    Movement Constraints
    6 Posts 5 Posters 8.2k Views 5 Watching
      DFB
      Is there a way to constrain component movement by one or more constraints? For example, I am designing a pantograph for my workshop:
      I would like to constrain the movements of the arms to pivot about their respective pivot points.Pantorouter.skp
      • gillesG Offline
        gilles
        Look at this:
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56852
        And, please upload your model as V6 (save as/sketchup version V6).
          Anton_S
          Hello, Derwin Brown,
          Using MSPhysics, here is one way to attach constraints to it:
          Pantorouter.skp
          When you get MSPhysics installed and click the MSPhysics blue play button, you will have two controllers to control that thing.
          Regards,
          Anton
            DFB
            @gilles said:
            Look at this:
            Thank you for your reply. I have investigated the MSPhysics plugin (thanks to Anton_S) and it has help me with my design.
            Why do you want the model uploaded as V6? Is this a standard for model uploading?
            • Rich O BrienR Online
              Some members still use SketchUp 6 and up so to make sure files can be opened it is always a good idea to save in earlier versions.
              SketchUp 6 is the Escort MkI of the CAD world.
                πŸ˜‰
                panrouter_v6.skp
