    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.7k Views 172 Watching
    • chriC Offline
      chri
      @jakub89 said:
      I have a problem with gears using MSphysics. Is there any way how to fix it?
      hi jakub89
      Please, take a look at the following example.
      The study of this example may help you with the problem of collision with the group and the subgroup.
      Chri
      CREATION PIGNON 2 AVEC PLUGIN.skp
      • chriC Offline
        chri
        HI
        SPGears plugin
        • F Offline
          faust07
          After tests with the late discovered Cenvexify (Fredo6 - Fredo Tools) here some problems with the relatively large torus segments with the usual MSP user interface settings.
          Convexify_01.skp
          • I Offline
            Istvan N
            Hello Faust07. I copied the slices into a new model and it works well. Always try this solution in such cases.
            Convexify_02.skp
            • F Offline
              faust07
              Thanks again, Istvan. Good to know. It seems to be a similar problem as the frame export in MSP Replay in SUp 2017 using SUp 2016 models. The solution was to copy the content or to import the model into a new model.
              BTW, thanks for your shape loader extension! πŸ‘
              • F Offline
                faust07
                Hi Anton,
                during extensive physics calculations, MSPhysics reduces interim phases during image reproduction. Partially over 5 frames, the content remains the same. This can lead to pretty jerky videos. It would be helpful if this setting, at least for exporting the images in Replay, could be turned off?
                  delchrys
                  Hello all,
                  i'm new to msphysics and intermediate at sketchup 2016, and can't get my model to work the way i want.
                  Is there someone who can point me in the right direction???
                  I like to reproduce this type of device and then make it animate in sketchup.
                  https://www.youtube.com/watch?v=MO2Dy7PM7Gs
                  http://4.bp.blogspot.com/-4t0Ghm1M8VQ/Vh1EDse0mTI/AAAAAAAAAKo/Yo5RzwcT2xs/s1600/HU_1.png
                  For now i have made some parts already but i want to begin animating already, but can't get it to work.
                  Someone who wants to help.
                  I need the parts to be connected and when a cylinders move like a slider, the rest of the parts have to follow.
                  Kinde regards and thanks,
                  Bert.
                  (The Netherlands)
                  test upload.skp
                    Anton_S
                    Hello, Faust,
                    Even after copying, the issue still persists. Moving some split shapes toward the center, the original position where they fell through the mesh, made them fall through again. Hate to say that, but it's the bug of the physics engine that MSPhysics is using. Until the physics engine is updated, this is how it will remain and even for the upcoming version 1.0.0. To fix it, have the floor shape be a static box, or a static compound. Or just ensure that the objects don't fall at those places.
                    So, you export replay into images and some images remain undesirably the same for 5 consequent frames? Is that what it is? Could I have a test model? You could PM it to me if you want to.
                    Regards,
                    Anton
                    • F Offline
                      faust07
                      Hallo Anton. Thanks for your explanation.
                      Here is a picture sequence with the problem. It usually happens in fast motion sequences, as if MSPhysics tries to run the simulation in real time. For games and the like it is certainly useful, but for a video recording are missing some phases of some objects.
                      Unfortunately the model is currently under construction. I am trying to optimize and combine motion sequences and motion modes. If it works again, I can send it to you.
                      TestSequence.zip
                        Anton_S
                        Hello, Bert Broek,
                        Here is the hydraulic torque wrench with MSPhysics:
                        delchrys - hydraulic torque wrench.skp
                        The center of rotation might need some adjusting but it works as good as the model is.
                        Regards,
                        Anton
                          How to "past" the little box falling on the big box as sson as it touches it?
                            Anton_S
                            Pilou, do you mean, how to set the box static when the other box hits it?
                            If so, attach this script to the little box:
                            onTouch { |toucher, point, normal, force, speed|
                              this.static = true
                              this.set_velocity(0,0,0)
                              this.set_omega(0,0,0)
                            This should set the little box static whenever the falling box over it catches up.
                              For avoid this artificial bowling's corridors! πŸ˜„
                              http://sketchucation.com/forums/download/file.php?id=146225
                              Objective is make a stone wall : so a general vertical fall
                              Rotation 90Β°
                              Then another http://sketchucation.com/forums/download/file.php?id=146225
                                delchrys
                                @anton_s said:
                                Hello, Bert Broek,
                                [attachment=1:zw0fm2hr]<!-- ia1 -->delchrys - hydraulic torque wrench.skp<!-- ia1 -->[/attachment:zw0fm2hr]
                                Regards,
                                Anton
                                It's getting there but now i only need to get it to rotate around the small hole's center.
                                i've made another one with a dynamic component for you to see what i mean. Hope you can help me with it.
                                regads,
                                Bert
                                PROBEER NIEUWE ATORATOR.skp
                                  @ Anton yes that works fine but I have hundred of objects!
                                  I can't put one by one the script! πŸ˜„
                                  (multiple selection don't work for this case)
                                  and little problem! πŸ˜„
                                    Anton_S
                                    Hello, Bert,
                                    Could you be more clear about, which small hole's center it should rotate about?
                                    Is that what it should do now?
                                    I will soon make a video on how I am adding MSPhysics to it, so you know how it is done.
                                    Regards,
                                    Anton
                                      Anton_S
                                      Hi, Pilou,
                                      To assign same script to multiple objects, give them all the same name, assign script to one of them, and in the Properties tab of the UI click on the Assign Script to All with Same Name button.
                                      One way to reduce the offset, is by enabling the Continuous Collision in Simulation tab.
                                      Regards,
                                      Anton
                                        delchrys
                                        Sorry for not being very clear. The whole circular wrench part should rotate around the hole's center. I'll post a update tomorrow where I have added the hydraulic cylinder so you can see what I mean. Now I'm on my phone so can't post it now.
                                        I want the cylinder to push out and push the lever so that the wrench part rotates a bit. So from a linear motion to a rotating one. I'll update tomorrow, thanks for now.
                                          Anton_S
                                          Hello, Faust,
                                          I sent you a private message on this. Please check your inbox.
                                          Thanks,
                                          Anton
                                            Anton_S
                                            Bert, you can alternatively add labels to hole centers and then indicate which hole you're referring to by its name.
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 46
                                            • 47
                                            • 41 / 47
