    1.5k Posts 471 Posters 3.4m Views 470 Watching
      ScetcheeDave
      you just coined a new phrase πŸ˜‰ Thanks works great.
        ScetcheeDave
        Actually... it worked great but also deleted the sides in the centre piece. I can and have fixed it easy enough but thought I would see if it was caused by something else i can do better.
        http://i.imgur.com/ihtWjT2.jpg
        • BoxB Offline
          You are running into the Tiny Faces issue. SU has problems forming faces when the edges segments get below 1mm. Scale your geometry up to do complex edits, then scale down again.
          Or use the Dave Method of scaling a component instance up to edit then delete the large one and the small one will retain the edits.
          http://i.imgur.com/3wF3ekd.gif
            barakuda
            Originally I wanted to post PM to you but I could not because the PM function is disabled.
            I also waited if author of Selection Manager will reply and repair his stuff to make it working. I needed to save the selection to show you which edges I am planing to work. Without the selection this is useless to write to you. I have no way how to show what I am trying to do exactly. I wanted to use the Round Corners to round corners of the mesh bellow.
            Now I tried to generate edge 1m offet and 1 side then 2 sides. All works fine.
            Now I have added more edges with 3 sides and everything works fine. I obtained information when the offest 1.25 was too much and would create overlaps.
            On the mesh I did succesfully 1st floor/elevation. Then I move up +4m few faces and I try once more to round the edges. Some gaps has been created on the second floor. I add the model.
            During this test I have not found serious problems.
            Previous job what I did was with file which was much more bigger. Same grid 5m spacing 1km x 1km (same texture) worked very slow. The problem was that when I wanted to select the edges manually red arrow suddenly appeared and I clicked it by incident. Because of it I suggest to have possibility - option do turn of some arrows which I do not plan to use. This would be solution for performance problem. With small objects like this there is no serious performance problem so it works nice.
            round corners mesh.skp
              thaiscardoso
              Actually, I installed a last version of libfredo. Ok, anyway. But when try to install RoundCorner v3.2b, the sketchup say to me: "You must install libfredo6 to rum RoundCorner.
              Someone can help me about it? Version Sketchup 2015.
              LibFredo already installed:
              http://i64.tinypic.com/nv85ch.png
              Message error:
              http://i63.tinypic.com/ajscap.png
                babliadrian
                Same error here! :S
                Please help!
                • fredo6F Offline
                  @babliadrian
                  This may be related to special characters in your username.
                  Could you replace the attached file in the Sketchup Plugin Directory, and advise if this solves the problem.
                  Fredo6_RoundCorner.rb
                  Thank you
                    babliadrian
                    The tool is working now! πŸ˜„
                    So, once again...
                    What was the problem? And what have you done?
                    Thank you!
                    • fredo6F Offline
                      So, once again...
                      Thank you!
                      This is related to non-ascii characters in your username under Windows. For whatever reason, even with SU2017, this seems to create some problem when checking folders and files for existence.
                      • fredo6F Offline
                        NEW RELEASE: RoundCorner v3.2c - 12 Aug 17
                        RoundCorner 3.2c is a maintenance release. It fixes a bug when Windows username contains non-ascii characters, which appear in file and directory pathes.
                        Home Page of RoundCorner for information and Download.
                        Main post of this thread.
                        • fredo6F Offline
                          NEW RELEASE: RoundCorner v3.2d - 12 Aug 17
                          RoundCorner 3.2d is a maintenance release. It fixes a bug when Windows username contains non-ascii characters, which appear in file and directory pathes. It also includes adjustments for compatibility with hi-res screen.
                          RoundCorner 3.2d requires LibFredo6 v7.7 or higher.
                            tgaz
                            Hi everyone. I am trying to use the Roundcorner plugin but i am running into some issues. It seams to work ok but the problem is that the selected edges (to be chamfered/filleted etc) are never visible. Am I doing something wrong. Please advise. Thanks in advance.
                            UPDATE: All is fixed with the latest version of LibFredo6. Cheers!
                            • DATAKASHD Offline
                              DATAKASH
                              Please add 2 functions:
                              1. Offset (without rounding)
                              2. Offset with intersection (toggle)
                              These functions are necessary for constructing subdivision topology
                              (I hope you understand my idea, it's hard for me to explain the idea in a foreign language)
                                There are already extensions available that are designed to do what you are asking. How about using them instead of adding complexity to an existing tool. ThomThom's SubD would be a good place to start.
                                • DATAKASHD Offline
                                  DATAKASH
                                  You did not understand me!
                                  I ask that RundΠ‘orner add Offset function [highlight=#ff4040:149q787k](Without rounding!)[/highlight:149q787k]
                                  And the function of intersection of edges, for the construction of stiffeners for modeling under SUBDIVISION (google β€” subdivision topology)
                                    Yes. I did understand you. There are already tools that do subdivision in SketchUp.
                                    • filibisF Offline
                                      filibis
                                      Those features exist in QuadFace Tools and it is advised here to use as well.
                                      Check below gif.
                                      Click to play. (Quadface offset for subdivision)
                                      • DATAKASHD Offline
                                        DATAKASH
                                        Check below gif.
                                        QFT does not make the offset of the desired edge.
                                        • Offset uneven (See the screen)
                                        • What if you do not have a ring? If there is no ring, the offset is not done!
                                          Check below gif
                                        • fredo6F Offline
                                          @DATAKASH
                                          There was another request for that and it makes perfect sense.
                                          This will come in due time, but no promise.
                                          • DATAKASHD Offline
                                            DATAKASH
                                            @fredo6 said:
                                            @DATAKASH
                                            Yes Yes Yes! @cesaro36 @Hieru They say the same thing as I do! RoundCorner would be an ideal tool, having such such functions. At the moment everything has to be done manually, every day 😞
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 73
                                            • 74
                                            • 67 / 74
