    Delete texture.
    3 Posts 2 Posters 7.0k Views 2 Watching
      Instead of deleting a colour/texture and replacing it with the default, how about replacing it with a selected colour/texture?
        The plugin exists.
        https://sketchucation.com/pluginstore?pln=Global_Material_Change
        You get two lists of materials - select a target material and select a replacement material.
        Everything having the target material then gets the replacement material...
          Thanks TIG, a pity just about everything has to be via a plugin but that's life. I will have to check that plugin.
