track time for a model, you need to create a SUClock project. So use "Attach to New Project", and give it a unique name (in the video, you select an existing skp file instead). This will create the information file with extension .suclock
                                  2. Once you have a SUClock project, you can attach a model to it by "Attach to an existing project", where you select the .suclock file.
                                  There is a documentation on SUClock where you have the details and explanations on other use cases too.
                                    jdcamc
                                    It is working now. For some reason it would not give me the .suclock extension when I first tried I, just the error message stating the file was invalid. Now it does give me the .suclock extension. Thanks for you help!
                                    • fredo6F
                                      NEW RELEASE: SUClock v2.0a - 31 Oct 18
                                      SUClock 2.0a provides bug fixing.
                                      See plugin page of SUClock for information and download.
                                      See main post of this thread for discussion.
                                        simMonster
                                        Is it possible to modify your code to allow your plugin to determine the time spent on an older sketchup file? I am very anxious to hear from you.
                                        • fredo6F
                                          What do you mean by 'older'?
                                            db11
                                            Hi Fredo —
                                            I'm having a problem with the plugin under SU Pro 2015: It works fine in 2018, but now doesn't work properly in 2015.
                                            Specifically, I can't pull up the configuration window, either from the menu or by clicking the toolbar button.
                                            Everything worked fine in 2015 up until either my installation of 2018, or the last SUClock update (both were around the same time).
                                            Any thoughts on what's going on and how to fix it? Love the plugin and depend on it for my project time-tracking.
                                            Thanks.
                                            • 6 / 7
