    Plugin request - show/hide for scene dialog
    extensions
    12 Posts 7 Posters 3.5k Views 7 Watching
      monkers
      Hi Everyone.
      I find myself having to go through each scene select the objects, hide, then update the scene. For 20 odd scenes with a couple of objects this gets annoying. Before you tell me to put them on layers and use JF Add Layer. Sometimes that just doesn't work with what I need.
      If we could have similar dialog when you can select "hide in all scenes except current" that would be super handy. Even better would be a dialog with a list of scenes each one would have a check box beside it. that way you could custom show/hide in each scene. Something like this for layers would also be a nice feature to add into JF add layer experience.
      Is there anything similar out there?
      Cheers.
      M
      • HornOxxH
        HornOxx
        @monkers said:
        ... something like this for layers would also be a nice feature ...
        or to add a thought only: a right click scene tab context option like "pick scene properties" for example...
        never trust a skinny cook
        • jujuJ
          juju
          DISCLAIMER: Without you completing your profile, we cannot tell which version of SketchUp you're using or which platform you work on.
          You may be interested in VisMap, see if it works for you...
          404 Not Found
          (sketchucation.com)
          but also read here...
          404 Not Found
          (sketchucation.com)
          and then here...
          404 Not Found
          (sketchucation.com)
          You may have to repackage it into a .RBZ file if you're on a recent version of SketchUp.
          • srxS
            srx
            Try TOLIAS plugin for hiding a layer in all scenes.
            www.saurus.rs
            • jujuJ
              juju
              link? I can't find it in SketchUcation PluginStore or on Extension Warehouse.
              • filibisF
                filibis
                If i understood your intention correctly, then you can do it via Scene section in Default Tray.
                Follow these steps:
                1- Hide geometry or change whatever properties you want to update in your model.
                2- Select your scenes from Scene section in Default Tray
                3- Right Click one of the selected scenes > Choose Update Scenes
                4- Tick properties you want to update.
                Update Scenes via Default Tray.
                • srxS
                  srx
                  Google is better search engine:
                  http://sketchucation.com/forums/viewtopic.php?t=66243
                  www.saurus.rs
                  • jujuJ
                    juju
                    Oh, I see.
                    That brings us to the next question, why isn't this in the PluginStore?
                    • pbacotP
                      I don't see that these respond to OP's request. OP doesn't want to have to go to each scene and select each object to hide, choose hide, then save the scene. He wants to go to ONE scene and then choose an object and say: hide in all other scenes. He's not using layers for that. With the method he is using, one way is much faster and simpler. I don't know why he is using the hide method and not layers, but that's what he wants.
                        monkers
                        @sdmitch said:
                        Something like this?
                        YES! That looks awesome! Where can I find this plugin? I had a look through your blog but didn't see it.
                        • sdmitchS
                          sdmitch
                          No I never put it on the blog but I will send you a copy via Personal Message.
                          http://sdmitch.blogspot.com/
                          • sdmitchS
                            sdmitch
