    3D Truss Models
    1.5k Posts 31 Posters 869.8k Views 30 Watching
    • facerF Offline
      facer
      MEDEEK PLUGINS - PRICING POLICY ($)
      Posting by Medeek at:
      by medeek » Wed Aug 02, 2017 12:30 am
      https://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63133%26amp;p=623551#p623551
      There seems to be some confusion regarding the licensing for the plugins. Just to be clear when you purchase a license it is permanent, it will work forever. There is no need to renew your license for continuous functionality.
      Sample Model - view on any web device and in VR using iphone with cardboard viewer or headset
      Sketchfab LINK:
      https://sketchfab.com/models/7dd005d09e ... 19b6dc4cfa
      • medeekM Offline
        medeek
        @dpaul said:
        Might it be possible to control the overhang of the roofing layer only so we can add as much
        detailed fascia work as we require (say using PB) to complete the roof details?
        Thanks.
        I have given this some thought previously since I am only really modeling the sub-fascia and not the entire fascia treatment. By the way what does PB stand for?
        Should both the roof cladding and sheathing layer have this ability for an additional overhang or just the rood cladding? I am thinking about adding this setting into the global settings where you set this additional offset for the roofing/sheathing.
        http://design.medeek.com/resources/images/truss_su205_800.jpg
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • jujuJ Offline
          juju
          PB = Profile Builder
          Profile Builder 2 out now, much improved from original Profile Builder.
            dpaul
            I think just the roof cladding. Our trim can go up under the cladding and hide the
            roof sheathing and sub-fascia.
            Thanks.
            • medeekM Offline
              medeek
              The order of operations here is important since it will generally determine how or what overlaps what.
              The order of installation as I see it (correct me if I'm wrong).
              1.) Trusses, rafters
              2.) Sub-Fascia
              3.) Sheathing (OSB, Plywood)
              4.) Fascia/Trim
              5.) Roof Cladding
              I was thinking one could install the Fascia/Trim last but thats assuming the drip edge (flashing) is already installed and if there is any thickness to the fascia/trim this does not seem like a possibility.
              In any case it seems to me that one would want to probably cover up the edge of the sheathing if there is no drip edge.
              design.medeek.com
                dpaul
                You are right, or course, about the order of installation on a site (and in how you are organizing the plugin).
                However, in terms of my modelling and rendering, I will not necessarily be showing any drip cap on the gables themselves, just the top portion of the trim assembly (fascia plus bed moulding ,etc.) right under the roof membrane---or shingles.
                This trim assembly will cover the thickness of the roof sheathing. (1/2" ply, say?)
                If you can give us the option in the global settings to extend the roofing itself, can you also give us an option for the gable drip cap as well? Certainly on any hip we will put in a drip cap to take the water over into the gutter.
                Thanks.
                • medeekM Offline
                  medeek
                  Talking with some other users about the timber truss module I think it may be useful if the module could generate a separate detail with dimensions etc... for each plate.
                  I don't know how to do this in layout so I will probably use SVG and html.
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    That is quite a niche use, probably a "pro version" or "engineering version" item?
                    • medeekM Offline
                      medeek
                      Progress is slow but steady:
                      http://design.medeek.com/resources/images/truss_su260_800.jpg
                      Now I just need to add the bolts to the peak and heal plates...
                      Full on calcs would be nice too, but I'm just getting ambitious again.
                      design.medeek.com
                        glro
                        what is the niche use?
                        is it the engineering version?
                        or is it the hobby version?
                        hobbyist don't make money with sketchup
                        so hobbyist won't pay for the extension
                        maybe the engineering version is the one that could bring to the developper the resources needed to developp the extension
                        possible to create a scene for each plate and add dimensions directly in sketchup
                        just ideas ...
                        • facerF Offline
                          facer
                          Medeek Const Library - Kickstarter Status at: 5 Aug
                          https://www.kickstarter.com/projects/128644708/medeek-construction-plugin-library
                          All or nothing. This project will only be funded if it reaches its goal by Tue, August 29 2017
                          • jujuJ Offline
                            juju
                            At glro: you're new to the extension, else you would know that there is no free version, except maybe the trial, so the developer would already be earning revenue. What I understand he wants to do is develop a module whereby a cut list and punch list is generated, which means the engineering end has to be up to scratch, which I don't doubt Nathan can do, but the building codes may differ (liability problems), and most user won't need to generate cut lists or punch lists, thus niche use.
                            • facerF Offline
                              facer
                              8 Aug Update
                              • facerF Offline
                                facer
                                Medeek,
                                Please check your private messages, you have yet to respond to a PM proposal I posted.
                                Regards,
                                Ray
                                • facerF Offline
                                  facer
                                  Medeek Const Library - Kickstarter Status at: 14 Aug
                                  • medeekM Offline
                                    medeek
                                    Back from my trip to Utah. I had to take a day yesterday just to recuperate from my vacation, 5 kids can wear anyone out.
                                    Facer will be implementing a new program to help drum up extra support for the campaign, only about 10 days left and we are only 50% there.
                                    design.medeek.com
                                    • jujuJ Offline
                                      juju
                                      I'm willing to double my support, which isn't much but will help the cause.
                                      I'm hoping this kickstarter takes off...
                                      *** EDIT ***
                                      So, apparently, once you've backed the kickstarter you can't do another pledge?
                                      • TandemT Offline
                                        Tandem
                                        It would be interesting to hear from the current users of the Truss and Foundation plugins. Looking at the Kickstarter project it looks like only 4 Truss Plugin users are interested in the upgrade and none of the Foundation Plugin users are showing any interest. Although it is possible that some of the existing users are among the 23 backers that made the Basic or Advanced pledges. Still, only 30 backers?
                                        • medeekM Offline
                                          medeek
                                          There are currently 371 active (unique) users of the truss plugin. Yet the turnout is very low with the Kickstarter Campaign, which leads me to one of two conclusions:
                                          1.) Kickstarter does not work well with the SketchUp community.
                                          OR
                                          2.) The number of "active" users of the plugin is much smaller than the registered user base.
                                          If #2 is the case then it leads one to believe that the real world utility of the plugin is limited at best. Admittedly the plugin is a bit of novelty, it can do some cool stuff but does the registered user actually employ it on a daily basis and does it add significant value. These are questions that I have been asking for some time but do not have a clear answer on.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I've posted the Html Timber Truss input page at the link below so anyone can start putting it through its paces and offer me some feedback.
                                            (design.medeek.com)
                                            I still need to add in the algorithms for the bolts into the top chord and top of the king post, should be able to knock that out this evening.
                                            I will probably need to add in some extra logic that deals with bolt placement at the heel joints especially when the scarf cut on the bottom chord extends below the centerline of the bottom chord.
                                            design.medeek.com
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 74
                                            • 75
                                            • 41 / 75
