    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 883.2k Views 172 Watching
    • ecatiE Offline
      ecati
      Hi, Anton,
      First of all thank you very much.
      I do not want to bother you with such simple questions. But I have not found a tutorial that will answer my questions. If I'm not wrong, you're preparing a tutorial, are not you?
      Now, how can I bring the green piston into its original position with a spring after it is pulled out?
      Thank you.
        BallBearing
        I got the worm gear to do it's work quite nicely (MSPhysics & Sketchy). Just making the collision mesh groups is time consuming. I wonder if there exist possibility for something like in Blender & mesh collision option? The collision frame is not so super exact...
        SketchUp, 3D printing stuff and more:
        http://www.youtube.com/user/CinemaTablet
        • gillesG Offline
          gilles
          @ecati said:
          Hi, Anton,
          Thank you.
          Cut the piston from it's context escape the context then paste in place.
          • ecatiE Offline
            ecati
            Collision problem.
            When the first part is moved, it enters into the second part and the third part escapes from the center. How is this prevented?
            To see the animation, clik on the picture please.
              Anton_S
              Hi, Ecati,
              I first need release version 1.0.0. Then I will transition to making tutorials. The tutorials is a bold part on my TODO list.
              You can't have the green thing be connected to a piston and the spring at the same time. You can simply tell the piston to move back to its original position by dragging its associated slider controller to its original position. You can as well change the controller of the piston joint to do it with a click of a key, such as key('f') * 5, so that it moves 5 preset units (millemeters in your case) when key F is held down and back to initial location when the key is released. You can add a negative sign to 5 or in front of the controller for it to move in the opposite direction.
              @ecati said:
              Collision problem.
              There must be something in the way. Here is a few potential causes to this:
              1. Part2 is connected to multiple joints, such as the hinge and the piston. It must be connected to just the hinge.
              2. Either part2 is pushed out by part3 (if the hinge is not inside part3 or part3 state is not set to non-collidable). Either move hinge inside part3 and set it static or set part3 non-collidable so it doesn't push out part2.
              3. Another collision outside the shown view is stopping part2.
                There could be many reasons. I won't know until I inspect the actual model myself, but the actual cause may very likely denote one of the provided potential causes above.
              Regards,
              Anton
                Anton_S
                Hello, Martin,
                Those images show it in SketchyPhysics, but it will work the same in MSPhysics.
                So, another way of doing it (in MSPhysics) is by using geared joints:
                1. Set both gears to non-collidable and remove all original joints connecting the gears.
                2. Add a Piston joint at the location and in the direction of the wormgear and connect it to the wormgear (using the Joint Connection Tool).
                3. Add a Hinge joint at the center and in the normal direction of the gear and connect it to the gear.
                4. Using the Joint Connection Tool, connect Piston joint to the Hinge joint to create a geared joint.
                5. Adjust the gear ratio of the piston-to-hinge gear using the MSPhysics UI.
                  Make sure you're using MSPhysics toolbars for doing all that...
                Regards,
                Anton
                • ecatiE Offline
                  ecati
                  Where do we download MSPhysics 1.0.0?
                    You could wait [joke 😉 ] ?
                    The current version is 0.9.9 - and it's latest version is always available from the SketchUcation PluginStore:
                    http://sketchucation.com/pluginstore?pln=MSPhysics
                    Like most Plugins/Extensions...
                    • F Offline
                      faust07
                      Hi, ecati,
                      Sorry, I used a test version for the connect example file.
                      Anton is working on release version 1.0.0 - which soon comes out.
                        SynSuka3D
                        Bonjour,
                        Je voudrais lire la vitesse D'un corps sur l'axe Y interne,no axe Y mondiale !!!
                        J'ai essayé get_velocity...
                        set_var("speed_Y",????)
                        Hello,
                        I would like to read the speed of a body on the internal Y-axis, no Y-axis world!
                        I tried: get_velocity...
                          Anton_S
                          Hello, Nicolas,
                          To get local velocity, along the body's Y-axis, you got to transform the global velocity relative to the body first, then get the Y component:
                          loc_vel = this.get_velocity.transform(this.get_normal_matrix.inverse)
                          vy = loc_vel.y
                          Regards,
                          Anton
                            Anton_S
                            Faust, I will ckeck out that cloth thingy soon.
                            • F Offline
                              faust07
                              Hi, Anton,
                              first test of a (cloth-) mesh with your MSPhysics API self connect script.
                              Unfortunately, each node joins only one rod. What am I doing wrong?
                              Connect_test_01.skp
                                Anton_S
                                Okay, faust.
                                Your script for connecting bodies attempts to connnect multiple bodies to the same joint. That's how it is in the user interface of MSPhysics, but behind the scenes a new joint instance is added for each constraint. So here is the script to have:
                                onTick {
                                  if frame == 1
                                    this.touching_bodies(true).each { |body|
                                      next if body.group.name != 'capsule'
                                      joint = MSPhysics;;BallAndSocket.new(this.world, this, this.get_matrix, this.group)
                                      joint.connect(body)
                                Paste it into one knot, and assign it to all knots, using the Assign Script to All With Name button.
                                That said, this is a very inefficient way of creating cloth, not to mention that you also have to create faces and then reposition vertices and map the UVs of textures (if any).
                                I already got my own, more efficient, version of cloth working, like 3 years ago. But it's not perfect. Here is the demo updated and refined for the current version of MSPhysics:
                                  cristyan
                                  Hello ! There is a script or another way that maintains the same distance between objects attached on CurvySlider , as a rollercoaster ? Thank you !
                                  • F Offline
                                    faust07
                                    Thanks, Anton,
                                    Your code works perfectly. For genuine cloth simulation this is, of course, too cumbersome. For me, it is a good practice to learn a little bit of good script again. In addition, the example shows the almost unlimited possibilities of MSPhysics.
                                    and this happens after 1.800 frames
                                      Anton_S
                                      Oops, the get_normal_matrix should be normal_matrix
                                      Also, to quote other people, use the double-quote button or put them in quote tags surrounded with square brackets. And posting the whole video on the error isn't necessary either. Just post a message that is reported.
                                        SynSuka3D
                                        CODE: SELECT ALL
                                        vy = loc_vel.y
                                        Regards,
                                        Anton
                                        problem!!!!!!
                                        • ecatiE Offline
                                          ecati
                                          This gears is not spinning properly. What would be the reason?
                                          dişli.skp
                                          • ecatiE Offline
                                            ecati
                                            Hi, Anton
                                            Will you take a look at this file at a time when you are not busy?
                                            makine.skp
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 46
                                            • 47
                                            • 16 / 47
