    [Plugin][EVAL] TIG-CutNfill
    89 Posts 31 Posters 90.6k Views 31 Watching
      pillarpom
      @TIG
      Thank you for your suggestion. The hard part then is how to make the skirt identical. My contour lines were made in Autocad with the same identical property line and then moved to the actual Z value of each contour. The contour lines were imported to Sketchup and transformed to surface by Sandbox. I could not control the boundary afterwards, but they looked almost identical. After the surfaces were made I then used your plugin to make the skirts for each terrain. That was what the result came out. Any suggestion please. Thank you.
        Work on a copy as it might get messy !
        View > Hidden Geometry ON so you can see all edges and vertices.
        Use a Style [temporarily] that makes end-points very noticeable.
        Edit the EXTG group.
        Select all of the 'skirt' by fence - i.e. leave out the top surface.
        Use Edit > Copy to put it onto the clipboard.
        No exit that edit.
        Edit the Proposed group.
        Select all of the 'skirt' by fence - i.e. leave off the top surface.
        Press <delete> to remove it.
        The top surface should be unaffected.
        Now immediately use Edit > Paste-In-Place to insert the clipboard's 'skirt' copy.
        Immediately use the context-menu to Group that - we need to temporarily separate it from the other geometry we will be editing.
        The Proposed group will no longer be 'solid', since we know that the two surfaces do not overlay exactly in plan, and of course the temporary skirt-group will also lead to non-solidity in any case...
        Now deselect everything inside the edit, and use the Move tool to relocate the misplaced vertices on the top-surface's perimeter to snap them in turn onto the temporarily grouped skirt's equivalent top edge vertices, or in some cases an edge [if there is no vertex at the desired location].
        The perimeter of the Proposed top-surface should align exactly in level [Z] with the equivalent edges in the EXTG, since you have no cut/fill beyond the edges ??
        Once you are happy that you have 'healed' the Proposed top-surface's vertices onto the grouped-skirt test for solidity...
        Explode the skirt-group so it merges with the top geometry.
        No exit the edit and Entity Info should report 'solid'...
        If so you can try CutNfill again...
        If still bot solid Undo until the skirt-group exists again... repeat fixing the vertices until it is a solid ...
          Here's v2.0 http://sketchucation.com/pluginstore?pln=TIG-CutNfill It's now reworked and signed for full v2016 compatibility, and various minor improvements for the newer SUp versions - with Skirt making code refreshed etc.
          If you have an earlier licensed version of TIG-CutNfill, then please get this updated EVAL version and when it is installed, the earlier license code is reused.
          So you do not need to buy another license [although if you do I won't mind (no refunds!) 😉 ]
          • O Offline
            ohemstock
            I have downloaded the latest evaluation version, it looks like this tool is exactly what I require. However I get the following error on loading SketchUp:
            Error Loading File TIG-CutNfill.rb
            (eval):65:in `require': uninitialized constant SketchupExtension::TIG::CutNfill::FOLDER
            Please advise, I am keen to get this working
            • O Offline
              ohemstock
              Hi again,
              Just paid for the licensed version as I am sure this tool will make my life easier. However the same problem persists: Error Loading File TIG-CutNfill.rb
              Cheers,
              Ollie
                Following on from the last two posts...
                After some not inconsiderable reverse-engineering...
                I have now made a v8 compatible version of the v2.0 RBZ - for both the EVAL and LICENSED versions...
                So, if you need one please contact me by Private Message...
                Then I'll PM you an RBZ that will work on your 'olde' version 8...
                BUT if you have bought a license, then please give details of your user-name, email etc, so that it can be verified...
                I am not as stupid as I look !
                  lmfarmer
                  Earlier today I purchased CutNfill. 2 questions:
                  1. should I have received my license number by now, or does it take a while for the email to be sent? I did get the PayPal receipt.
                  2. using the Skirt Tool on my unlocked Location Terrain group, created using Add Location, doesn't make a solid. Is there something I'm missing?
