    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
    • F Offline
      faust07
      After tests with the late discovered Cenvexify (Fredo6 - Fredo Tools) here some problems with the relatively large torus segments with the usual MSP user interface settings.
      Convexify_01.skp
      • I Offline
        Istvan N
        Hello Faust07. I copied the slices into a new model and it works well. Always try this solution in such cases.
        Convexify_02.skp
        • F Offline
          faust07
          Thanks again, Istvan. Good to know. It seems to be a similar problem as the frame export in MSP Replay in SUp 2017 using SUp 2016 models. The solution was to copy the content or to import the model into a new model.
          BTW, thanks for your shape loader extension! πŸ‘
          • F Offline
            faust07
            Hi Anton,
            during extensive physics calculations, MSPhysics reduces interim phases during image reproduction. Partially over 5 frames, the content remains the same. This can lead to pretty jerky videos. It would be helpful if this setting, at least for exporting the images in Replay, could be turned off?
              delchrys
              Hello all,
              i'm new to msphysics and intermediate at sketchup 2016, and can't get my model to work the way i want.
              Is there someone who can point me in the right direction???
              I like to reproduce this type of device and then make it animate in sketchup.
              https://www.youtube.com/watch?v=MO2Dy7PM7Gs
              http://4.bp.blogspot.com/-4t0Ghm1M8VQ/Vh1EDse0mTI/AAAAAAAAAKo/Yo5RzwcT2xs/s1600/HU_1.png
              For now i have made some parts already but i want to begin animating already, but can't get it to work.
              Someone who wants to help.
              I need the parts to be connected and when a cylinders move like a slider, the rest of the parts have to follow.
              Kinde regards and thanks,
              Bert.
              (The Netherlands)
              test upload.skp
                Anton_S
                Hello, Faust,
                Even after copying, the issue still persists. Moving some split shapes toward the center, the original position where they fell through the mesh, made them fall through again. Hate to say that, but it's the bug of the physics engine that MSPhysics is using. Until the physics engine is updated, this is how it will remain and even for the upcoming version 1.0.0. To fix it, have the floor shape be a static box, or a static compound. Or just ensure that the objects don't fall at those places.
                So, you export replay into images and some images remain undesirably the same for 5 consequent frames? Is that what it is? Could I have a test model? You could PM it to me if you want to.
                Regards,
                Anton
                • F Offline
                  faust07
                  Hallo Anton. Thanks for your explanation.
                  Here is a picture sequence with the problem. It usually happens in fast motion sequences, as if MSPhysics tries to run the simulation in real time. For games and the like it is certainly useful, but for a video recording are missing some phases of some objects.
                  Unfortunately the model is currently under construction. I am trying to optimize and combine motion sequences and motion modes. If it works again, I can send it to you.
                  TestSequence.zip
                    Anton_S
                    Hello, Bert Broek,
                    Here is the hydraulic torque wrench with MSPhysics:
                    delchrys - hydraulic torque wrench.skp
                    The center of rotation might need some adjusting but it works as good as the model is.
                    Regards,
                    Anton
                      How to "past" the little box falling on the big box as sson as it touches it?
                        Anton_S
                        Pilou, do you mean, how to set the box static when the other box hits it?
                        If so, attach this script to the little box:
                        onTouch { |toucher, point, normal, force, speed|
                          this.static = true
                          this.set_velocity(0,0,0)
                          this.set_omega(0,0,0)
                        This should set the little box static whenever the falling box over it catches up.
                          For avoid this artificial bowling's corridors! πŸ˜„
                          http://sketchucation.com/forums/download/file.php?id=146225
                          Objective is make a stone wall : so a general vertical fall
                          Rotation 90Β°
                          Then another http://sketchucation.com/forums/download/file.php?id=146225
                            delchrys
                            @anton_s said:
                            Hello, Bert Broek,
                            [attachment=1:zw0fm2hr]<!-- ia1 -->delchrys - hydraulic torque wrench.skp<!-- ia1 -->[/attachment:zw0fm2hr]
                            Regards,
                            Anton
                            It's getting there but now i only need to get it to rotate around the small hole's center.
