    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.2k Views 170 Watching
      The objects being cut are not 'solids', so the tool tries to guess what is needing a face and what is not.
      It fails and faces the ground floor cut, missing out the wall faces.
      However, a little manual editing/erasing and over-drawing of unfaced edges to make missing faces etc will fix it.
      No code algorithm is foolproof.
      As you have shown, it's easy to make a form that has several alternative interpretations of what should be faced...
      • I
        ittayd
        what do you mean be editing/erasing and over drawing? do you mean creating the faces then unlocking the layer created by the plugin and then copying over there? Or is there something else to direct the plugin to create the faces?
        • srxS
          srx
          @jql said:
          Tig,
          I think this is a nice workflow to have for architectural projects, specially if we use reflected ceiling plans and I would find it interesting if the plugin would generate Section Cut Faces as components which could probably be an option.
          Good idea. I was also thinking about this...not for Section Cut Face, but for Rich Section.
          You are editing the section Group - Component...what about updating it later? How do you manage the changes?
          www.saurus.rs
            You have a number of settings to choose from.
            Do not lock the group [you can then edit it more easily].
            Do no hide edges.
            Keep faceless edges.
            Have Updating off.
            Make the grouped faces/edges.
            Then edit the group.
            Draw over a faceless edge that should have a face - like some of the back walls.
            This will make a face.
            When all faces are made...
            Select and <delete> the unwanted faces - like the one across the lowest floor's main volume.
            Select use the Material Browser's eyedropper to select a colored face's material and apply that to the new faces which have no material.
            If you want the group locked, select it and use the context-menu item to change its properties...
            • JQLJ
              JQL
              What do you mean Srx? What changes? Updating changes to the model on the section cut face?
              www.casca.pt
              Visit us on facebook!
              • srxS
                srx
                Yes
                www.saurus.rs
                • JQLJ
                  JQL
                  If I have done a lot of work on a SectionCutFace (like healing SCF that doesn't fill walls due to model complexity or, most commonly, a SCF where I've drawn 2D details and area groups on) I simply draw a rectangle on the area that has changed, erase every line inside and intersect it with model.
                  It's a very fast way to remake a section cut face and you don't loose the work you've done.
                  However, I'd greatly appreciate if sectioncutfaces were Components instead of Groups as I could export them directly or even, if Tig would develop an incremental SCF component (Section#1, Section#2, Section#3 from the same section plane), I could restore an older section from the component browser.
                  www.casca.pt
                    danx82
                    It works with Mac?
                      @danx82 said:
                      It works with Mac?
                      Yes.
                      But read up on how to use it...
                      It only appears in the context-menu if one Section Cut Plane is selected.
                      There are no menu or toolbar entries.
                      It works on both OSs, and with Pro or Make too...
                      Note: Most extensions / plugins work on both PC and MAC.
                      The author will usual state quite clearly if they do not work on a particular OS.
                      Also many will work with both Pro and Make - although some need Pro functions like 'solid-tools', but then this is clearly stated in the usage notes.
                      • sirtetS
                        sirtet
                        Today, my model started to crash (bug splat) when i try to redo a section cut, or add a new one...
                        In a blank file, it still works.
                        But in two copies of my model, it crashes...
                        could there be some remains of an old section cut, that i deleted by hand?
                        Any idea how to investigate/get rid of this crashing?
                          Without seeing the model this must be guesswork...
                          A few ideas...
                          Have you run Model Info > Statistics > Fix problems [and Purge unused] ?
                          Do you get any error messages in the Ruby Console before the crash ?
                          If you use the Outliner can you see if the named SCF group is still hanging around.
                          e.g.
                          Have you hidden it ?
                          Have you moved it to an off layer ?
                          Was it locked ?
                          Have you somehow moved it inside another group or component ?
                          If you delete the Section-Plane and then immediately recreate it in the same place, then any associated SCF will no longer be linked, and you can then make a brand new SCF - this workaround might avoid the crash - whatever the cause...
                          • sirtetS
                            sirtet
                            Thanks TIG.
                            So, my model had stopped crashing for a while, but now it does it again...
                            I'm on SU2017 now, and the only difference is, that the crash does not bring up a bugsplat window, but just closes SU.
                            No, Model info had no errors reported.
                            No, I opened the console first, then my skp, then redo SCF, >> CRASH
                            Yes
                            No
                            No
                            Was it locked ?
                            No
                            Hmm, the whole house was newly grouped as a whole, sometime before each level (where the SCF is in) was a top-level group.
                            No, still crashing...
                            Here's the skp (7MB):
                            https://www.dropbox.com/s/twhe7pvrl7hdora/Kirchweg-55_Ideen.skp?dl=0
                              I have your SKP BUT it's relatively useless.
                              What are you trying to do ?
                              Where is the problem ?
                              If I select the SectionPlane in the last Scene-Tab I can Add OR ReMake it.
                              Although I see it is not 'named' ?
                              Can you explain your steps to the crash.
                              I have no issues...
                              • sirtetS
                                sirtet
                                TIG, sorry, very dumb of me.
                                Thanks a lot for your patience and quick replies!
                                And for all your tools anyways.
                                The Section cut in that last scene works for me too.
