    Sketchup to Oculus Rift DK2 Workflow
    18 Posts 5 Posters 16.7k Views 5 Watching
    • jo-keJ
      jo-ke
      OK. A new challenge for me:
      I want to render a footage with twilightrender for Oculus.
      What would be the workflow?
      I want to do a fly arround with 180° stereosscopic. This should be working, I hope.
      How can I set the two camerapaths right an left eye?
      how can I merge both series in one Video together fitting with Oculus?
      A lot of thnings to learn...
      http://www.zz7.de
      • jo-keJ
        jo-ke
        It worked better then I thought.
        first 180° Pano is finished:
        I converted the to pic to a video and it was possible to display it in Oculus rift with NeoVr player
        Nice 3D effect.
        Next thing I want to try is a full 360° Pano.
        Now I need a free video editor, which is able to produce an output of a 2048x2048 Video out of a single Pic with both equirectangular panoramas (made in Photoshop)
        Has anyone a recomendation for a free videoeditor?
        http://www.zz7.de
        • jo-keJ
          jo-ke
          OK I've found VSDC Video Editor.
          I'll try that this weekend.
          setting the two equirctangular panos in PS is tricky, because if you look north, your left eye is left but if you look south your left eye is right, so I've had to change the half of the panos...
          Let's see, if it has worked.... I will post it here....
          http://www.zz7.de
          • jo-keJ
            jo-ke
            this will be the movie:
            http://www.zz7.de
            • jo-keJ
              jo-ke
              Hmm. It really works but the problem is the video editor. It is not possible to choose a free aspect ratio. only 3;4 oder 16;9 but I need 1:1
              anyody's an idea how to get an aspct ration as described?
              http://www.zz7.de
              • jo-keJ
                jo-ke
                OK, I streched the aspect ratio and it worked fine now in Oculus.
                Problem now: I lost somewhere resolution. Output quality is 3640x2048. That is fine but my pic is much lower and pixled... No idea how to change that.
                http://www.zz7.de
                • jo-keJ
                  jo-ke
                  OK problem solved. VSDC can do that.
                  seems that nobody is interessted in that theme.
                  http://www.zz7.de
                  • K
                    kaas
                    @jo-ke said:
                    seems that nobody is interested in that theme.
                    To me its a bit 'strange' using an Oculus to view stereo pano's. You could do that with a fancy phone and Google Cardboard.
                    May I ask why you want to use the Oculus for this instead of investigating a nice workflow getting your models into Unreal of Unity?
                    • jo-keJ
                      jo-ke
                      the reason is that I usually produce panos and I am happy with the quality in twilight render. Learning a new solftware like unity is very timeconsuming. I don't have that time at the moment
                      http://www.zz7.de
                      • jo-keJ
                        jo-ke
                        I've found out that the 360° panoviewer of Oculus rift is able to display 360° stereopanos. So you can put the pano directly to your pictures folder of Oculus.
                        http://www.zz7.de
                          jorgearq0000
                          Estoy muy interesado en el tema, no tengo aún oculus porque tengo MAC pero estoy planeando pasarme a PC por los problemas de compatibilidad de MAC con los visores VR, Pronto esscribiré mi aporte al respecto
