    Layout Lists
    layout
    18 Posts 5 Posters 5.0k Views 5 Watching
    • C
      CMS 5PS
      And maybe my rtf file issue is really an openoffice issue. The formatting for numbered lists is frustrating there as well.
        Maybe it is an Open Office thing. I use LibreOffice and regularly make lists with tab separated columns. No problem with formatting.
        It might be that you'd have better luck if you insert your bullet glyph as a character instead of using the Bullets tool.
        • C
          CMS 5PS
          It's actually numbers that I am having the space issue with. I have just noticed that bullets have the same issue.
          I appreciate your help. I'll keep playing with it and maybe check out LibreOffice to see if I can make that a part of my process.
          • C
            CMS 5PS
            Just an update: I tried the rtf import from LibreOffice, and it works much better. Thanks!
              Excellent!
              • RichardR
                Richard
                I find it SO MUCH easier to just build lists in LayOut using an array of Text Boxes!
                BUILTBRAND.COM.AU
                • brettsichellodesignB
                  brettsichellodesign
                  Great drawing Richard! How did you do the drop shadows on trees and arrows?
                  • RichardR
                    Richard
                    Thanks mate, to add the shadows I dragged the PDF from LayOut into Indesign!
                    BUILTBRAND.COM.AU
                      Richard, I really like that look. Excellent job.
                      I don't know InDesign very well. How hard is it to create those shadows from the PDF?
                      • RichardR
                        Richard
                        Dave, so simple!!!! Indesign is really intuitive.
                        Export PDF from layout with layers enabled > in Indesign drag the PDF onto a page the same size as the original > turned off all tree layers for the flat background > copy the PDF > paste in place > turned off all the background layers > turn on tree level 1 > add drop shadow > copy PDF > paste in place > turn off tree level 1 > turn on tree level 2 > repeat from level 3. > Export PDF.
                        If I make any changes to the Layout plan, I just re-export the base PDF and refresh the link in Indesign.
                        BUILTBRAND.COM.AU
                          Very interesting. Thanks for the explanation. Are the circles created in LO or in SU?
                          • C
                            CMS 5PS
                            Beautiful drawing, Richard. I hope to be able to get to that point someday!
                            • RichardR
                              Richard
                              Everything is from LO other than the shadows Dave!
                              BUILTBRAND.COM.AU
                              • bmikeB
                                bmike
                                That looks great...
                                Couldn't you create the drop shadows in LO? Copy all the arrows to the side, shift them all, then force them behind the arrows, shade in a transparent color? Or use layers?
                                I know that they aren't as pretty and fuzzy, but with layers its pretty easy.
                                • RichardR
                                  Richard
                                  @bmike said:
                                  That looks great...
                                  [attachment=0:1d7spjwp]<!-- ia0 -->Screen Shot 2017-03-23 at 3.44.08 PM.png<!-- ia0 -->[/attachment:1d7spjwp]
                                  For sure mate, I tried this in the past with floor plans - though the hard shadow is a bit harsh, plus it doesn't represent so well as the shadow cant be set as multiply like you can in photoshop or indesign. So in the end it all ends up a bit flat!
                                  BUILTBRAND.COM.AU
