    Wish list for Sketchup 2018
    125 Posts 50 Posters 234.0k Views 50 Watching
    • zain01Z
      zain01
      I would like to customise my tools bars on Mac like they can be in windows. Floating toolbars are a bit annoying and time consuming moving them around.
      • zain01Z
        zain01
        A button for locking the orthographic view when working in 2d would be helpful.
        Would make panning around easier. If i accidentally orbit i have to click on plan view button again to align the view again. Also maybe being able to rotate the view locked in orthographic would be useful.
          drafter
          A program loading Progress Bar such as found in Windows. No big deal.
          • E
            ezlde
            in older versions there could be found LINE TO FACE plugin, that made face from single line, like push/pull for faces, just for line and face could be pulled to any direction, now with the "older extensions won't apply in the warehouse" that usefull plugin nowhere to be found and is so missing, would be great to recreate again this tool
            • pbacotP
              I use extrude tools for this now, or Vertex tools ($). You can draw out a face with one edge or multiple edges.
              • B
                bobrsta
                I may have posted this request before, but I'd really like the ability to "Lock" an object yet still be able to hide it. Locking should keep me from moving it, deleting it, changing any attribute - except visibility. I understand that layers are the main way that SU handles visibility, but my models have well over 100 layers now and if I was to create a layer for every single entity that I may want to randomly and temporarily remove from view (blocking something I'm looking at / modeling), I'd have thousands of layers. As it is, I must either unlock / lock an object every time its in the way of modeling something else, or risk moving it inadvertently and not discovering that until who knows when and after who knows how many objects have been modeled based on it. Which happens too often.
                Another request, I often create a group or component, move to a layer, then hit the "m" key to move the object into place. Except I just created a layer "m" instead. I can't tell you how often I do that each and every day. In order to make that work flow work, I have to deselect my object, then reselect it! Find a way to make that work better, please, such as requiring that I actually hit the "+" in the layer window.
                Another request, if anyone from Trimble watches this forum, some awareness in the program about where current modeling is taking place - as in, I often start to model something (usually piping or ductwork diagram with 3Skeng tools) in close and in perspective 3D. I then go to top view parallel so I can see my end point. I find that I have to scroll waaaay out and then back in on my modeling location. To have the top view / parallel automatically be over where I last was in the model would be superb!
                Whew, glad to get those off my chest.
                Bob
                  sketchgirl1
                  My concern is for the artistic direction of SketchUp. For instance, the new orbit symbol isn't as nice as the last one, not even as descriptive. And we have to use this constantly. The "architectural design style" style isn't exactly the same, and not as nice. It can be changed to be more like the original, but why was it changed? It just doesn't seem like a truly artistic person is making decisions for Trimble or is on the staff.
                    sketchgirl1
                    But I love SketchUp!
                      db11
                      Bob
                      Agree with all of your points, but have little faith that they'll ever be addressed.
                      Just finished writing a short rant at the other forum on a similar theme β€” the number of times a day I accidentally rename layers and components (usually with "m") because SU doesn't release focus on pressing enter β€” it highlights the entered text instead.
                      Bob
                      An available solution to your last request is provided by the Eneroth Relative Top View plugin, which works pretty much exactly that way. (If only she was designing the SketchUP UI I'd be so happy πŸ˜„ ... I'm a big fan of her work and her way of thinking)
                      • SJS66S
                        SJS66
                        Not having to Save As a component, then open the component file, draw a line then erase it, just to give yourself credit for the work you have done. What pain in the **** that is! Automatic credit if you are logged in or something similar to save having to go through this time consuming exercise.
                        • P
                          pipingguy
                          Would like to strike the spacebar to activate last tool used.
                          • pbacotP
                            Yes. I've wanted this for a long time. I would like to be able to assign a key. I use the return key in other apps, and if it doesn't interfere with anything, I'd use that. The space bar may be used by people in SU for the selection cursor (or NO tool).
                              driven
                              there's been a plugin around since v7, but the mac version is just code, hidden in the thread...
                              404 Not Found
                              (sketchucation.com)
                              it can only work with SU Tools because a large majority of plugins aren't even 'Tools', but a stream of macro commands...
                              I would also rather they fix the 'Return' key to work properly with the various input boxes than allow us to use it for a shortcut...
                              @ piping guy, without the Spacebar for 'Select Tool' as the default behaviour, my modelling would slow to a crawl...
                              • JQLJ
                                JQL
                                Me too, but if it could be configured by user both could set it up as wished.
                                I don't understand why some commands are hard built into some keys...
                                www.casca.pt
                                Visit us on facebook!
                                  driven
                                  without the hard coded defaults they can't appear in menus or Help files...
                                  you would also need to set all of them from scratch...
                                  you can change any of the SU ones [on a mac] if you think the choice of key is illogical...
                                  • JQLJ
                                    JQL
                                    You're right!
                                    What a Duh moment from me!
                                    Somehow I was under the impression that Sketchup had some hardcoded keys that you couldn't change ever. Like "M" for the move tool. But that's not true, of course, I changed many of them myself.
                                    What was I thinking?
                                    I'm almost sure I had a key that I wanted to change but could not... maybe it was another software!
                                    www.casca.pt
                                    • V
                                      veerlexyz
                                      • Possibility to hide scenes in the toolbar (checkmark icon above "include in animation" in scenes-tab in default tray?)
                                      • Possibility to put (less used) plugins (+ icons) in a library folder in the default tray
                                      • JQLJ
                                        JQL
                                        And be able to group them... Scene Groups and ability for users to define where the plugins show up, overriding the defaults.
                                        www.casca.pt
                                        • sicksickisckS
                                          sicksickisck
                                          πŸŽ‰ Blender/Cycles render engine + node wrangler/ in Sketchup! this is sound like Christmas...
                                          • P
                                            pipingguy
                                            bigger close-out button for model info box.
                                            • 3 / 7
