    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • jujuJ
      juju
      Thanks for the clarification Nathan, maybe download access to the last version a licence qualifies for is needed? I've only seen upgrade options (when licence has come to expiration date) and no alternate link to last qualifying version.
      Having said that, upgrades are quite affordable, thank you.
      • medeekM
        medeek
        I agree that I should probably have a page with the ability to download any of the previous versions. I have resisted this slightly though since earlier versions did not implement any licensing system and in my mind some of the earlier versions are such crude and flawed attempts that no one in their right mind would want to use them over the current versions.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
          dpaul
          It is a pleasure to watch the remarkable development of this plugin (and the others).
          A question: might it be possible to control the overhang of the roofing layer only so we can add as much
          detailed fascia work as we require (say using PB) to complete the roof details?
          Thanks.
          • facerF
            facer
            MEDEEK PLUGINS - PRICING POLICY ($)
            Posting by Medeek at:
            by medeek » Wed Aug 02, 2017 12:30 am
            https://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63133%26amp;p=623551#p623551
            There seems to be some confusion regarding the licensing for the plugins. Just to be clear when you purchase a license it is permanent, it will work forever. There is no need to renew your license for continuous functionality.
            Sample Model - view on any web device and in VR using iphone with cardboard viewer or headset
            Sketchfab LINK:
            https://sketchfab.com/models/7dd005d09e ... 19b6dc4cfa
            • medeekM
              medeek
              @dpaul said:
              Might it be possible to control the overhang of the roofing layer only so we can add as much
              Thanks.
              I have given this some thought previously since I am only really modeling the sub-fascia and not the entire fascia treatment. By the way what does PB stand for?
              Should both the roof cladding and sheathing layer have this ability for an additional overhang or just the rood cladding? I am thinking about adding this setting into the global settings where you set this additional offset for the roofing/sheathing.
              http://design.medeek.com/resources/images/truss_su205_800.jpg
              design.medeek.com
              • jujuJ
                juju
                PB = Profile Builder
                Profile Builder 2 out now, much improved from original Profile Builder.
                  dpaul
                  I think just the roof cladding. Our trim can go up under the cladding and hide the
                  roof sheathing and sub-fascia.
                  Thanks.
                  • medeekM
                    medeek
                    The order of operations here is important since it will generally determine how or what overlaps what.
                    The order of installation as I see it (correct me if I'm wrong).
                    1.) Trusses, rafters
                    2.) Sub-Fascia
                    3.) Sheathing (OSB, Plywood)
                    4.) Fascia/Trim
                    5.) Roof Cladding
                    I was thinking one could install the Fascia/Trim last but thats assuming the drip edge (flashing) is already installed and if there is any thickness to the fascia/trim this does not seem like a possibility.
                    In any case it seems to me that one would want to probably cover up the edge of the sheathing if there is no drip edge.
                    design.medeek.com
                      dpaul
                      You are right, or course, about the order of installation on a site (and in how you are organizing the plugin).
                      However, in terms of my modelling and rendering, I will not necessarily be showing any drip cap on the gables themselves, just the top portion of the trim assembly (fascia plus bed moulding ,etc.) right under the roof membrane---or shingles.
                      This trim assembly will cover the thickness of the roof sheathing. (1/2" ply, say?)
                      If you can give us the option in the global settings to extend the roofing itself, can you also give us an option for the gable drip cap as well? Certainly on any hip we will put in a drip cap to take the water over into the gutter.
                      Thanks.
                      • medeekM
                        medeek
                        Talking with some other users about the timber truss module I think it may be useful if the module could generate a separate detail with dimensions etc... for each plate.
                        I don't know how to do this in layout so I will probably use SVG and html.
                        design.medeek.com
                        • jujuJ
                          juju
                          That is quite a niche use, probably a "pro version" or "engineering version" item?
                          • medeekM
                            medeek
                            Progress is slow but steady:
                            http://design.medeek.com/resources/images/truss_su260_800.jpg
                            Now I just need to add the bolts to the peak and heal plates...
                            Full on calcs would be nice too, but I'm just getting ambitious again.
                            design.medeek.com
                            • G
                              glro
                              what is the niche use?
                              is it the engineering version?
                              or is it the hobby version?
                              hobbyist don't make money with sketchup
                              so hobbyist won't pay for the extension
                              maybe the engineering version is the one that could bring to the developper the resources needed to developp the extension
                              possible to create a scene for each plate and add dimensions directly in sketchup
                              just ideas ...
                              • facerF
                                facer
                                Medeek Const Library - Kickstarter Status at: 5 Aug
                                https://www.kickstarter.com/projects/128644708/medeek-construction-plugin-library
                                All or nothing. This project will only be funded if it reaches its goal by Tue, August 29 2017
                                • jujuJ
                                  juju
                                  At glro: you're new to the extension, else you would know that there is no free version, except maybe the trial, so the developer would already be earning revenue. What I understand he wants to do is develop a module whereby a cut list and punch list is generated, which means the engineering end has to be up to scratch, which I don't doubt Nathan can do, but the building codes may differ (liability problems), and most user won't need to generate cut lists or punch lists, thus niche use.
                                  • facerF
                                    facer
                                    8 Aug Update
                                    • facerF
                                      facer
                                      Medeek,
                                      Please check your private messages, you have yet to respond to a PM proposal I posted.
                                      Regards,
                                      Ray
                                      • facerF
                                        facer
                                        Medeek Const Library - Kickstarter Status at: 14 Aug
                                        • medeekM
                                          medeek
                                          Back from my trip to Utah. I had to take a day yesterday just to recuperate from my vacation, 5 kids can wear anyone out.
                                          Facer will be implementing a new program to help drum up extra support for the campaign, only about 10 days left and we are only 50% there.
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            I'm willing to double my support, which isn't much but will help the cause.
                                            I'm hoping this kickstarter takes off...
                                            *** EDIT ***
                                            So, apparently, once you've backed the kickstarter you can't do another pledge?
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 76
                                            • 77
                                            • 41 / 77
