    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.5k Views 172 Watching
    • robintR Offline
      robint
      Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
      only way I found was to use the rotate tool before hitting go
      not very elegant
      perhaps someone else will pitch in
      Cheers
      Robin
      As one door closes another one slams in your face
      • robintR Offline
        robint
        Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
        I put the sound byte into the UI sound tab, but nothing happens? WOTODO?
        Robin
          PituPhysics
          Robin
          Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab.
          Try this:
          mortar 2.skp
            SketchyPhysicsNutt
            Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
            thx
            Tez
            • robintR Offline
              robint
              Hi PP
              some good stuff there, doesnt make the sound?
              take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
              Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
              Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
              What am I doing wrong?
              Robin
              mortar 3.skp
                PituPhysics
                I made more models to be more opportunities.
                1.) Frozen: mortar 4.1.skp
                2.) Hide: mortar 4.2.skp
                3.) Simulation pause: mortar 4.3.skp
                And magnet test:magnet.skp
                • robintR Offline
                  robint
                  Hi PP
                  tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic?
                  Robin
                  • robintR Offline
                    robint
                    Even stranger, I managed to get my balls to clang together at 30 fps, but unable to simulate repulsion even with negative magnet values? I notice that perhaps magnet is a wrong term as it behave more like gravity between two masses (hence no repulsion effect)
                    Universal gravitation equation
                    F = GMm/R2
                    where
                    F is the force of attraction between two objects in newtons (N)
                    G is the Universal Gravitational Constant = 6.674*10−11 N-m2/kg2
                    M and m are the masses of the two objects in kilograms (kg)
                    R is the separation in meters (m) between the objects, as measured from their centers of mass
                    notice how the ball is attracted to the target even though the target has no magnetic force
                    for example
                    Robin
                    my magnetic balls 1.skp
                    • robintR Offline
                      robint
                      Hi PP
                      Got as far as 4.3 and it certainly is the cats whiskers, like the disappering effect in 4.2, all we need is a little pop up explosion (still no sound on mine?)
                      I dont understand what is affecting the fps so drastically? It goes from 30fps down to 4 or less
                      Robin
                      • robintR Offline
                        robint
                        Playing with real shells. Wonder how I can get the nose pointing along the path? hmmm ❓ notice the fps is 27, yet on some of the models its very slow 2fps
                        mortar 5.1.skp
                          PituPhysics
                          For me 63 fps.
                          mortar 5.2.skp
                          • robintR Offline
                            robint
                            Wow PP that has blown me away, havent looked into detail yet, tomorrow am
                            Now could this be mounted on a tank? Forward, left, right track
                            Then we could have two or more, multi players
                            Tank battle, forests, obstacles, terrain, mines, smoke etc
                            Pls assume all rights, I'll be your beta tester and write the manual
                            Robin
                            Ps I wrote a game like this in BASIC years ago, for four players, it was extemely addictive, hidng under tree cover trying to guess where you opponents were. Each tank had a home base corner and had to return for new ammo and fuel. we spent hours on it
                            I turned this into a kids game sliding around on mats on a polished wood floor blindfold, getting coded instruction from their base commanders. They fired foam tennis balls at each other and only had three reserve tanks. Couldn't get them out of the classroom, oh and they had to give their instructions in a foreign language, French German, Italian and swedish - a summer uni job - but the kids loved it
                            Robin
                            • robintR Offline
                              robint
                              Hi PP
                              changed the angle so its a cannon 0 - 80deg azimuth control
                              just gets better 😄
                              mortar 5.3.skp
                              • I Offline
                                INVR
                                I have a little issue where sometimes when I run the sim (simple hinges) it starts scanning and objects seem to disappear. I can control the camera and see them or half of the object. But it gets worse and worst until I have to reset it. Is there any steps I can take to fix this?
                                  Anton_S
                                  INVR, camera clipping is very like caused by some objects falling down too far away from camera. To fix this, find the objects that fall down non stop and draw a floor below them or set them to ignore if they are not necessary for the simulation. These objects could be hidden groups or hidden layers. So uif you unhinde everything, and run simulation, you should be able to notice which objects do that.
                                  • F Offline
                                    faust07
                                    Testing "export replay to images" in SketchUp 2017.
                                    The result is incomplete images with always the same empty white parts..
                                    The same happens when using the following line in a MSPhysics script:
                                    Sketchup.active_model.active_view.write_image("e;/MSPh_Temp/frame_%06d.png" % frame,1600,900,true,1.0)
                                    How should it be right for SUp 2017?
                                    • F Offline
                                      faust07
                                      Hi, Anton. Here I have yet an other question:
                                      It would be great if, for example, there would be a mode for the servos to hold the joint exactly at the center of rotation and completely prevent the centrifugal forces and the pulling out of the components involved.
                                      In the enclosed example, I have not found any way to keep the outer sections of the wings exactly at the center of rotation of the servos. There always develops a gap between the parts.
                                      Have screwed at all settings and nothing was useful.
                                      It seems to be a kind of inertia of the outer wing segments, which can not be stopped by reducing weight, gravitation, friction, etc.
                                      • luckyvacL Offline
                                        luckyvac
                                        Hi Anton, is it possible to control the movement of a servo motor with a function of time. An Excel file ? In the command section can replace the slider by a function of time ( ontick ? ). ... thank you very match.
                                          Anton_S
                                          Yes, luckyvac, it is possible to control servo angle through a function of time. There are lots of ways it can be done. One way is to simply write a function into the controller section of the the servo. Say, you want to control the angle of the servo, in degrees, with a function f(t) = t*3 + 150.
                                          Converting it to ruby and MSPhysics, the code would like like this: world.time * 3 + 150. If you paste this snippet into the controller section of a servo, it will have the servo angle be the value of this function at simulation time, t.
                                          • luckyvacL Offline
                                            luckyvac
                                            Hello Anton,
                                            Thank you for your reply. I will need more knowledge to carry out my project.
                                            I am guitarist and I teach guitar accompanying songs.
                                            This project aims to realize a tutorial to learn how to play the accompanying guitar and to show that one can realize accompaniments guitar with 5 or 6 rhythmic figures.
                                            http://www.luckyanimationspectacle.com/index.asp?pageid=33
                                            I used MSPhysics to simulate the movement of the arm and hand of a guitarist holding a pick.
                                              He accompanies guitar with a song following the rhythm 1-2-345et.
                                            Fig.01 As an attachment. pierrot robo guitar
                                            I used 2 servomotors:
                                            • one for the forearm which operates the up and down of the forearm.
                                            • a second for the descent of the hand.
                                              I made a stop-motion video by adjusting the two actuators point by point according to the following diagram:
                                              Fig.02 As an attachment 1-2-345et
                                            I would like to replace the slider by time functions, point by point (FIG. 2) or FFT.
                                            The displacement coordinates of the servomotors are shown in the table in figure 02.
                                            You will find the simulation with the <FOREARM> (avant bras ) and <HAND> (main ) slider in my drive and an example video. I chose the refrain of Bob Dylan's "blowin in the wind".
                                            Here is the link :
                                            https://drive.google.com/open?id=0B00m7nJr8D_qTnRXX3AyeWVyZmc
                                            The video tutorial shows the synchronized movement with a rhythmic tablature made with Guitar Pro MIDI (*.gpx, *.mid ). There is no human, just my voice 😉.
                                            I thank you for your attention and information you can communicate to me to help me realize my project.
                                            Best regards
                                            jean-luc alias luckyvac... lucky guitaR
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 46
                                            • 47
                                            • 14 / 47
