    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      @fernandocatalan said:
      como descargo en esta pagina no eh podido
      First post of this thread.
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v7.6a - 25 May 17
        LibFredo6 7.6a is a major release dedicated to Animator 1.6
        See main post of this thread for Download of LibFredo6.
          lilywater
          thank you for your offer!
            CharlyLee
            Awesome!!! Thanks
              gene123
              thanks a lot
                Tantema
                Hi - I am running Sketchup 2016 and I seem to be having many of the same problems I see popping up here.
                1. I installed LibFredo6 successfully after many deletions and redownloads. I say "successful" since I was finally able to open sketchup 3 times without this error message:
                Error Loading File C:/Users/Gordon/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                Failed to read RBE/RBS file.
                Error Loading File Fredo6_!LibFredo6.rb
                Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                C:/Users/Gordon/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Gordon/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                C:/Users/Gordon/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                During that time I also installed Curviloft and while I was not receiving an error from the Library I was getting this message upon startup:
                You must install LibFredo6 version 6.9 or higher to run Fredo6_Curviloft
                At no point did LibFredo6 options appear in my Windows tab. None of the Fredo pluggins show up in my Warehouse list of extensions for me to activate. Now I am receiving the notification that I need to install the Library (and I have been trying to install v7.6a) as well as the Error listed above.
                Deleting all Fredo related files and starting over does not seem to work as I've been doing it 3 - 4 time a day now for a week. Any help would be greatly appreciated since I would love to be able to take advantage of these tools. It makes trying to learn anything frustrating when 99% of tutorials on-line say "just engage this toolset and voila!" when simply downloading the toolset is what prevents the advancement.
                  Assuming you have the latest LibFredo RBZ...
                  Please check that you have installed SketchUp properly...
                  Close SketchUp.
                  Find the SketchUp installer exe file [probably in your Downloads folder]
                  Select its icon.
                  Right-click > Context-menu > Run as administrator...
                  When offered choose 'Repair'.
                  Restart SketchUp - any improvement ?
                  • fredo6F Offline
                    @tantema
                    This is not related to LibFredo6 specifically but to Sketchup and your user account in Windows. For some unknown reason, this gives this type of error (failed to read rbs/rbe), even for the plugins shipped by Sketchup like the sandbox).
                    You have a discussion there on the problem.
                    I am not sure the Sketchup teams has yet identified the cause of the problem, which happens in SU2016 and SU2017.
                      KMA
                      Dear form editor.
                      Greetings.
                      I have google sketch-up 2015 pro.
                      1. I have installed the plug-in from the presences section / extensions : install extension
                        after downloaded from the website
                      2. restarted the program for activating the plug-in
                      3. message pops-up as following "you have to visit the website to make the plug-in working"
                      and the normal website as follow
                      RoundCorner | SketchUcation
                      (sketchucation.com)
                      which is the first step of installation1.png, which is pointless.
                      please to inform me what to do.
                      find the attachment photos
                        @KMA
                        Most of Fredo's extensions also need his Lib installing - that Lib has many shared supporting utilities.
                        Download the RBZ for his Lib from the PluginStore... and install that.
                        https://sketchucation.com/pluginstore?pln=LibFredo6
                        Restart Sketchup afterwards, to ensure that everything gets properly synced.
                          KMA
                          Greetings:
                          KMA89Window tab not showing extensions manager
                          I have downloaded the round corner plug-in normally.
                          also I have google sketchup 2015 pro, as per the video, I do not have the same windows as in the video, the window tab is not showing the extension manager, only all I did is installing the extension from the preferences tab, so every time I start the program this message popsup as in 2nd picture.
                          please ant advises for this issue
                          • fredo6F Offline
                            That's what TIG was telling you.
                            To make RoundCorner work, you need to install the Library LibFredo6, which apparently you did not.
                            See this post for how to install LibFredo6>
                            Note that LibFredo6 is common to most of my plugins, and therefore you need to install it (and update it) once.
                              Marcadam
                              Hi everyone : thank you Fredo for your great tools. I have tried to install them some time ago and watched Fredo's video a few times. I get plenty of error messages on start-up like
                              Error Loading File C:/Users/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                              C:/Users//AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users//AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                              C:/Users//AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>
                              In his video, Fredo opens a menu called extensions under Preferences. This does not exist in my version of Sketchup Make 2017. I see that Fredo 6 Lib Tools are installed and enabled in the extensions manager, but they dont show up as menu. What am I doing wrong ? Thanks for any help - Marc
                                In v2017 the 'Extensions Manager' is now accessed from the SketchUp 'Window' menu - this is now common between PC and MAC.
                                That resultant dialog has a red button which is used to install extensions [much as previously]...
                                Let's assume you messed you when attempting an unnecessary manual installation...
                                Try again...
                                Remember that most of Fredo's tools also need his 'LibFredo' installing [first].
                                If errors persist you might have previously failed to install SketchUp correctly.
                                The only proper way to install SketchUp is to close it if its already running, then find its installer's exe file [probably in your downloads folder ?], select its icon, right-click > context-menu > "Run as administrator"
                                If SketchUp is already installed, when prompted choose 'Repair'...
                                If it's actually a fresh installation, then accept that option...
                                SketchUp should now be properly installed...
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v7.7a - 09 Jul 17
                                  LibFredo6 7.7a is a major release dedicated to the support of high-resolution and Retina screens and Retina.
                                  Basically, the button palettes, progressions bars, the text font, the line thickness and the dimension of some visual marks are grown by the factor of resolution.
                                  • Sketchup < 2016: Font size cannot be changed and characters may thus still appear small. you have also to set up manually the scale factor
                                  • Sketchup 2016: you have to set up manually the scale factor (usually 2), because it cannot be detected by the API.
                                  • Sketchup >= 2017: the configuration is activated automatically. Still, you can manually disable the option.
                                  The settings are in the LibFredo6 Default Parameters:
                                  Because most of plugins uses LibFredo6, the support of hi-res screens should apply to all my plugins. However, there may be changes required in each individual plugin, which will be rolled out progressively.
                                  IMPORTANT:
                                  • HoverSelectis NOT supported for hi-res screens
                                  • Animatormust be upgraded to v1.7a or above
                                  Please report all issues and suggestions in this dedicated thread on the Sketchucation forum
                                    rv1974
                                    Almost 300000 downloads... Blockbuster! Is it only last version or cumulative?
                                      ajiprihastono
                                      Frodo,
                                      I am using sketchup pro 2016, and I dont find extension manager menu in my windows bar. Can you guide me how to get it?
                                        @ajiprihastono said:
                                        Frodo,
                                        Look in Preferences>Extensions for Install Extension. Best to install the Sketchucation Extension Store from Resources at the top of the page and use it to install LibFredo6 and other extensions.
                                          classicaircraft
                                          Good day Fredo, I'm VERY new to SketchUp so please bear with me. I have watched the video wrt installing plug-ins/extensions and am happy that I'm doing it correctly. When I start SketchUp I get this error message for both v7.6 and 7.7:
                                          C:/Users/Main/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Main/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                          C:/Users/Main/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                                          "Aidez moi s'il vous plait"
                                          Kind Regards,
                                          Joe J
                                          • fredo6F Offline
                                            Joe,
                                            Looks like you have a wrong installation.
                                            Could you please show the footprint (i.e. files and folders) in your Sketchup Plugin directories, that is:
                                            • 108
                                            • 109
                                            • 8 / 109
