    My furniture
    139 Posts 24 Posters 41.4k Views 24 Watching
    • alvisA
      alvis
      Well done.
      • ginchiusG
        ginchius
        Thank you all
        You can find my models at http://sketchucation.com/shop/models
        • W
          Whaat
          This is amazing stuff! Absolutely amazing work all around! I wish I would have noticed this thread sooner. Following it now...πŸ˜„
          Also, please check your inbox for a PM from me.
          • Bryan KB
            Probably the best 3D furniture I have seen anywhere by anyone. πŸ‘
            • ginchiusG
              ginchius
              @whaat said:
              This is amazing stuff! Absolutely amazing work all around! I wish I would have noticed this thread sooner. Following it now...πŸ˜„...
              Thanks πŸ’š
              • ginchiusG
                ginchius
                Small living room
                • Bryan KB
                  Gorgeous!
                  Say, is that Bigfoot on TV?
                  • ginchiusG
                    ginchius
                    Nope, it's not Bigfoot πŸ˜„
                    • Bryan KB
                      πŸ˜† Thanks!
                      • alvisA
                        alvis
                        Bravo
                        • jo-keJ
                          jo-ke
                          Hey I know that sofa πŸ˜‰ Giorgetti!
                          nice
                          http://www.zz7.de
                          • ginchiusG
                            ginchius
                            @jo-ke said:
                            Hey I know that sofa πŸ˜‰ Giorgetti!...
                            Yes, it's the same sofa πŸ’š
                            • ginchiusG
                              ginchius
                              Teen's bedroom armchair and two seat sofa
                                You have the exact measures when you start your model or it's by eyes?
                                • ginchiusG
                                  ginchius
                                  @pilou said:
                                  :fro:
                                  At the beginning it was a normal sized armchair, later I decided to resize it according to this little man (attached image). H860 x W600/1285 x D835 mm
                                  • I
                                    infernovak
                                    Amazing models man! Really cool! I've been drooling over them
                                    Could you share some tips on how you create the piping or seams in your models? Perhaps some images or a video, before you smoothen it out?
                                    • ginchiusG
                                      ginchius
                                      Thanks,
                                      All seams/pipes are added after smoothig with this plugin "Pipe along path"
                                      Just mark the lines/edges where you want to add the pipes (make sure that selected lines/edges are not softened/smoothed) or make a "road" for piping with "SketchUV: path select tool"iping with "SketchUV: path select tool"
                                      • I
                                        infernovak
                                        That's a wonderful way to do it. Will try it out!
                                        I also noticed in your models that there is a clear and distinct dark line when 2 edges of the fabric meet. It looks really clean!
                                        How you achieve that effect? Is it in the geometry or done using a plug-in after smoothing?
                                        • ginchiusG
                                          ginchius
                                          If you are talking about these lines (see attached image with red marks) so it's a tubes/seams.
                                          • I
                                            infernovak
                                            I was referring to your Madison sofa model, labeled as 1,2,3
                                            1 - The small, horizontal joint in the armrest
                                            2 - Similar joint running along the arm
                                            3 - The cuts in the tufting part
                                            • 6 / 7