                                What crashes:
                                I open the sketch.
                                Hatch EG is the open tab.
                                (See the EG Tab, the hatch is out of date.)
                                Turn on section planes
                                Click the section plane in Group EG
                                Redo Section Cut face
                                Immediate crash
                                  I assume you mean this one ?
                                  It remade the SCF with no issues...
                                  The Section Plane with its overlaps etc was somewhat difficult to select before I could use the right-click context-menu, but using a select > fence did it...
                                  Later I also realized the remade SCF was named "EG wallCut" in the Outliner - doh!
                                  But it only appears after it's remade - was it previously deleted manually ?
                                  I can also Add a new SCF and give it any name I choose...
                                  I switched of other containers so you can see the result more clearly...
                                  • sirtetS
                                    sirtet
                                    Yes, this is the one.
                                    Well, it crashes for me:
                                    Also all the other hatches (Scenes Hatch UG|OG|DG) crash too, Same as the purple hatch in Scene Hatch EG. In that Scene, the hatches of the chimney do work to update.
                                    Any idea how i could remove these offending (or all) hatches in a way, so there's no remake- contex menu entry anymore? I think something is messed up somehow.
                                    Your questions about it being moved/renamed/manually deleted:
                                    What would be illegal operations, that could create the crashing?
                                    I think i did quite some renaming and stuff with the section cuts until i understood them more or less, but i think they were more or less in the state they are now, when they still worked.
                                    PS:
                                    I don't find it hard to select the section cut...
                                    • V
                                      vico44
                                      I've done a Plugin with the core of section Cut Face withe some of new things:
                                      • A Layer organisation : Section is only done in few layer and keep the layer organisation
                                        All face done with section Cut face'll go to the correct layer
                                      • A Automatic view creation : it create multiple view with specific layer and Style
                                        The first view is for heavy line (Structure of Building)
                                        The second is for middle line (2nd Oeuvre of Building)
                                        The third view is for fine line (Object, doors, etc...) large scale
                                        The fourth view is for fine line (Object, doors, etc...) small scale
                                        The fifth view is for Hatch (with the layer color)
                                      I've done some Scrapbook for layout to bring this view in a simple way...
                                      The plugin : Vico-Section.rb
                                      A Skp example with the layer organisation Orga.skp
                                      You can access to the plugin with the right click on a Sketchup section (Plan is for top view / coupe is for section...)
                                      You can update all the section with "Mise à jour des sections" in the extension menu...
                                      Some exemple of drawing in layout : http://www.vico.lautre.net/portfolio/plan-sur-sketchup/
                                      I've planed to do it more customized, but i need more time for that, and it 'll not be done soon 😄
                                        You don't appear to get a BugSplat dialog ?
                                        Can you check that your Graphics Card Drivers are up to date...
                                        I cannot replicate the problem at all, so I am starting to suspect it's your system configuration.
                                        The various permutations for manual deletion etc should not cause issues... they don't for me...
                                        • sirtetS
                                          sirtet
                                          No... Plain crash...
                                          Well... That's a sore point.
                                          I have a Dell Precision 7510 with 4K Int. Display + Ext. 1920x1200 and 2560x1440, driven by Intel HDGraphics 530 plus Quadro M2000M...
                                          The Windows device manager just updated the Quadro drivers, so from Window's view i'm up to date.
                                          I DO have graphics problems, but around Displays (mostly the 4K) after boot/wakeup being black, but windows can be moved to that screen...
                                          The dell site offers me a confusing amount of drivers, Talking to Dell hotline eats endless time...
                                          I need to fix that sometime, but for now i need to work on work and not the PC.
                                          But if i get input on a good approach to sanitize the system, i'm in, for sure.
                                          Did you try EXACTLY as in the video?
                                          I now found out, that the crash is not happening if i redo not in the Scene Hatch EG, but in the scene "Haus" (switching from Hatch EG to Haus).
                                          But there's a few things why i think it's not (only?) the system config:
                                          The fact that deleting a section still leaves the Redo section cut Option in the context menu (even after saving, closing, reopening the file), tells me that some remains are left after deleting the section. Also, it will come up again with the same custom name as before, if i redo a section that does not crash.
                                          Where's that info coming from?
                                          But, why does the context-menu entry for remake persist, if the cut is seemingly completely deleted?
                                            I can't replicate the issue...
                                            The SCF's settings are remembered with the Section Plane, as attributes.
                                            When you select a Section Plane the context-menu shows appropriate options.
                                            A Section Plane that has never had a SCF gets 'Add...' - and using that takes your entered settings and then it makes the SCF based on those - if you choose to allow it to be 'Re-made', it then links it to the Section Plane, and adds the settings to the Section Plane as attributes,
                                            If the Section Plane has a SCF or it once had one that perhaps you deleted, and it is set to be Remake-able, you get the 'Re-Make...' option as well.
                                            If you choose that, then a replacement SCF is created using the previously used settings [read from the attributes], any preexisting linked SCF is delete, and a new linked SCF is added.
                                            If you choose 'Add...' then the settings dialog pops up with the last used SCF settings - any preexisting linked 'Re-make-able' SCF is delete, and a new one is added.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 24 / 29