                  Here's what I thought I'd be able to do: Add Location, unlock Location Terrain, use Skirt Tool, copy Location Terrain (now a solid), rename one of them EXTG, rename other PROPOSED, move PROPOSED over 1000', modify PROPOSED, move it back 1000', which should put it back in exactly the same spot as EXTG. Obviously I can't do this if I can't make Location Terrain a solid, so I think I'm missing something.
                  I'm going to go back now and experiment with creating a terrain from scratch and then using the SKIRT TOOL, while I wait for an answer here. Maybe I'll figure out the answer to my own question 😄
                    How did you purchase it ?
                    Through the SCF Shop ?
                    If you did that you should have got a new RBZ which you then download and install.
                    And that is fully licensed.
                    There is no license emailed to you.
                    The downloaded RBZ contains the licensed RBZ...
                    Provided that the 'surface' terrains [EXTG & PROPosed] are inperforate skins then the skirt should make a solid.
                    If it's not a solid the entity info will report it as not.
                    Tools like SolidSolver and SolidInspector² can help make these solid...
                    PS:
                    I have copied this to the SCF Shop to determine that you have indeed paid, and if so we'll get a licensed RBZ sent to you...
                      lmfarmer
                      Thanks, TIG.
                      I did manage to make it solid, but only after a bit of work on it. Tomorrow, I'll download some other Google terrains to see the results. I'll attach a file or two if I still have difficulty with them.
                      Thanks for forwarding my query re the license, as the plugin I downloaded did not download with a license attached.
                      And thank you, too, for some of your other plugins. I'm amazed at the work you do!
                        The license file comes in the tool's subfolder shipped in its RBZ.
                        It's a temporary license file in the 'eval' version's RBZ.
                        When, after paying, you get the licensed RBZ, you simply install that and the license file is overwritten with a permanent one, this is all done automatic, there is no other licensing procedure required.
                        I've not heard from the SCF Shop guys to confirm the payment.
                        I am I right is assuming that you got the licensed RBZ ?
                        It's called "TIG-CutNfill[LICENSED]_v2.0".
                        If I confirm your Shop payment but you haven't got the RBZ I can always PM a version to you...
                        After installing the licensed RBZ, I suggest that you restart SketchUp to make sure that it gets fully 'registered'...
                          lmfarmer
                          "am I right is assuming that you got the licensed RBZ ?
                          Well, what I did was I paid for it through the extension store and got the attached message saying to check my email. I did so, saw the paypal receipt was there and thought it might just take time for the email from SketchUcation to come. In the meantime, because I was anxious to get started 😄, I installed the [EVAL] plugin, thinking I'd just be able to add the license when I got the email. So far, though, still no email from SketchUcation. If you or the "SCF Shop guys" need my paypal receipt, I can send that by PM.
                          I also think I know why I wasn't getting a solid when using the Skirt Tool on my Google Location Terrain. When it comes in, it's of course not on SU's default axes, so I need to rotate it and then, if I want accurate shadows, use the Solar North tool. Does that sound right? I'm going to try it after I finish this message.
                          Thanks for your assistance.
                          Linda
                          Confirm.pdf
                            @Linda
                            I've sent you a licensed RBZ by Private Message.
                            Download it somewhere safe and install it to get the licensed tool...
                              lmfarmer
                              Received and installed. Thanks!
                              Now on to Question 2 re not getting a solid when I use the Skirt Tool on a mesh created by Add Terrain. I've tried two different sites, and found that if I grab a small section of the site, I get a solid; if I grab the whole site, I don't. Using Solid Inspector2 tells me I have two surface borders that have to be fixed manually. I've looked, and I can't find anything wrong with the borders.
                              The whole area, of course, wouldn't need cutting and filling, and I read your answer to another post that one should perhaps use CutNfill on just the area that needs cutting and filling. So....
                              I've attached one of the files that has the whole site, no solid for either the rotated-and-end-point-moved-to-origin Location Terrain or the Location Terrain as created by Add Terrain (although I did move it 2000' from where it originally came in so that I could move the rotated copy to the origin). In another file I grabbed a much, much smaller area, and the Skirt Tool worked perfectly. So is size my problem here?
