    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 173.9k Views 79 Watching
    • LOAML Offline
      LOAM
      I've had an email back from ppoublan to say he is hoping to get this fixed in the new year.
        karllarsen
        @loam said:
        @juju said:
        @bob james said:
        [attachment=0:2vnsbkfz]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:2vnsbkfz]
        works fine here in SU2017 as well
        It loads fine as per your image but try the following;
        • Make a tree
        • Reconfigure it, using right click, reconfigure
        • Change tree parameters *
        • Redraw tree using updated parameters **
        • You will notice that many of the sliding bars are listed as NaN
          ** Redraw does nothing after changing any of the parameters 😞
        http://i.imgur.com/Udv6s2S.jpg
        I am having the exact same problem.
        Less is more.
          Jorgensen
          has anyone got this to work with su2017?
          thanks
          jorgensen
            karllarsen
            It sure would be nice to know if this will ever work or its just a lost-cause?
            Less is more.
              I don't really have a need for it but I just installed it now because of your post. It seems to work fine for me. It makes trees like it says on the box.
                Works fine for me inside Su2017 Make ! ☀
                Make your change(s) then Right Click on the selection / Context Menu 3D Arc Studio Tree/ Redraw.
                Free version
                3DArcStudio Tree Maker Sketchup Plugin can be downloaded for free from this site. The free version gives you access to all features, except you are not granted the right to sell or distribute trees created with the plugin, you will get one message each time you change configuration and little time to wait before the tree starts drawing, and you will not get access to all the tree templates included in the full version. If you like this plugin, you can get a licence for 10 euros that will remove those limits.Possible with the free version
                Time was 5 s 😉
                Rendered with the free SimLab Composer Light! maxi 1920 * 1080 😉 (a KeyShot like)
                Can reload quasi any format of files! 👍
                  PS But you right : Configuration Menu works not like inside Su2016! 😮
                  Seems some parameters are not responsive like "Number of truncs"...
                  and more curious the 2 buttons Redraw and Draw Proxy!
                  So it's a very good habit to keep old versions of SU! 💚
                    mwm5053
                    I downloaded the plugin from Sketchucation store within SU just the other day and read the post about the difference between free and paid so I don't think that's the issue I'm having. The drop down list of templates shows none either for the trees or grass. May be some knows something I don't (which is entirely possible).
                    2011 iMac
                    SU 2015 Pro, 2017 Make
                    V2 Twilight
                    macOS Sierra 10.12.5
                    • OxerO Offline
                      Oxer
                      The plugin does not work on SU 2017, try with SU 2016 or 2015.
                        If it doesn't work in SU2017, why did I get trees from it in SU2017?
                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p613826
                        It worked for Pilou with no problem either. Maybe we're doing it wrong.
                        • OxerO Offline
                          Oxer
                          Perhaps because you use Windows, mwm5053 & me work on Mac, the plugin works fine in SU2016 on Mac but in SU2017 it appears the issue that mwm5053 describes.
                            mwm5053
                            I just removed all website data in Safari and Google Chrome ( some plugins I remembered use web dialogue something or other ) like the Fur plugin that I had problems with on Mac but still no choice for choosing type of tree.
                            Edit the Fur plugin does work in SU 2017 and OS X 10.10.5 Yosemite
                            2011 iMac
                            V2 Twilight
                              lgrahm
                              I guess it's a Mac-related problem. I've tried to install it on both an iMac and a Macbook pro with SU2017 pro.
                              Problem 1 is (as other have noted) that the menu is blank - you can't choose any tree type.
                              Problem 2 is that the plugin dissapears when you quit and restart SketchUp! Yes, it's not disabled - it's not there!
                                karllarsen
                                [attachment=0:2trikxvl]<!-- ia0 -->Screenshot - 2_10_2017 , 6_47_08 PM.png<!-- ia0 -->[/attachment:2trikxvl]
                                Great! Now try to EDIT the tree and tell me if you can ADD branches.
                                Then, make sure you read the entire description of what is NOT working 😉
                                Less is more.
                                  mwm5053
                                  Still having the same problem as lgrahm on my Mac with SU 2017 seems to work fine in SU 2015 however.
                                  2011 iMac
                                  V2 Twilight
                                  • LOAML Offline
                                    LOAM
                                    Hi Dave R, can you explain the process of how you are editing already created trees please? This is a plugin that we have paid for and whilst it wasn't expensive we would like to continue to use it in 2017 Pro. As you discovered It makes trees fine, they all generate originally but you can not edit them once created as a large percentage of the sliders are listed as "NaN" and the redraw button does nothing and the ruby console throws an error.
                                    Works ok though in 2016 pro.
                                    Would really appreciate a description of how you got it working so we can try the same thing.
                                    This post describes the issue we are running into;
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p608575
                                      jdcamc
                                      The plugin works fine in the Windows version of SketchUp 2017 but it doesn't work for the MAC version of SketchUp 2017. I have both and the drop-down menus in both the trees and grass dialog boxes are empty in the MAC version. I can import a tree that I made with the Windows version into the MAC Version of SketchUp but when I select the tree, then right click to bring up the context menu, the context menu is empty, too. I am, however, able to turn on and off the proxy of the tree that I've imported into the MAC version of SketchUp.
                                      • ppoublanP Offline
                                        ppoublan
                                        I uploaded in sketchucation plugin store a new version that is working with SU2016 and SU2017.
                                        • jujuJ Offline
                                          juju
                                          Thank you, good sir!
                                          • TIGT Online
                                            How did you do it ?
                                            I can't see an updated version ?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
