    Dimension at center
    layout
    5 Posts 3 Posters 2.8k Views 3 Watching
      dieter10
      I have a trouble with Layout 2017.
      When I want to dimension at the center of a hole, the dimension box always becomes red.
      What should I do?
      -Reconnect to model doesn't work
      -The clipping mask is not the problem
        The red box indicates that the dimension is disconnected from the geometry in the SketchUp file. Does selecting Reconnect from the right click context menu fix it?
        Is the hole's edge a circle? Are you inferencing off the center of the circle?
        If nothing else works, you could just right click on the dimension and choose Explode.
          dieter10
          1. No
          2. The hole edge is a real circle and not a polyline. I selected the center (blue dot appears), when selecting the edge of the circle its no problem
          3. Explode works fine
          Is this a bug?
            I doubt it.
            • GMthompsonG Offline
              GMthompson
              smustard "set centerpoint.rb: is one of my most used plugins, may help if not you will find it useful anyways
              you can learn something everyday by paying attention
