[Plugin Library] LibFredo6 - v14.5a - 23 May 24
Almost 300000 downloads... Blockbuster! Is it only last version or cumulative?
Frodo,
I am using sketchup pro 2016, and I dont find extension manager menu in my windows bar. Can you guide me how to get it?
@ajiprihastono said:
Frodo,
Look in Preferences>Extensions for Install Extension. Best to install the Sketchucation Extension Store from Resources at the top of the page and use it to install LibFredo6 and other extensions.
Good day Fredo, I'm VERY new to SketchUp so please bear with me. I have watched the video wrt installing plug-ins/extensions and am happy that I'm doing it correctly. When I start SketchUp I get this error message for both v7.6 and 7.7:
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Main/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:inprocess' C:/Users/Main/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in
module:LibFredo6_Loader'
C:/Users/Main/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
"Aidez moi s'il vous plait"
Kind Regards,
Joe J -
Joe,
Looks like you have a wrong installation.
Could you please show the footprint (i.e. files and folders) in your Sketchup Plugin directories, that is:
C:/Users/Main/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/PluginsThanks
NEW RELEASE: LibFredo6 v7.7c - 16 Aug 17
LibFredo6 7.7c is a minor release dedicated to
- some adjustments for high-resolution and Retina screens and Retina.
- The support of VRay in Animator.
How to uninstall Libfredo6 and round corner? pls...
In the Sketchup PluginDirectory, you should have 2 folders and 2 ruby files; just remove them!
You have two other methods, in case this is just for deactivation:
- In the Sketchup Extension Manager, just uncheck LibFredo6 and RoundCorner
- The Sketchucation Extension Store plugin also allows to disable / enable plugin.
NEW RELEASE: LibFredo6 v7.7d - 13 Sep 17
LibFredo6 7.7d is a maintenance release fixing bugs, in particular one that may affect Animator and some FredoTools plugins (DrawAlong, MoveAlong among others)
NEW RELEASE: LibFredo6 v7.7e - 19 Sep 17
LibFredo6 7.7e is a maintenance release fixing bugs, in particular one that may affect Animator and some FredoTools plugins (DrawAlong, MoveAlong among others). V7.7e also correct a bug that was introduced in v7.7d affecting TopoShaper.
Bonjour,
Quand je fais de tout petits modèle (des composant électroniques), l'outil arrondi me fait des trous aux angles. Par exemple si je dessine une brique de 8 x 14 x 10 mm et que je fais des arrondis de 0,3 mm ça me fait des trous dans tous les coins.
J'ai mis sur le modèle une précision à 4 chiffres après la virgule, et 2 pour les angles et j'ai démarré avec le modèle "Documentation de construction en mm" Sous la dernière version de sketchup make (17.2.2555 64 bit).
Merci
Frank -
@fks4466 said:
Bonjour,
Merci
FrankWith these very small dimensions, Sketchup is not always able to create faces.
So the trick is to scale up the model by a factor like 10, perform the RoundCorner rounding and then scale back down.
NEW RELEASE: LibFredo6 v7.7f - 01 Oct 17
LibFredo6 7.7f is a maintenance release for OSX High Sierra. With previous versions you get dialog boxes popping up at startup time of Sketchup.
Note that you also need to upgrade FredoTools v3.1e; previous versions simply won't load under High Sierra.
just downloaded libfredo6 in sketchup pro 2017, but cannot see any of the icons from the toolbar
LibFredo doesn't have a toolbar so you wouldn't see any icons. LibFredo is a collection of helper files used with a number of Fredo's other extensions.
NEW RELEASE: LibFredo6 v7.8a - 11 Oct 17
LibFredo6 7.8a is a maintenance release for JointPushPull 4.0 evaluation.
thank you fredo you are the best!
I have been trying for 2 weeks, off and on, to down load anything from LibFredo6 into window 2017. I have disabled add blocking and still get nothing. Also FYI Sketchup make 2017 does not have a plugin folder.
I would sure like to try the scale tool and the round corners. Howver I'm not going to continue to attempt the down load with out furter suggestions from you.
Sincerly,
Herman
funk.herman@yahoo.com -
How have you been attempting to get it?
FYI, yes it does have a Plugins folder. It is in a location that is normally hidden but if extensions are installed correctly, there's no need for direct access to it by the user.
Sincerly,
HermanAgain, how are you going about trying to install it?
