    [Plugin] HoverSelect - v1.5a - 07 Oct 17
    81 Posts 34 Posters 126.2k Views 34 Watching
    • fredo6F Offline
      Does this problem happen only with HoverSelect or all my plugins?
      If so, this may come from a conflict with some other plugins (like some versions of Podium and Matchbox)
      • SwissmountainS Offline
        Swissmountain
        All your other plugins work like a charm on my machine Fredo, thank you for the update to the round corner and curviloft scripts earlier this year!
        The hoverselect sounds like an amazing tool for speeding up more organic modeling approaches which require selection and scaling of splines, I would love to make it a part of my toolbox.
        Cogito ergo dum-di-dum
        • fredo6F Offline
          NEW RELEASE: HoverSelect v1.2a - 27 Nov 13
          HoverSelect 1.2a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
          • fredo6F Offline
            NEW RELEASE: HoverSelect v1.3a - 20 Oct 14
            HoverSelect 1.3a is required for the support of usernames with non-ascii characters in Sketchup 2014.
              greatoe
              @swissmountain said:
              @carrozza said:
              I have pretty much the same problems as Dereeei (see above): when I activate the plugin and click-hover on edges nothing get selected.
              Hey Fredo, same problem over here on Mac OSX Snowleopard, Sketchup 8.0.11751 & LibFredo6 - v4.4m - 14 Apr 12
              I see the menu but can't select anything, there is no selection rectangle either.
              Thank you for everything you do
              Ciao
              This issue still remains. Mac OSX El Capitan 10.11, Sketchup 2015.
              • fredo6F Offline
                Could you open the Ruby Console to chcek if there is an error message displayed.
                  greatoe
                  Nothing show up in the console.
                    rilian
                    Recently discovered this plugin. It installs and the menu items are there but I am not seeing the toolbar. It's turned on in the settings for the tool. I'm on SU 2017.
                    [edit] Clarification Note: It's not showing in the toolbars list nor displaying anything on the screen.
                      Did you look for the icon in the Fredo6 Tools toolbar as indicated in the first post of this thread?
                      It shows up and works just fine for me in SU2017.
                        giuliosaoncella
                        Hi Fredo! I have just now the opportunity to use and appreciate this fantastic plugin... Is it possible to add a Face-HoverSelect mode? Let me try to explain: I often import model from other CAD formats converted in 3ds, so I have a faceted model, no any circle/rect/curve/etc. In order to create sub-groups and/or adding material/color specs to them, I need to select ANY single face one click by another: terrible. Using the selection rectangle, unwanted results occour... If I can hover-select faces, instead, I can group and color them quickly. Do You think You can add this function or maybe create a dedicated plugin?
                        Thank You very much and many, many, many compliments for your great works!!!
                        Giulio
                        • fredo6F Offline
                          Not totally sure, but I think there exists some plugin doing that, possibly Thomthom's Selection Toys.
                          Maybe some other forum contributors know the options.
                            db11
                            Same here: also Mac OSX El Capitan 10.11, SU Pro 2015. This is a plugin I would use a lot if it worked properly on Mac OS.
                              giuliosaoncella
                              ...no... I have tested many plugins (including thomthom selection toys): all performs either a "filter" or a "search", but no one acts like the eraser tool, which effectively is what I need... thanks anyway to You and to all the plugins developers: You made Sketchup special!!!
                              Giulio
                              • fredo6F Offline
                                NEW RELEASE: HoverSelect v1.5a - 07 Oct 17
                                HoverSelect 1.5a is a maintenance release:
                                • required for the support of usernames with non-ascii characters.
                                • Support of OSX High Sierra
                                • Certified for SU2017
                                  Ahmed0007
                                  Follow mode not working
                                  any solution?
                                  • fredo6F Offline
                                    any solution?
                                    Can you clarify and explain what is the problem. Follow option works fine for me.
                                      Ahmed0007
                                      @fredo6 said:
                                      any solution?
                                      it's select whole. even i set the limit
                                      and please add "Stop at Edge Crossing"( ❀ ) feature in hoverselect like in Curvizard.
                                        Ahmed0007
                                        try in sketchup 2015,17,18
                                        here is one another Behavior that i don't understand
                                          Ahmed0007
                                          @fredo6 said:
                                          any solution?
                                          hello! fredo6 can you see my above response?
                                          • 5 / 5
