    6x1 Cubemap
    15 Posts 5 Posters 3.0k Views 5 Watching
      Macker
      That's disappointing. Presumably because both export plugins exhibit very similar issues, then this is a problem inherent in Sketchup? Surely two separate codes are unlikely to produce the same problem?
      It's a real shame, SU could really do with some more export options now that VR is taking off.
      Check out my blog @ http://macviz.blogspot.co.uk
        It's an artifact related to cubic maps. Typically cubic maps need each face to have a small amount of barrel distortion applied to compensate for this.
        http://wiki.polycount.com/w/images/thumb/3/35/Cubemap_angular_distortion.jpg/600px-Cubemap_angular_distortion.jpg
        Cube map - polycount
        (wiki.polycount.com)
          Macker
          This is the type of cubemaps we're producing (albeit this is a 12x1/stereo) http://cadpoint.co.uk/img//ChaosGroup/newinVray.3.2/blk_gear_vr.jpg
            Nice output!
            Why not render an equirectanglar image and then convert it?
              Macker
              How do you export equirectangular from Sketchup?
              • cottyC
                cotty
                A lot of renderers are able to produce equirectangular outputs.
                my SketchUp gallery
                  Macker
                  I'm not looking for a render engine - I want to use Sketchups styles to output "sketchy" images at stages that are too early in the design phase to warrant rendering properly in 3DS max/VRay.
                  • filibisF
                    filibis
                    Well, if you go to forum thread of that plugin, there Rami says:
                    @rami_lpm said:
                    Warning
                    This plugin is not working correctly in sketchup 2017. As a workaround, you can set resolution to 1020,2040 or 4080
                    So set your resolution multiplied by 2. There is no limit to this which means you can set it 8160, 16320 etc...
                      Macker
                      @rami_lpm said:
                      Warning
                      Perfect! Thank you!
                      I was using multiples of 1024. What an odd issue to have.
                      [Edit] HAH! The issue comes back if you use styles. Brilliant. Surely trimble must issue a fix for this?
                        driven
                        have you tried setting your 'Viewport' to the same ratio as export?
                        i.e. make it square...
                        • filibisF
                          filibis
                          Well, if you change styles, then this pattern works: 1024, 2048, 4086...
                          I have no idea but it works like this! πŸ˜„
                          Edit: False alarm! I had tried that in a rush and it doesn't really seem to work with styles πŸ˜•
