    UV mapping of reflection map in Sketchup?
    renderpluginsextensions
    5 Posts 5 Posters 3.8k Views 5 Watching
    • G
      gnome_mo
      Is it possible to custom position reflection and glossiness maps in vray for sketchup?
      I'm trying to add some surface imperfections like puddles on the road, fingerprints, but not as edited diffuse texture.
      Thanks in advance
      • andybotA
        andybot
        Unfortunately, you're limited to the one channel that SU uses, so additional maps can only be mapped relative that that channel (you can use the UVW transforms like scale and rotation.) There's no way to add additional mapping per material.
        However, if you export the mesh and edit the UV mapping in another 3D software (such as Blender) you can bring in those additional channels by making that mesh into a proxy outside of SU. (There's a mesh to proxy converter included with vfs3: "ply2vrmesh" in "tools" in the vfs3 program folder) Then in SU, you can select the additional channels in the Vray material editor as required.
        • omiKronO
          omiKron
          It could be a trick faking the order of layers. You have your main diffuse, you add a reflection layer with a texture linked to it, then swap order of layers. Or, if this doesn't do it, make 2 Diffuse layers : one with color, one with a texture [like puddles, imprints]. swap it the way you like. Then drag-n-drop the bitmap slot of Diffuse in Reflection.
          If that doesn't do it, you need to separately scale the puddle-imprint texture to your diffuse texture.
            anamichelena
            So, if I get this right: in the 'texture placement' menu, you can choose a UV channel/set (by default set to 1), but there is no way to assign and use these different channels?
            Does this make sense to anyone else? πŸ˜•
            Ana
            hardware:
            MSI Apache Pro
            Intel Core i7-6700HQ
            16GB ram
            GeForce GTX 1060
            • filibisF
              filibis
              Check this fresh plugin: Physically-Based Rendering
