    Thick lines on walls - can't push/pull
    6 Posts 3 Posters 982 Views 3 Watching
    • I
      Inkyj
      Hi All, I'm brand new to Sketchup - I just started using it today. I've got some tutorials up and they've been helping, but I hit a snag that I can't find the answer to online.
      I'm working on layout the basement of my new house and i have all of the dimensions correct, but I can't push/pull the outside wall. Actually, I can't even select the outside wall as an interactive area. I believe it's got something to do with how I made it. I've got 2 sets of thick lines as the outside walls. They're the foundation walls so I liked that they were thicker than the rest, but I can't move them.
      I can't figure out what I did wrong, or what to do to fix it. I've attached a screenshot.
      Any help would be greatly appreciated!
        The big help will be to post the file "skp" (Save as "format V6" πŸ˜‰
        • I
          Inkyj
          attached skp file (v6)
          basement.skp
            Draw over a few more edges, making faces form, until there are no thick edges remaining.
            Delete any dividing edges you don't want.
            The faces should then PushPull as you hope...
            • I
              Inkyj
              redrawing the lines worked perfectly, thanks!
                For clean walls use Fredo Tool for see the false segments! (Mark Vertices)
                So erase the 3 false long segments and redraw them
                Then Make face (with the 2 "red lines")
                Then Extrude by Push Pull!
                Et voilΓ ! πŸ˜„
                Ps Kill the Guide points! πŸ˜‰
