    [Plugin] SectionCutFace
    569 Posts 171 Posters 478.4k Views 170 Watching
    • V Offline
      vico44
      I've done a Plugin with the core of section Cut Face withe some of new things:
      • A Layer organisation : Section is only done in few layer and keep the layer organisation
        All face done with section Cut face'll go to the correct layer
      • A Automatic view creation : it create multiple view with specific layer and Style
        The first view is for heavy line (Structure of Building)
        The second is for middle line (2nd Oeuvre of Building)
        The third view is for fine line (Object, doors, etc...) large scale
        The fourth view is for fine line (Object, doors, etc...) small scale
        The fifth view is for Hatch (with the layer color)
      I've done some Scrapbook for layout to bring this view in a simple way...
      The plugin : Vico-Section.rb
      A Skp example with the layer organisation Orga.skp
      You can access to the plugin with the right click on a Sketchup section (Plan is for top view / coupe is for section...)
      You can update all the section with "Mise Γ  jour des sections" in the extension menu...
      Some exemple of drawing in layout : http://www.vico.lautre.net/portfolio/plan-sur-sketchup/
      I've planed to do it more customized, but i need more time for that, and it 'll not be done soon πŸ˜„
        You don't appear to get a BugSplat dialog ?
        Can you check that your Graphics Card Drivers are up to date...
        I cannot replicate the problem at all, so I am starting to suspect it's your system configuration.
        The various permutations for manual deletion etc should not cause issues... they don't for me...
        • sirtetS Offline
          sirtet
          No... Plain crash...
          Well... That's a sore point.
          I have a Dell Precision 7510 with 4K Int. Display + Ext. 1920x1200 and 2560x1440, driven by Intel HDGraphics 530 plus Quadro M2000M...
          The Windows device manager just updated the Quadro drivers, so from Window's view i'm up to date.
          I DO have graphics problems, but around Displays (mostly the 4K) after boot/wakeup being black, but windows can be moved to that screen...
          The dell site offers me a confusing amount of drivers, Talking to Dell hotline eats endless time...
          I need to fix that sometime, but for now i need to work on work and not the PC.
          But if i get input on a good approach to sanitize the system, i'm in, for sure.
          Did you try EXACTLY as in the video?
          I now found out, that the crash is not happening if i redo not in the Scene Hatch EG, but in the scene "Haus" (switching from Hatch EG to Haus).
          But there's a few things why i think it's not (only?) the system config:
          The fact that deleting a section still leaves the Redo section cut Option in the context menu (even after saving, closing, reopening the file), tells me that some remains are left after deleting the section. Also, it will come up again with the same custom name as before, if i redo a section that does not crash.
          Where's that info coming from?
          But, why does the context-menu entry for remake persist, if the cut is seemingly completely deleted?
            I can't replicate the issue...
            The SCF's settings are remembered with the Section Plane, as attributes.
            When you select a Section Plane the context-menu shows appropriate options.
            A Section Plane that has never had a SCF gets 'Add...' - and using that takes your entered settings and then it makes the SCF based on those - if you choose to allow it to be 'Re-made', it then links it to the Section Plane, and adds the settings to the Section Plane as attributes,
            If the Section Plane has a SCF or it once had one that perhaps you deleted, and it is set to be Remake-able, you get the 'Re-Make...' option as well.
            If you choose that, then a replacement SCF is created using the previously used settings [read from the attributes], any preexisting linked SCF is delete, and a new linked SCF is added.
            If you choose 'Add...' then the settings dialog pops up with the last used SCF settings - any preexisting linked 'Re-make-able' SCF is delete, and a new one is added.
            • bmikeB Offline
              bmike
              Getting crashes in 2017 Mac with the latest update. Might copy back in my older version and see if I get the same behavior. It didn't crash yesterday at all.
              • bmikeB Offline
                bmike
                Working just fine, same model in 2016.
                Will see if I have the latest SU2017 installed.
                • bmikeB Offline
                  bmike
                  Nothing to report, sporadic crashes in 2017 Mac with certain models, solid in 2015 and 2016 with same model.
                  • I Offline
                    ifresia
                    Hi TIG,
                    Great plugin, but I have a question. I'm trying to couple sectioncutface with the keyframe animation plugin, essentially to animate a section cut in perspective through a building model, except by animating the building to move through the section plane, keeping the plane and camera in the same spot. Is it possible to have sectioncutface update real-time as the animation is played?
                    Isaac
                    • bmikeB Offline
                      bmike
                      TIG -
                      When I create a scene with the SCF plugin the layer I have added the section to is now on in the current scene as well as the new scene... is this a bug or a feature? I would expect that the current scene would not be affected by anything happening when I choose 'New Scene'
                      I'm also getting bug splats every couple of times I run the plugin. I have sent off the bug slats, not sure where I can access them to show you what is going on.
                      Last bugs plat submitted was Crash Report #7925
                      • bmikeB Offline
                        bmike
                        Video of layer activating on existing scene:
                        • bmikeB Offline
                          bmike
                          Submitted multiple more bug splats, the latest was Crash Report #7933
                          • bmikeB Offline
                            bmike
                            Crash Report #7935
                            • bmikeB Offline
                              bmike
                              OK - I think I have isolated the issue, am testing now.
                              If I run the plugin to create a new scene from a scene that uses a style where 'Section Planes' has not been updated or refreshed - SU crashes.
                              Done this twice now in a row. Will test more.
                              If I run the plugin in a scene with a style that I have not altered (like turned the section planes on so I can see them, to create the new cut) - then it works consistently.
                                A guaranteed way to Splat is to Remake Section when you section is hiding all content.
                                • bmikeB Offline
                                  bmike
                                  OK - This appears to be the case - if any change is made to the style of the current scene (like turn section planes on or off) - if you don't refresh the style when SectionCutFace tries to make a new scene it crashes.
                                  I have tested this by altering edges, not refreshing and getting a crash, as well as only toggling the Section Plane on and off (for visibility) - and it crashes if I do not update the style before running the plugin.
                                  • bmikeB Offline
                                    bmike
                                    I'm trying to make new...
                                    See below - I think I have isolated what is happening - its related to styles...
                                      Can we keep the posts on this in the one place - here...
                                      Having other posts at SketchUp.com is confusing - although their team's comments on your BugSplats might be helpful...
                                      Can you provide a simple model with Styles etc that shows this behavior...
                                      ZIP it and PM if you don't want it 'public'...
                                      If it's too big to attach use a file sharing site and PM me a link...
                                      Also some step by step instructions on how to make the splats would be most helpful...
                                      • bmikeB Offline
                                        bmike
                                        I can... later today.
                                        2 issues that I have posted about -
                                          • Is the layer behavior a bug or feature?
                                        Video:
                                        https://youtu.be/v9GZJrM7Jvo
                                        I am getting the layer turned on in the scene I start from, when I believe it should only be on in the new scene that SCF creates.
                                        1. the crashes - it crashes just with 2 boxes on the screen, and I believe this is connected to having a new scene created that is using a style that has been altered, but not refreshed.
                                          Here's v6.1 http://sketchucation.com/pluginstore?pln=SectionCutFace
                                          New FR strings file added [thanks to @mariocha].
                                          Re-signed for full v2017 compatibility.
                                          Haven't yet got to the bottom of the @bmike reported issues.
                                          Watch this space...
                                          • V Offline
                                            victor hugo
                                            TIG.
                                            I upgraded SectionCutFace using extension store, the previous version was working fine and with this upgrade to 6.1 when I want to create a section I don't get the prameters window.
                                            Any clues why this doe not appear.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 24 / 29
