    Push Pull Created New Object That Can't Be Intersected
    7 Posts 4 Posters 830 Views 4 Watching
      Trip12091
      Hello All,
      Need a little help here.
      SU 2017
      Build 17.2.2555
      64 Bit
      Win 10
      I used push pull to extend a metal plate. Rather than extending the plate it created a new object which I am unable to join in any capacity to the initial plate. I have tried re-doing the process many times and many different ways... Plate 1 exploded, Plate 1 grouped, Push Pull with new wall, Push Pull with existing wall, post push pull explode, intersect and then regroup, etc.
      Now, what happens is then I try to delete the line that delineates the two objects (which it should be only one object) I, of course, lose the entire face of the plate. Normally I can just fix losing a face my pulling the other side, with a new wall, back to the front again. However, in this case, the other wall is also two objects.
      I've also tried bisecting the line with other line so that I can delete it in portions.
      What's also interesting is that the edges of the plate are a single object (please see image).
      http://bit.ly/2gUNW1C
      I need to make this a single object
      Any direction you may be able to provide would be greatly appreciated.
      Thanks kindly,
      Trip
      Tempermental Plate.skp
      • ecatiE Offline
        ecati
        Do you upload the skp file.
          Trip12091
          Thanks Necati. I just did so.
            Trip12091
            UPDATE #1:
            I've noticed the following...
            While the edge I am pulling is absolutely 100% square and plumb (as confirmed by the protractor), the pulled extension is coming out 0.6% off. It's barely visible until you really zoom-in, but it is there.
            Trip
            UPDATE #2:
            I have now found that if I take the one face of the original plate, copy it, then push-pull it to the proper thickness, and then, after than, push-pull the edge to the proper width, it is working-out fine and I can delete the line.
            I have Nooooo idea why, or what's going on.
            Trip
              Before any operation Scale * 100 or *1000 your object!
              When you explode all
              Keep only bottom perimeter
              Seems your initial surface is not planar!
                Trip12091
                Thanks Pilou!
                So, would this imply that at some point a did a rotation of the object and didn't quite get it to stick to an even multiple of 90 degrees... that I was off by a fraction of a degree?
                  @trip12091 said:
                  UPDATE #1:
                  No. It isn't absolutely 100% square. If you set the precision in angle units higher, the Protractor will show confirm it. You can also check the coordinates using the Text tool.
                  UPDATE #2:
                  Trip[/quote]
                  The reason that works is because Push/Pull is precisely extruding at 90° to the face each time. So by copying the single face and extruding that, you areleaving the problem of your out-of-square edge behind.
