    3D Truss Models
    1.5k Posts 31 Posters 869.7k Views 30 Watching
    • medeekM Offline
      medeek
      I've been giving some though to the soffit and fascia and I realized that in many cases the design may call for a closed soffit:
      http://design.medeek.com/resources/images/truss_su205_800.jpg
      https://s-media-cache-ak0.pinimg.com/originals/96/f9/b2/96f9b2ade22b6d526a7f1facc3bc8403.jpg
      I've seen soffits constructed with plywood and also metal (aluminum, vented).
      Also the fascia I am creating currently should be more properly labeled the sub-fascia since in many cases the true fascia board is a thinner 5/4 or 1x material. If metal is used then the sub-fascia is covered over with a fascia cover:
      http://www.trimbender.com/image/data/stories/gable.jpg
      http://woodshms.com/wp/wp-content/uploads/2014/11/Eaves-Detail.png
      Then of course we get into the whole boxed soffit at the corners:
      http://daveosborne.com/dave/projects/images/soffits.gif
      I would like to get some input in what you would like to see with closed soffits and fascia. I am thinking it might be useful to have a completely separate section in the global settings that deals specifically with closed soffits, fascia and corner treatment (ie. boxed corners vs. non-boxed)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        The most typical corner treatment I usually see locally is the following two methods:
        https://lh5.googleusercontent.com/-m1cZwre0NN8/UyYUvfx-NxI/AAAAAAAAA34/gqkNLucrZ90/w634-h845-no/soffit-fascia+details+2.jpg
        http://farm6.static.flickr.com/5043/5216819204_a7659c1fc7.jpg
        The second one is called a soffit box.
        design.medeek.com
        • medeekM Offline
          medeek
          Medeek Truss vs. MS Physics:
          http://design.medeek.com/resources/images/truss_su207_800.jpg
          Pretty clear the house didn't have a chance.
          I'm actually very impressed with the collision detection of MS Physics, an amazing extension.
          design.medeek.com
            Excellent disaster if we can say that! 🤓
            • medeekM Offline
              medeek
              I've been reviewing my Todo list lately and it really hasn't shrunk much, if anything it has grown a bit as I've added some new features in the last month and more catching up needs to be done with various truss types.
              I only work on this project part time and on the weekends as much as possible, so my progress since September of 2016 has been quite slow (took a new job with the City of Ocean Shores).
              Currently the Truss Plugin has seen the most development http://design.medeek.com/resources/pluginchangelog.html
              but I am also spread between the other separate plugins as well:
              Medeek Wall Plugin
              Medeek Structural Plugin
              Medeek Foundation Plugin
              Medeek Deck Plugin
              The structural and wall plugins will be just as complex and involved as the Truss Plugin and will require a couple years of my full time attention to get where they need to go.
              When I step back and look at everything I want to accomplish there is just no way, given my current situation, that I can achieve it. It would be nice to also be able to hire some help in knocking out some of the coding, realistically there is only so many hours in a day and only so much one person can do.
              I would really like to work full time on all of this as I see it has some serious potential and I'm also very excited about it but my previous attempt at using KickStarter to raise some working capital did not amount to much.
              I was watching Shark Tank last night and I was thinking would this type of business even have a chance in that setting? Anyhow, I am open to any ideas you might have in how to really blow this thing up and get it going.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.8.7 - 03.26.2017
                • Added energy/raised heels for double howe truss (3 variant: wedge, slider and vertical w/ strut).
                • Metal plate connectors now enabled for double howe trusses.
                http://design.medeek.com/resources/images/truss_su208_800.jpg
                Back to updating all the truss types with metal plates, raised heels and all other advanced options.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Recently I've had a couple requests for bobtail/stub end trusses.
                  http://www.perrantrusses.co.uk/images/bobtail_studend.jpg
                  When specifying how to truncate the truss, what lengths are typically used to control the location of the stub end(s)?
                  1.) Stub or heel height.
                  2.) Nominal span minus stub length
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Then of course to further complicate matters there is the double bobtail truss which is really nothing more than a raised heel truss with unequal heel heights
                    So rather than add in a completely new category of trusses I suppose I could just allow the user to specify a heel height for both the left and right side of the common truss. Currently the first menu has the option for a raised heel which is then applied to both sides of the truss. I think I could just update to be:
                    Raised Heel Left: YES/NO "Defaults to NO"
                    Height Height Left (in.): "Defaults to 12" if no user entry"
                    Raised Heel Right: YES/NO "Defaults to NO"
                    Heel Height Right (in.): "Defaults to SAME AS LEFT"
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Quite a number of requests this month for the flat truss, looks like I need to re-focus my priorities again.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Woke up early this morning and I began to work on extending the recent polygon tool (in the foundation plugin) to the floor joist module in the truss plugin. There are some differences but the principles and methods are nearly the same.
