    My furniture
    139 Posts 24 Posters 34.4k Views 24 Watching
    • Bryan KB Offline
      Probably the best 3D furniture I have seen anywhere by anyone. πŸ‘
      • ginchiusG Offline
        ginchius
        @whaat said:
        This is amazing stuff! Absolutely amazing work all around! I wish I would have noticed this thread sooner. Following it now...πŸ˜„...
        Thanks πŸ’š
        You can find my models at http://sketchucation.com/shop/models
        • ginchiusG Offline
          ginchius
          Small living room
          • Bryan KB Offline
            Gorgeous!
            Say, is that Bigfoot on TV?
            • ginchiusG Offline
              ginchius
              Nope, it's not Bigfoot πŸ˜„
              • Bryan KB Offline
                πŸ˜† Thanks!
                • alvisA Offline
                  alvis
                  Bravo
                  • jo-keJ Offline
                    jo-ke
                    Hey I know that sofa πŸ˜‰ Giorgetti!
                    nice
                    http://www.zz7.de
                    • ginchiusG Offline
                      ginchius
                      @jo-ke said:
                      Hey I know that sofa πŸ˜‰ Giorgetti!...
                      Yes, it's the same sofa πŸ’š
                      • ginchiusG Offline
                        ginchius
                        Teen's bedroom armchair and two seat sofa
                          You have the exact measures when you start your model or it's by eyes?
                          • ginchiusG Offline
                            ginchius
                            @pilou said:
                            :fro:
                            At the beginning it was a normal sized armchair, later I decided to resize it according to this little man (attached image). H860 x W600/1285 x D835 mm
                            • I Offline
                              infernovak
                              Amazing models man! Really cool! I've been drooling over them
                              Could you share some tips on how you create the piping or seams in your models? Perhaps some images or a video, before you smoothen it out?
                              • ginchiusG Offline
                                ginchius
                                Thanks,
                                All seams/pipes are added after smoothig with this plugin "Pipe along path"
                                Just mark the lines/edges where you want to add the pipes (make sure that selected lines/edges are not softened/smoothed) or make a "road" for piping with "SketchUV: path select tool"iping with "SketchUV: path select tool"
                                • I Offline
                                  infernovak
                                  That's a wonderful way to do it. Will try it out!
                                  I also noticed in your models that there is a clear and distinct dark line when 2 edges of the fabric meet. It looks really clean!
                                  How you achieve that effect? Is it in the geometry or done using a plug-in after smoothing?
                                  • ginchiusG Offline
                                    ginchius
                                    If you are talking about these lines (see attached image with red marks) so it's a tubes/seams.
                                    • I Offline
                                      infernovak
                                      I was referring to your Madison sofa model, labeled as 1,2,3
                                      1 - The small, horizontal joint in the armrest
                                      2 - Similar joint running along the arm
                                      3 - The cuts in the tufting part
                                      • ginchiusG Offline
                                        ginchius
                                        1 and 2 - pipes
                                        • pbacotP Offline
                                          Thanks for the details!
                                          • I Offline
                                            infernovak
                                            Thanks for sharing these tips! They are amazing πŸ˜„
                                            You should consider doing your own Youtube channel for 3d Modelling in Sketchup. Trust me, a lot of beginners like me would look up to your work for inspiration!
                                            • 6 / 7
