    Simple animation around one axis
    4 Posts 3 Posters 974 Views 3 Watching
      bflmpsvz
      I would like to use SU animation in the simplest way, only transition between two scenes.
      But I need to keep one axis stable, so the result looked like rotation or flying around.
      Not like this:
      Is it possible?
        Fredos Animator Extension has a forum...
        http://sketchucation.com/forums/viewforum.php?f=401
        You can download the extension here...
        http://sketchucation.com/pluginstore?pln=Animator
        You will also need LibFredo...
        404 Not Found
        (sketchucation.com)
        It's easier if you install our own SketchUcation Tools and use that to install extensions as you need them...
        http://sketchucation.com/pluginstore?pln=SketchUcationTools
        • F Offline
          faust07
          By: sdmitch (http://sdmitch.blogspot.de/)
          Usage: To rotate the view or objects for animation purposes.
          works!
            bflmpsvz
            My attempts to install Animator was not successful. But Spin It script works and is good enough for my purpose.
