    Toggle between tools?
    9 Posts 6 Posters 1.7k Views 6 Watching
      djh
      May one easily toggle between tools?
      In other programs, for example, if one is using the "line tool" one may press on the space bar and the tool goes back to the "select tool". He may press on the space bar again and the tool goes back to the "line tool".
      • pbacotP
        wanted this for years... It would be nice if it worked in plugin actions too.
          djh
          May we petition Trimble to include this basic feature?
          • kimi kimiK
            kimi kimi
            How do you type 7 5/8" then? Space bar is taken. First you need a petition to kill feet and inches.
            • C
              Charlie__V
              Why 7.625 of course. 😎
                JGA
                Matthieu NOBLET released a plugin Recall_last_tool.rb that worked with SU7, but I've found it didn't appear to work with SU201* versions.
                Recall_last_tool.rb
                Regards,
                JGA
                  djh
                  JGA, perhaps because it has to be *.rbz and not *.rb
                    JGA
                    djh,
                    *.rb is the ruby file in plain txt format
                    *.rbz is the more modern version that is a ruby file compressed in a ZIP file, with the extension changed from .zip to .rbz.
                    Regards,
                    JGA
                      slbaumgartner
                      Depending on what kind of errors occur, that could be because SketchUp changed from Ruby 1.8 to Ruby 2.0 in 2014, or it could be due to changes in the SketchUp API. It is quite common for older plugins, especially way back to SU7, to need updating for new versions of SketchUp.
