    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • facerF
      facer
      Midgard - Three Level House
      Sketch Plan (SK) Study of Floor - Roof Truss Options
      Using "Medeek plugin" to quickly access Floor - Truss Options
      Excellent addition to the "toolbox" of plugins
      Ray Facer Architect
      Melbourne Australia
      01Floor Truss Options - using Medeek Truss 02
      • pbacotP
        Fine example of use in unusual construction
        • jujuJ
          juju
          @medeek said:
          Tomorrow is my birthday.
          Happy CAKE DAY! nom nom nom πŸŽ‰
          Here you go, WIP model for standard details...
          Julian Smith, Professional Senior Architectural Technologist. Primary use of Medeek Truss plugin is the expedited creation of roof construction (trusses, rafters, etc.).
          • medeekM
            medeek
            Thank-you for the examples posted. I appreciate the continued support of the development of this plugin. I only wish I had more time to devote to it but my current job has me occupied most of the week and weekends can be tough with competing interests.
            Nathaniel P. Wilkerson PE
            Medeek Engineering Inc
            design.medeek.com
            • medeekM
              medeek
              I've been giving some though to the soffit and fascia and I realized that in many cases the design may call for a closed soffit:
              http://design.medeek.com/resources/images/truss_su205_800.jpg
              I've seen soffits constructed with plywood and also metal (aluminum, vented).
              Also the fascia I am creating currently should be more properly labeled the sub-fascia since in many cases the true fascia board is a thinner 5/4 or 1x material. If metal is used then the sub-fascia is covered over with a fascia cover:
              [img]
              http://www.arteroofing.com/include/get.php?nodeid=98[/img]
              design.medeek.com
              • medeekM
                medeek
                https://s-media-cache-ak0.pinimg.com/originals/96/f9/b2/96f9b2ade22b6d526a7f1facc3bc8403.jpg
                http://www.trimbender.com/image/data/stories/gable.jpg
                http://woodshms.com/wp/wp-content/uploads/2014/11/Eaves-Detail.png
                Then of course we get into the whole boxed soffit at the corners:
                http://daveosborne.com/dave/projects/images/soffits.gif
                I would like to get some input in what you would like to see with closed soffits and fascia. I am thinking it might be useful to have a completely separate section in the global settings that deals specifically with closed soffits, fascia and corner treatment (ie. boxed corners vs. non-boxed)
                design.medeek.com
                • medeekM
                  medeek
                  The most typical corner treatment I usually see locally is the following two methods:
                  https://lh5.googleusercontent.com/-m1cZwre0NN8/UyYUvfx-NxI/AAAAAAAAA34/gqkNLucrZ90/w634-h845-no/soffit-fascia+details+2.jpg
                  http://farm6.static.flickr.com/5043/5216819204_a7659c1fc7.jpg
                  The second one is called a soffit box.
                  design.medeek.com
                  • medeekM
                    medeek
                    Medeek Truss vs. MS Physics:
                    http://design.medeek.com/resources/images/truss_su207_800.jpg
                    Pretty clear the house didn't have a chance.
                    I'm actually very impressed with the collision detection of MS Physics, an amazing extension.
                    design.medeek.com
                      Excellent disaster if we can say that! πŸ€“
                      • medeekM
                        medeek
                        I've been reviewing my Todo list lately and it really hasn't shrunk much, if anything it has grown a bit as I've added some new features in the last month and more catching up needs to be done with various truss types.
                        I only work on this project part time and on the weekends as much as possible, so my progress since September of 2016 has been quite slow (took a new job with the City of Ocean Shores).
                        Currently the Truss Plugin has seen the most development http://design.medeek.com/resources/pluginchangelog.html
                        but I am also spread between the other separate plugins as well:
                        Medeek Wall Plugin
                        Medeek Structural Plugin
                        Medeek Foundation Plugin
                        Medeek Deck Plugin
                        The structural and wall plugins will be just as complex and involved as the Truss Plugin and will require a couple years of my full time attention to get where they need to go.
                        When I step back and look at everything I want to accomplish there is just no way, given my current situation, that I can achieve it. It would be nice to also be able to hire some help in knocking out some of the coding, realistically there is only so many hours in a day and only so much one person can do.
                        I would really like to work full time on all of this as I see it has some serious potential and I'm also very excited about it but my previous attempt at using KickStarter to raise some working capital did not amount to much.
                        I was watching Shark Tank last night and I was thinking would this type of business even have a chance in that setting? Anyhow, I am open to any ideas you might have in how to really blow this thing up and get it going.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.8.7 - 03.26.2017
                          • Added energy/raised heels for double howe truss (3 variant: wedge, slider and vertical w/ strut).
                          • Metal plate connectors now enabled for double howe trusses.
                          http://design.medeek.com/resources/images/truss_su208_800.jpg
                          Back to updating all the truss types with metal plates, raised heels and all other advanced options.
                          design.medeek.com
                          • medeekM
                            medeek
                            Recently I've had a couple requests for bobtail/stub end trusses.
                            http://www.perrantrusses.co.uk/images/bobtail_studend.jpg
                            When specifying how to truncate the truss, what lengths are typically used to control the location of the stub end(s)?
                            1.) Stub or heel height.
                            2.) Nominal span minus stub length
                            design.medeek.com
                            • medeekM
                              medeek
                              Then of course to further complicate matters there is the double bobtail truss which is really nothing more than a raised heel truss with unequal heel heights
                              So rather than add in a completely new category of trusses I suppose I could just allow the user to specify a heel height for both the left and right side of the common truss. Currently the first menu has the option for a raised heel which is then applied to both sides of the truss. I think I could just update to be:
                              Raised Heel Left: YES/NO "Defaults to NO"
                              Height Height Left (in.): "Defaults to 12" if no user entry"
                              Raised Heel Right: YES/NO "Defaults to NO"
                              Heel Height Right (in.): "Defaults to SAME AS LEFT"
                              design.medeek.com
                              • medeekM
                                medeek
                                Quite a number of requests this month for the flat truss, looks like I need to re-focus my priorities again.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Woke up early this morning and I began to work on extending the recent polygon tool (in the foundation plugin) to the floor joist module in the truss plugin. There are some differences but the principles and methods are nearly the same.
                                  It just occurred to me that when sections of floor joists are the same (ie. L-shaped floor) it would be useful to have joists that are the same geometrically (length) all use the same component definition so that they could all be edited at once. This same concept would also be useful for the slab reinforcement. I plan on making this change to both plugins so that editing after the fact is facilitated as much as possible.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.8.8 - 04.28.2017
                                    • Added energy/raised heels for mod fan truss (3 variant: wedge, slider and vertical w/ strut).
                                    • Metal plate connectors now enabled for mod fan trusses.
                                    http://design.medeek.com/resources/images/truss_su209_800.jpg
                                    design.medeek.com
                                    • facerF
                                      facer
                                      Chinese users will love this version πŸ˜„
                                      • pbacotP
                                        Looks wonderful!
                                        • medeekM
                                          medeek
                                          Version 1.8.9 - 05.01.2017
                                          • Added energy/raised heels for triple fink truss (3 variant: wedge, slider and vertical w/ strut).
                                          • Metal plate connectors now enabled for triple fink trusses.
                                          http://design.medeek.com/resources/images/truss_su215_800.jpg
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            What are the chances of you doing a version of this that does steel trusses? Not really useful for residential, but for industrial / commercial it would be useful.
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 76
                                            • 77
                                            • 34 / 77
