    [BUG] SU mesh Validity Check error
    renderpluginsextensions
    6 Posts 2 Posters 9.6k Views 2 Watching
    • O Offline
      optimaforever
      Hi all,
      From time to time I get the infamous Problems were found that could not be fixed
      The entity at address ********** has an invalid id (***) destroyed ()
      during a random Validity Check when saving the skp.
      I'm pretty sure it's related to SubD and QFT usage but can't solve the issue.
      Anyone?
        What SU version?
        What OS?
        You mention both SUbD and QFT. Do you have some steps that reproduce? A model saved?
        • O Offline
          optimaforever
          If it doesn't ring a bell to you, it means I'm an isolate case?
          The only way to solve the issue is to save, close skp and then reopen it...
          But that doesn't explain me where the issue lies...
            Not something I've seen or can recall hearing about before.
            That error seems to indicate an issue with the entity ID of some entities - which is something only SU assigns.
            I would need a way to reproduce in order to figure out what might be going on.
            • O Offline
              optimaforever
              The thing is, if I save you a file, then when you'll reopen it, you probably will not see the error.
              It only happens (eventually) when you're working and once it happens, you can't get rid of it until you close the file.
                Have you noticed any patterns that lead up to this?
                Also:
                What SU version?
                What OS?
