    Simple animation around one axis
    4 Posts 3 Posters 1.0k Views 3 Watching
    • B
      bflmpsvz
      I would like to use SU animation in the simplest way, only transition between two scenes.
      But I need to keep one axis stable, so the result looked like rotation or flying around.
      Not like this:
      Is it possible?
        Fredos Animator Extension has a forum...
        404 Not Found
        (sketchucation.com)
        You can download the extension here...
        404 Not Found
        (sketchucation.com)
        You will also need LibFredo...
        404 Not Found
        (sketchucation.com)
        It's easier if you install our own SketchUcation Tools and use that to install extensions as you need them...
        404 Not Found
        (sketchucation.com)
        • F
          faust07
          By: sdmitch (http://sdmitch.blogspot.de/)
          Usage: To rotate the view or objects for animation purposes.
          works!
          • B
            bflmpsvz
            My attempts to install Animator was not successful. But Spin It script works and is good enough for my purpose.