                              Thanks ever so much for your assistance. First you do all the work to create these great tools, and then we take up your time pestering you with questions 😄 Sorry!
                              Linda
                              CutNfill test copy.skp
                                mahmoudsaad89
                                Hi TIG, I donated through the help button to get the license, payment received and got the receipt from PayPal but never got the download link. Am still on EVAL mode and need the tool urgently. I have contacted PayPal and they asked me to contact you directly. Could u please help??
                                  Here's v3.0 https://sketchucation.com/pluginstore?pln=TIG-CutNfill
                                  Signed updated for the newer SUp versions.
                                  Load error on license checking is fixed.
                                  If you have already bought a licensed versions, you can update to this one by installing the trial version from the link.,,
                                  Your current license file will not be affected by the reinstallation.
                                  I will also update the SCF Shop's version very shortly.
                                  So that any new purchasers will get the latest version too...
                                    Resolved, with a refund I hope !
                                    However, your complex EXTG/PROP groups cause issues with SketchUp itself.
                                    Its Solid Tools fail to make a 'difference' that is solid, therefore the volume reports as 0 !
                                    These tools are used by CutNfill too, so they get the same issues.
                                    SketchUp assumed that an edge with start/end nearer that 1/1000" are coincident and the edge is not made, then related faces can't exist, and the object is then not a solid.
                                    Parts of it have before and after faces that are fractions of a millimeter apart, the can't the be used in the 'difference' as the vertical tiny edges get lost...
                                    You could perhaps try scaling up both groups by x1000, do the process and then manually fix the volumes which will be 1000x1000x1000 too big !
                                    The tiny edge at 0.25mm then becomes 250mm so it will succeed in the 'differncing'...
                                      Rhino
                                      I have just purchased the TIG-CUTNFILL and cant get it to load on my SU8 Pro. I keep getting a message that says;
                                      (eval):71:in `join': can't convert nil into String
                                      Also, I get an error;
                                      TT_Lib² Not Installed
                                      Additional files are needed.
                                      Please help. Thanks!
                                        Gábor
                                        Hi Rhino,
                                        Version 3 is clearly listed an compatible >= v2013.
                                        So in v8 it doesn't work !
                                        Indeed v8 is no longer supported by SketchUp and many extensions.
                                        I've contacted TIG and he has an offer to either refund you, or send you a modified V2 version of the plugin what is made SU8 compatible.
                                        Please let us know about your choice.
                                          TimConnell1980
                                          I used the Cut N Fill tool on one terrain, it worked well! THanks. I tried it again on another terrain and although it took a while to get both to be solid objects, when I did get them to be solids it calculated the cut n fill but gave a '0 m3' result and said 'Cut not solid' and 'Fill not solid'. Any ideas what the problem would be?
                                            @Tim
                                            Without seeing the terrain models I can't be sure, however, if the 'remainder' [cut or fill] group is not a solid then its volume is reported as 0.
                                            It is how the API works with 'solid-tools' subtractions, just like doing it manually.
                                            If you select a cut or fill result it should show as a 'Solid' in Entity Info and report its volume.
                                            The reason you can sometimes subtract two solid forms and end up with a non-solid result can be caused by the forms having intersecting geometry such that the resultant form includes some edges with start/end points so close to each other that SketchUp interprets them as being coincident, and consequently the edge is not created and the two faces that it should have supported cannot then exist, meaning that the form has a hole in it and it's therefore not a 'solid'.
                                            SketchUp's tolerance is 1/1000", and whilst you earthworks are unlikely to get near that it is possible to have extg/proposed forms with very small differences in the elevation of some of their planes, which might result in very thin 'slivers' that cannot be made solid; also triangulated faces in the extg/prop forms which intersect could sometimes create very tiny triangular facets, which can cause these kinds of issues...
                                            If you do a manual solid-tools subtraction on copies of the two forms you should see the result cannot be reported as 'solid'.
                                            Check the geometry of the two forms and make minor adjustments, it's pointless having before and after levels that are ~1mm apart as the total cut/fill volume would be minimal anyway...
                                            • 2 / 5
