    Wish list for Sketchup 2018
    125 Posts 50 Posters 231.8k Views 50 Watching
      sketchgirl1
      My concern is for the artistic direction of SketchUp. For instance, the new orbit symbol isn't as nice as the last one, not even as descriptive. And we have to use this constantly. The "architectural design style" style isn't exactly the same, and not as nice. It can be changed to be more like the original, but why was it changed? It just doesn't seem like a truly artistic person is making decisions for Trimble or is on the staff.
        sketchgirl1
        But I love SketchUp!
          db11
          @bobrsta said:
          I often create a group or component, move to a layer, then hit the "m" key to move the object into place. Except I just created a layer "m" instead. I can't tell you how often I do that each and every day.
          Bob
          Agree with all of your points, but have little faith that they'll ever be addressed.
          Just finished writing a short rant at the other forum on a similar theme β€” the number of times a day I accidentally rename layers and components (usually with "m") because SU doesn't release focus on pressing enter β€” it highlights the entered text instead.
          @bobrsta said:
          To have the top view / parallel automatically be over where I last was in the model would be superb!
          Bob
          An available solution to your last request is provided by the Eneroth Relative Top View plugin, which works pretty much exactly that way. (If only she was designing the SketchUP UI I'd be so happy πŸ˜„ ... I'm a big fan of her work and her way of thinking)
          • SJS66S
            SJS66
            Not having to Save As a component, then open the component file, draw a line then erase it, just to give yourself credit for the work you have done. What pain in the **** that is! Automatic credit if you are logged in or something similar to save having to go through this time consuming exercise.
            • P
              pipingguy
              Would like to strike the spacebar to activate last tool used.
              • pbacotP
                Yes. I've wanted this for a long time. I would like to be able to assign a key. I use the return key in other apps, and if it doesn't interfere with anything, I'd use that. The space bar may be used by people in SU for the selection cursor (or NO tool).
                  driven
                  there's been a plugin around since v7, but the mac version is just code, hidden in the thread...
                  404 Not Found
                  (sketchucation.com)
                  it can only work with SU Tools because a large majority of plugins aren't even 'Tools', but a stream of macro commands...
                  I would also rather they fix the 'Return' key to work properly with the various input boxes than allow us to use it for a shortcut...
                  @ piping guy, without the Spacebar for 'Select Tool' as the default behaviour, my modelling would slow to a crawl...
                  • JQLJ
                    JQL
                    Me too, but if it could be configured by user both could set it up as wished.
                    I don't understand why some commands are hard built into some keys...
                    www.casca.pt
                    Visit us on facebook!
                      driven
                      without the hard coded defaults they can't appear in menus or Help files...
                      you would also need to set all of them from scratch...
                      you can change any of the SU ones [on a mac] if you think the choice of key is illogical...
                      • JQLJ
                        JQL
                        You're right!
                        What a Duh moment from me!
                        Somehow I was under the impression that Sketchup had some hardcoded keys that you couldn't change ever. Like "M" for the move tool. But that's not true, of course, I changed many of them myself.
                        What was I thinking?
                        I'm almost sure I had a key that I wanted to change but could not... maybe it was another software!
                        www.casca.pt
                        • V
                          veerlexyz
                          • Possibility to hide scenes in the toolbar (checkmark icon above "include in animation" in scenes-tab in default tray?)
                          • Possibility to put (less used) plugins (+ icons) in a library folder in the default tray
                          • JQLJ
                            JQL
                            And be able to group them... Scene Groups and ability for users to define where the plugins show up, overriding the defaults.
                            www.casca.pt
                            • sicksickisckS
                              sicksickisck
                              πŸŽ‰ Blender/Cycles render engine + node wrangler/ in Sketchup! this is sound like Christmas...
                              • P
                                pipingguy
                                bigger close-out button for model info box.
                                • T
                                  TBoy
                                  In "Metric world" it is usual length to be measured in cm or mm, but area in sq.m or bigger units (not sq.cm or sq.mm) that's why in "Model Info > model units" must be separate independent field for area units.
                                  • pep75P
                                    pep75
                                    Please add Material NAMES in the materials list!!! Now you've to hoover over to see its name. I can't believe that they still haven't done so. 😞
                                    • P
                                      pipingguy
                                      A choice for non-instantaneous transitions when toggling between camera views would be good. (just like the adjustable scene transitions)
                                      • P
                                        pipingguy
                                        Wish for the ability to automatically re-select previous selection set.
                                        • P
                                          pipingguy
                                          Ability to snap to an inference when using the move tool to extend or retract the end of a cylinder. Currently, one needs to punch the appropriate arrow key, or hold the shift key, to make this work.
                                          • P
                                            pipingguy
                                            I wish any contents contained within a group or component's instance field can be automatically omitted as an option when exporting a model in 3D form to AutoCAD. Otherwise, they become displayed as text objects that are not easily erased.
                                            • 3 / 7
