    My furniture
    139 Posts 24 Posters 34.5k Views 24 Watching
    • ginchiusG Offline
      ginchius
      @whaat said:
      This is amazing stuff! Absolutely amazing work all around! I wish I would have noticed this thread sooner. Following it now...πŸ˜„...
      @bryan k said:
      Probably the best 3D furniture I have seen anywhere by anyone. πŸ‘
      Thanks πŸ’š
      You can find my models at http://sketchucation.com/shop/models
      • ginchiusG Offline
        ginchius
        Small living room
        • Bryan KB Offline
          Gorgeous!
          Say, is that Bigfoot on TV?
          • ginchiusG Offline
            ginchius
            Nope, it's not Bigfoot πŸ˜„
            • Bryan KB Offline
              πŸ˜† Thanks!
              • alvisA Offline
                alvis
                Bravo
                • jo-keJ Offline
                  jo-ke
                  Hey I know that sofa πŸ˜‰ Giorgetti!
                  nice
                  http://www.zz7.de
                  • ginchiusG Offline
                    ginchius
                    @jo-ke said:
                    Hey I know that sofa πŸ˜‰ Giorgetti!...
                    Yes, it's the same sofa πŸ’š
                    • ginchiusG Offline
                      ginchius
                      Teen's bedroom armchair and two seat sofa
                        You have the exact measures when you start your model or it's by eyes?
                        • ginchiusG Offline
                          ginchius
                          @pilou said:
                          :fro:
                          At the beginning it was a normal sized armchair, later I decided to resize it according to this little man (attached image). H860 x W600/1285 x D835 mm
                          • I Offline
                            infernovak
                            Amazing models man! Really cool! I've been drooling over them
                            Could you share some tips on how you create the piping or seams in your models? Perhaps some images or a video, before you smoothen it out?
                            • ginchiusG Offline
                              ginchius
                              Thanks,
                              All seams/pipes are added after smoothig with this plugin "Pipe along path"
                              Just mark the lines/edges where you want to add the pipes (make sure that selected lines/edges are not softened/smoothed) or make a "road" for piping with "SketchUV: path select tool"iping with "SketchUV: path select tool"
                              • I Offline
                                infernovak
                                That's a wonderful way to do it. Will try it out!
                                I also noticed in your models that there is a clear and distinct dark line when 2 edges of the fabric meet. It looks really clean!
                                How you achieve that effect? Is it in the geometry or done using a plug-in after smoothing?
                                • ginchiusG Offline
                                  ginchius
                                  If you are talking about these lines (see attached image with red marks) so it's a tubes/seams.
                                  • I Offline
                                    infernovak
                                    I was referring to your Madison sofa model, labeled as 1,2,3
                                    1 - The small, horizontal joint in the armrest
                                    2 - Similar joint running along the arm
                                    3 - The cuts in the tufting part
                                    • ginchiusG Offline
                                      ginchius
                                      1 and 2 - pipes
                                      • pbacotP Offline
                                        Thanks for the details!
                                        • I Offline
                                          infernovak
                                          Thanks for sharing these tips! They are amazing πŸ˜„
                                          You should consider doing your own Youtube channel for 3d Modelling in Sketchup. Trust me, a lot of beginners like me would look up to your work for inspiration!
                                          • I Offline
                                            infernovak
                                            @ginchius said:
                                            1 and 2 - pipes
                                            In #3, how were you able to fuse the piping into the fabric? I am trying to test how it happens but it destroys the model.
                                            Here is what I am trying:
                                            1. Select path, add pipe
                                            2. explode pipe out of group, so that it merges with model
                                            3. Smooth and subdivide
                                            What am i doing wrong here?
                                            • 7 / 7
