    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • F Offline
      FZSarasota
      I just tested it in 2017, Works Great!!! Thanks for the plugin, saves me a lot of time working in SU2017.
      -Terry
        pebkac000
        Great plugin. Thank you very much.
        It is so easy to select the edges and configure for the required result.
        • V Offline
          valid8r
          A question. I'm thankful for this plug in. I've installed it on two machines, one running Win10 and one running Win7. Both install and the Win7 version works great, but the Win 10 'compresses' the window that gets loaded when I select one of the three cube icons. This means I can not control the parameters for RoundCorner. Is this a known issue with a solution?
          • ipsketchpiI Offline
            ipsketchpi
            Maybe silly question, but I cant get those edges visible, have tryed all without luck 😞 please help
            /IP
              Maybe you haven't tried all
                ipsketchpi
                hmm, you have done it with "Sharp corners in 3D" and have choose one segment property for round corner.
                But can you repeat the same with "Bevel edges and corners" ?
                /IP
                • fredo6F Offline
                  Do you have a picture of the situation on Win 10. Do you have a high resolution screen ?
                  • sirtetS Offline
                    sirtet
                    SU 2017 complains about an outdated signature... Is there a new version of RoundCorner, or a workaround?
                      There are loads of extensions that show as having outdated signatures. It doesn't prevent them from working. They still work just fine in SU2017 as does this one. The most recent version of Round Corner is in the SCF Extension Store.
                      • sirtetS Offline
                        sirtet
                        Thanks Dave.
                        My confusion came from me not finding the UI...
                        I was looking in the Tools menu etc, but did not find anything.
                        In SU16 a toolbar window opened, but not in SU17, so i thought it was not working due to the signature-problem...
                        Now i use the context menu on the toolbar to bring up the rounded corner icons. Shouldn't there be also some menu entry?
                          There's a toolbar for RoundCorner and it's also available in the Tools menu.
                            Splunk
                            Where is the download link? I cannot find it in the opening thread post.
                            Cheers for any help in advance.
                            Splunk
                            • sirtetS Offline
                              sirtet
                              i got it from the sketchukation store in SU...
                              else' there's a PluginStore link on every Sketchucation page.
                              http://sketchucation.com/pluginstore?pln=RoundCorner
                                @splunk said:
                                Splunk
                                Apparently you didn't read the first post in the thread as it is very clearly indicated.
                                As sirtet mentioned, Get extensions from the SCF Plugin Store. Install the tool from Resources at the top of the page and automatically install the extensions correctly.
                                  Splunk
                                  @dave r said:
                                  @splunk said:
                                  Splunk
                                  [attachment=0:ad62yv1w]<!-- ia0 -->Screenshot - 1_18_2017 , 5_12_32 AM.png<!-- ia0 -->[/attachment:ad62yv1w]
                                  Thank you, but 'apparently' I did find the link after I weighed through the lengthly first post again and found that tiny little line you describe while you were moderating my email.
                                  That first post is a visual disaster and needs a clean-up. A myriad of text colors (which you think may be links) and a myriad text thicknesses and sizes. There's no consistency. It looks like Willy Wonka threw up on a Thread post.
                                  We don't need to click on garish colored graphic button links like the 'Overview - Purpose' graphic that serves no purpose and leads nowhere.
                                  Show us image results of the corner plugin in action and that's it.
                                  That main post should have all Black, Regular Type. Black Bold for Small Headings.
                                  ONE up-to-date Download Link Button for the latest LibFredo.
                                  ONE up-to-date Download Link Button for the latest RoundCorner Plugin.
                                  Love the Plug-In....though it already should be in the App....and after nearly 8 years, that first post seriously needs a makeover.
                                    Most users are using the Sketchucation Extension Store to automatically install extensions like Round Corner and to keep them updated. They aren't downloading them individually to install them manually. You could do the same.
                                    • fredo6F Offline
                                      You are free to have and express an opinion.
                                      The design of the main post is intentional. The big colorful fonts highlight what is important. If you had read them, and just them, I guess you have not even raised your question on installation.
                                      • E Offline
                                        edd21
                                        Not sure if I've done something wrong, but the toolbox seems very small on my screen? Does anyone else have the same issue? Thanks.
                                        Mac OS X El Capitan. SketchUp 2017 Pro.
                                        • H Offline
                                          Hamodat
                                          why can't i download it no download to click on!!!!!!help please
                                            Gábor
                                            You have to be logged in to the site to see the download button at the above link.
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 73
                                            • 74
                                            • 39 / 74
