    V-Ray 3 for SketchUp released
    renderpluginsextensions
    22 Posts 13 Posters 4.8k Views 13 Watching
      Philw
      Will there be or are there some new tutorial to help get up to speed?
      Will the help files be expanded as well?
      I've been using the beta version and a lot of in depth information was missing on the new layout and some of the new features.
      Congrats to the Chaos team, and thanks you for this new version,
      cant wait to get my hands on it.
      • sketch3d.deS Offline
        sketch3d.de
        Free Webinar: V-Ray 3.5 for SketchUp
        Agenda: new UI, Material Library, Denoiser, Section Cuts, Grass etc.
        Date: 21.03.2017
          konstantin_chaos
          @solo said:
          So, say I have 3 x 1080 ti's will it use all 3?
          Hi solo,
          V-Ray will automatically use all the cards(GPUs) available.
          In case you need to limit the utilization you can use the following interface:
          Extensions > V-Ray > Tools > (GPU Device Selection)
          It lets you un-check any card/s that you don't want used for rendering.
          Regards,
          Konstantin
            bittybong
            Ive just updated to version 3 on sku2016. My early impression is that the workflow speed has dramatically increased due to the ability to make quick tweaks to lighting and materials through the new slick ui as well as quality settings. Very promising.
            Previously my 6 core 3930k processor has made good render times on version 2. All 12 threads at full pelt.Im intigued to experiment with gpu for rt and production renders but question is, how many gpu cuda cores will it take to out strip my processor?? After all its either cpu or gpu choice. Could be an expensive mistake buying 2x gtx1070's or the new titanx pascal?? We need comparitive results from chaos using different engines with different hardware.
            My gtx 780 is set up in vray with 2304 cuda cores but as yet is not giving me accurate textures..a bug? I need to know whether to upgrade the gpu or cpu count. Hopefully we will get answers soon..cheers
            • V Offline
              valerostudio
              Take note that this is still using the 3.4 engine and we do not have the full interactive production engine that is currently in 3.5 for Max. Meaning - that there are some missing features in GPU as of right now that we need to wait for 3.5 for.
              Here's the release notes for 3.5 Max just as an idea of what is to come potenitally.
              https://docs.chaosgroup.com/display/VRAY3MAX/3.50.01
                That UI is very slick.
                Way more approachable.
                • JQLJ Offline
                  JQL
                  Guys, does anyone know if Vray for Sketchup 3 supports Substance's .sbsar? and what about the vray bevel procedural?
                  www.casca.pt
                  Visit us on facebook!
                  • Collage ArchitectureC Offline
                    Bevel edges is very easy, use edge texture in bump slot or apply a bump material to object with edge texture.You could tweak the radius via assest editor.
                    PBR mat seems not supported in V-Ray right now. They will have glossy fresnel in the future update.So I don't think anything will be done, people have to convert SBS manually to Vray Mtl,just such a pain.
                    Best
                    I love Sketchup
                    • JQLJ Offline
                      JQL
                      Best
                      Thanks for the info.
                      But I was under the impression vray for max had substance support. Am I wrong?
                      www.casca.pt
                        Best
                        Some people wrote Max plugins to convert PBR material to Vray mtl. But I don't think Vray can achieve exactly same result as Substance painter.
                        δ»Žζˆ‘ηš„ iPhone ε‘ι€οΌŒδ½Ώη”¨ Tapatalk
                        I love Sketchup
                        • 2 / 2