                        It just occurred to me that when sections of floor joists are the same (ie. L-shaped floor) it would be useful to have joists that are the same geometrically (length) all use the same component definition so that they could all be edited at once. This same concept would also be useful for the slab reinforcement. I plan on making this change to both plugins so that editing after the fact is facilitated as much as possible.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.8.8 - 04.28.2017
                          • Added energy/raised heels for mod fan truss (3 variant: wedge, slider and vertical w/ strut).
                          • Metal plate connectors now enabled for mod fan trusses.
                          http://design.medeek.com/resources/images/truss_su209_800.jpg
                          design.medeek.com
                          • facerF Offline
                            facer
                            Chinese users will love this version 😄
                            • pbacotP Offline
                              Looks wonderful!
                              • medeekM Offline
                                medeek
                                Version 1.8.9 - 05.01.2017
                                • Added energy/raised heels for triple fink truss (3 variant: wedge, slider and vertical w/ strut).
                                • Metal plate connectors now enabled for triple fink trusses.
                                http://design.medeek.com/resources/images/truss_su215_800.jpg
                                design.medeek.com
                                • jujuJ Offline
                                  juju
                                  What are the chances of you doing a version of this that does steel trusses? Not really useful for residential, but for industrial / commercial it would be useful.
                                  • pbacotP Offline
                                    While I myself most likely would not model rebar or even studs, the quick generation of a visually complete house model (no innards) is very desirable and this last house model looks great. Just that visual shell would be my preference. Emphasis on exterior views, and possibly a foundation model that can be viewed by the design and construction team. Maybe some ability for some interior shots, sun study, fly-through, or top-down (Minus roof) view of rooms. Still the framing is very impressive and looks wonderful!
                                    • pbacotP Offline
                                      I assume standard finishes are included in the plugins? You might add standard trim such as dimensional corner trim frieze boards and water tables. Just what's needed for a start-- the user can model special trim for themselves.
                                      • medeekM Offline
                                        medeek
                                        So many possibilities and so little time.
                                        I've now extended my list of plugins that I would like to create or am currently creating to:
                                        1.) Truss Plugin (roofs and floors)
                                        2.) Foundation Plugin (stem, sog, slab, spread ftg.)
                                        3.) Wall Plugin (stud walls)
                                        4.) Stairway Plugin (wood, concrete and steel stairways)
                                        5.) Structural Plugin (calculation of beams, footings, posts, shearwalls etc...)
                                        6.) Reinforced Concrete Plugin (RC columns, beams, retaining walls, piles, mat foundations, spread footings, etc...
                                        7.) Steel Framing Plugin (cold formed steel framing, steel wide flange beams and posts, steel trusses, NUCOR steel buildings)
                                        8.) Deck Plugin (residential wood decks, balconies, stairs, footings)
                                        9.) Window and Door Plugin (windows, doors, OH Doors, Garage Doors, interior doors)
                                        The window and door plugin will probably be part of the wall plugin, but I might also make it a separate standalone plugin if users want that.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Fun with Roofs - Episode 1
                                          My 9 year old son took one look at this roof and then said "Don't build this in Florida, you'll create a sink hole".
                                          http://design.medeek.com/resources/images/truss_su210_800.jpg
                                          http://design.medeek.com/resources/images/truss_su212_800.jpg
                                          http://design.medeek.com/resources/images/truss_su211_800.jpg
                                          http://design.medeek.com/resources/images/truss_su213_800.jpg
                                          http://design.medeek.com/resources/images/truss_su214_800.jpg
                                          http://design.medeek.com/resources/images/truss_su216_800.jpg
                                          http://design.medeek.com/resources/images/truss_su217_800.jpg
                                          http://design.medeek.com/resources/images/truss_su218_800.jpg
                                          View model here:
                                          3D Warehouse
                                          (3dwarehouse.sketchup.com)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I'm trying to figure out the correct way to frame the stairwell as it joins up with the floor diaphragm above.
                                            http://design.medeek.com/resources/images/truss_su220_800.jpg
                                            It's hard to show exactly what I mean with sectional views, the best thing is to view the 3D model and you will see what I am talking about.
                                            3D Warehouse
                                            I am working on the polygon and hole tool for I-Joist and Solid Sawn floors. When you actually frame out this opening would you just use rimboard around the perimeter as I have shown?
                                            design.medeek.com
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 74
                                            • 75
                                            • 44 / 75
