    Printing molds
    10 Posts 5 Posters 11.1k Views 5 Watching
    • C
      ChemeJoo
      Let's say I have a design for a chess piece, but I want to print out a mold using a 3d printer. I can't do this by simply 3d printing the chess piece. I have to 3d print a mold, which is an "inverse" of the chess piece because it would be a cube, with a hole in the shape of the chess piece. I would then pour the casting media into the mold.
      Is there a way to delete an object from another object on sketchup?
        Yes, it is called a Boolean operation.
        If you have SU Pro it has these abilities
        • BoxB
          You can also just place the object inside a cube with its faces reversed and then split the whole thing in half, giving you two half molds.
          • gillesG
            gilles
            For SUMake with Outershell:
              @gilles
              That's super clever!
                d12dozr
                Love your solution, Gilles! 😎
                For more complex models using Sketchup Make, you can also use the BoolTools plugin
                http://goo.gl/f7ooYh
                • BoxB
                  Just to clarify my earlier comment.
                  There are many ways to modify geometry and it is important to learn the underlying structure.
                  First gif shows a manual split, second shows how an excellent plugin can automate it, once you understand how to do it.
                  Split by hand.
                  http://i.imgur.com/m5dVBop.gif
                  Split by Tig.
                  http://i.imgur.com/OYze0s9.gif
                  • C
                    ChemeJoo
                    So I've made the mold, but it doesn't export to Cura very well at all. I used a solid checker extension and all of the pieces are indeed solid.
                    I get a large yellow block in Cura. I used the "solid tools - subtract" on Sketchup to make the mold from the pieces.
                    Mold
                    Cura
                      d12dozr
                      Impossible to tell from your images, but if you upload the SKP model we can take a look!
                      • C
                        ChemeJoo
                        It's fixed! I saved it as an STL file (with the STL extension) and it worked. I guess some file types simply aren't compatible.
