[Plugin] FloorGenerator ( Updated 6-Apr-2017)
why is there no option for an origin point where you click? Why center or left lower corner only? I mean this would be useful
Because I assumed that the center or a corner were the most logical points of origin. FYI, the closest corner to the point you pick is used. Not just the lower left corner.
Can I please have a link for SU7. Latest one doesn't seem to work in SU7.
Cheers,
Mark -
Cheers,
MarkSorry I can't. There is only one version.
seems working perfectly in 2017!
[attachment=0:ocy8vhzy]<!-- ia0 -->sdm_floor.jpg<!-- ia0 -->[/attachment:ocy8vhzy]I think he has version 7 not 2017.
Hello could you tell me how to install it please...!!!!
Most Plugins and Extensions' RBZs can be downloaded from the SketchUcation PluginStore:
https://sketchucation.com/pluginstore?pln=SDM_FloorGenerator
Have a browse and be amazed...Use the native Extension Manager to install them.
Alternatively download and install the SketchUcation ExtensionStoreΒ³, then you can browse and auto-install extensions directly from with SketchUp itself - sidestepping the download part altogether... -
Just can't make it work, the command window never show up
I reayly like to make it run.....
There is what i get when i try to run it
SystemStackError: stack level too deepI do have Sketchup 2017 Version 17.21.2555 64 bit
On windows 10 professionnel version 1703(15063.332)(French Version)
I have Thearender for sketchup plugins install
Graphic card: GTX 1060
CPU: AMD FX-6300
8 gig off rami have this message in the console
i also have this line appears many many time before the error
read_default failed
Error: #<SystemStackError: stack level too deep>
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:ininitialize' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in
initialize'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:inmethod_missing' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in
update_wd'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:174:inrescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in
update_wd'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:170:inrescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in
update_wd'
update_wd'
update_wd'
update_wd'
update_wd'
update_wd'
update_wd'
Works fine for me with new Window 10 "creative" (French) not Pro but Familly!
Have you some accents on the paths Folders ?
Have you install it from the "Red Ruby" Menu from Sketchup ? -
These read_/write_default errors [and many more] might be because you have not initially installed SketchUp correctly.
Thereby stopping you/SketchUp accessing the Registry properly.Here is how to install SketchUp properly...
Find the SketchUp installer's exe file - probably in your Downloads folder.
Select its icon, right-click, context-menu, "Run as administrator"...This will ensure it's correctly installed, and that you and the app now have proper permissions set up.
If you already have SketchUp installed you probably do not need to uninstall/reinstall it - firstly try this...
Close SketchUp.
Use "Run as administrator" on the installer's exe file, as explained above...When prompted choose "Repair"...
This should fix issues.
Report back...
Close SketchUp.
Report back...
Thanks Tig
But i just reinstall it with the repair option as administrator but i still have the same result...
i will try to uninstall everything and try it again....
i don't know if it can have something to do with it , i had system mechanic running on it before, may be it did change some rule somewhere about the ability to read the registry.... -
Have you install it from the "Red Ruby" Menu from Sketchup ?[attachment=0:2yws8aqg]<!-- ia0 -->red ruby.jpg<!-- ia0 -->[/attachment:2yws8aqg]
[attachment=1:2yws8aqg]<!-- ia1 -->floor01.jpg<!-- ia1 -->[/attachment:2yws8aqg]
Yes i did install it with the Red Ruby Menu from sketchup, i have a lap top and its not working there to, same result.... i really dont know why, this plugin can really help me....if i can make it work
I dont have any accent in my path....
Your earlier post suggested that you have messed around with the Registry settings.
SketchUp, and some of its plugins need to write and read values from the Registry - so they are remembered across sessions...
If that ability has been limited you will get problems !What did you do
Previous versions of SDM_FloorGenerator had a problem with reading defaults from the registry when new pattern options had been added but I believe I finally fixed that problem in the May2017 release. Make sure you have the latest version.
Hi Sam, just have a question about what's going on here...
When I select the random texture option and select the source of the textures, I select a .skm file then I get a material picker dialogue box showing on the screen that has nothing but a select button.Any suggestions?
Edit: I have loaded the latest rbz file by the way....
The random texture option is not designed to use .skm files only .jpg,.png,.etc.
No worries. ta.
I really dont know, i never go in there to change value or key's, that's why i suspect System Mechanic