                            i've made another one with a dynamic component for you to see what i mean. Hope you can help me with it.
                            regads,
                            Bert
                            PROBEER NIEUWE ATORATOR.skp
                              @ Anton yes that works fine but I have hundred of objects!
                              I can't put one by one the script! πŸ˜„
                              (multiple selection don't work for this case)
                              and little problem! πŸ˜„
                                Anton_S
                                Hello, Bert,
                                Could you be more clear about, which small hole's center it should rotate about?
                                Is that what it should do now?
                                I will soon make a video on how I am adding MSPhysics to it, so you know how it is done.
                                Regards,
                                Anton
                                  Anton_S
                                  Hi, Pilou,
                                  To assign same script to multiple objects, give them all the same name, assign script to one of them, and in the Properties tab of the UI click on the Assign Script to All with Same Name button.
                                  One way to reduce the offset, is by enabling the Continuous Collision in Simulation tab.
                                  Regards,
                                  Anton
                                    delchrys
                                    Sorry for not being very clear. The whole circular wrench part should rotate around the hole's center. I'll post a update tomorrow where I have added the hydraulic cylinder so you can see what I mean. Now I'm on my phone so can't post it now.
                                    I want the cylinder to push out and push the lever so that the wrench part rotates a bit. So from a linear motion to a rotating one. I'll update tomorrow, thanks for now.
                                      Anton_S
                                      Hello, Faust,
                                      I sent you a private message on this. Please check your inbox.
                                      Thanks,
                                      Anton
                                        Anton_S
                                        Bert, you can alternatively add labels to hole centers and then indicate which hole you're referring to by its name.
                                          delchrys
                                          So I made my model a bit more complete.
                                          So the red cylinder pushes out and pushes the yellow block.
                                          the yellow block makes the green part rotates around origin point.
                                          I have made a dynamic component that when you click on the yellow part it show the rotation and added a piston controlley for the cylinder.
                                          Hope someone can show me how you make it moving and maybe a step by step guide with it.
                                          new gatorator.skp
                                          • F Offline
                                            faust07
                                            First impressions of MSPv1.0.0_WIP6:
                                            Great new features and improvements!: Particle recording and export, Escape to stop
                                            exporting, Magnets, Joystick, OnTouch functions ... πŸ‘
                                            I've got my walker model to run. Although I thought first, I can not do it.
                                            The main problem was my inaccurate definition of "Material" in conjunction with "Mass
                                            Control". For example: rubber with a mass of 3 kg, wood with a mass of 10 kg etc.
                                            This worked in version 0.9.9 but after opening with v1.0.0 all former mass values
                                            were displayed in density and the bodies then behaved strangely...
                                            I have now changed all the MSP materials with deviating mass to "Custom" and reset the
                                            display of "by Density" to "by Mass".
                                            It would be good to know the dependence of the strength of the joints on the density
                                            / mass of the connected body parts. For the walking person, I have to adjust the
                                            triple weight for all parts of the body in order to reduce the wobbling and trembling
                                            to a tolerable level.
                                            An oscillation of previously 60 frames now appears to correspond to a value of 1.0.
                                            Does the oscillation refer to real time or simulation time?
                                            The start rotation direction of the joints changes sometimes? I guess the cause is at
                                            the oscillators starting point at -1.0. But that's ok.
                                            The improper phasing till persists:
                                            The elimination of movement phases of individual bodies is still present. This,
                                            however, seems to be due to the amount of transformed emitters (drops, splashes,
                                            etc.). Without the many emitters, the body movements of my "Little Richie Gear" (I as
                                            a boy with a lantern...) are smooth.
                                            What is the influence of setting "Kinematic" or "Dynamic" to the simulation? Where
                                            can I find the script overview?
                                            Right now, I'm just trying to figure out what the simplest method is to copy a
                                            complex MSPhysics conglomerate like a person (with Curvy Piston and scripts) and let
                                            them act independently.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 46
                                            • 47
                                            • 31 / 47
