    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • robintR
      robint
      Hi PP
      Got as far as 4.3 and it certainly is the cats whiskers, like the disappering effect in 4.2, all we need is a little pop up explosion (still no sound on mine?)
      I dont understand what is affecting the fps so drastically? It goes from 30fps down to 4 or less
      Robin
      As one door closes another one slams in your face
      • robintR
        robint
        Playing with real shells. Wonder how I can get the nose pointing along the path? hmmm ❓ notice the fps is 27, yet on some of the models its very slow 2fps
        mortar 5.1.skp
        • P
          PituPhysics
          For me 63 fps.
          mortar 5.2.skp
          • robintR
            robint
            Wow PP that has blown me away, havent looked into detail yet, tomorrow am
            Now could this be mounted on a tank? Forward, left, right track
            Then we could have two or more, multi players
            Tank battle, forests, obstacles, terrain, mines, smoke etc
            Pls assume all rights, I'll be your beta tester and write the manual
            Robin
            Ps I wrote a game like this in BASIC years ago, for four players, it was extemely addictive, hidng under tree cover trying to guess where you opponents were. Each tank had a home base corner and had to return for new ammo and fuel. we spent hours on it
            I turned this into a kids game sliding around on mats on a polished wood floor blindfold, getting coded instruction from their base commanders. They fired foam tennis balls at each other and only had three reserve tanks. Couldn't get them out of the classroom, oh and they had to give their instructions in a foreign language, French German, Italian and swedish - a summer uni job - but the kids loved it
            Robin
            • robintR
              robint
              Hi PP
              changed the angle so its a cannon 0 - 80deg azimuth control
              just gets better 😄
              mortar 5.3.skp
              • I
                INVR
                I have a little issue where sometimes when I run the sim (simple hinges) it starts scanning and objects seem to disappear. I can control the camera and see them or half of the object. But it gets worse and worst until I have to reset it. Is there any steps I can take to fix this?
                  Anton_S
                  INVR, camera clipping is very like caused by some objects falling down too far away from camera. To fix this, find the objects that fall down non stop and draw a floor below them or set them to ignore if they are not necessary for the simulation. These objects could be hidden groups or hidden layers. So uif you unhinde everything, and run simulation, you should be able to notice which objects do that.
                  • F
                    faust07
                    Testing "export replay to images" in SketchUp 2017.
                    The result is incomplete images with always the same empty white parts..
                    The same happens when using the following line in a MSPhysics script:
                    Sketchup.active_model.active_view.write_image("e;/MSPh_Temp/frame_%06d.png" % frame,1600,900,true,1.0)
                    How should it be right for SUp 2017?
                    • F
                      faust07
                      Hi, Anton. Here I have yet an other question:
                      It would be great if, for example, there would be a mode for the servos to hold the joint exactly at the center of rotation and completely prevent the centrifugal forces and the pulling out of the components involved.
                      In the enclosed example, I have not found any way to keep the outer sections of the wings exactly at the center of rotation of the servos. There always develops a gap between the parts.
                      Have screwed at all settings and nothing was useful.
                      It seems to be a kind of inertia of the outer wing segments, which can not be stopped by reducing weight, gravitation, friction, etc.
                      • luckyvacL
                        luckyvac
                        Hi Anton, is it possible to control the movement of a servo motor with a function of time. An Excel file ? In the command section can replace the slider by a function of time ( ontick ? ). ... thank you very match.
                          Anton_S
                          Yes, luckyvac, it is possible to control servo angle through a function of time. There are lots of ways it can be done. One way is to simply write a function into the controller section of the the servo. Say, you want to control the angle of the servo, in degrees, with a function f(t) = t*3 + 150.
                          Converting it to ruby and MSPhysics, the code would like like this: world.time * 3 + 150. If you paste this snippet into the controller section of a servo, it will have the servo angle be the value of this function at simulation time, t.
                          • luckyvacL
                            luckyvac
                            Hello Anton,
                            Thank you for your reply. I will need more knowledge to carry out my project.
                            I am guitarist and I teach guitar accompanying songs.
                            This project aims to realize a tutorial to learn how to play the accompanying guitar and to show that one can realize accompaniments guitar with 5 or 6 rhythmic figures.
                            http://www.luckyanimationspectacle.com/index.asp?pageid=33
                            I used MSPhysics to simulate the movement of the arm and hand of a guitarist holding a pick.
                              He accompanies guitar with a song following the rhythm 1-2-345et.
                            Fig.01 As an attachment. pierrot robo guitar
                            I used 2 servomotors:
                            • one for the forearm which operates the up and down of the forearm.
                            • a second for the descent of the hand.
                              I made a stop-motion video by adjusting the two actuators point by point according to the following diagram:
                              Fig.02 As an attachment 1-2-345et
                            I would like to replace the slider by time functions, point by point (FIG. 2) or FFT.
                            The displacement coordinates of the servomotors are shown in the table in figure 02.
                            You will find the simulation with the <FOREARM> (avant bras ) and <HAND> (main ) slider in my drive and an example video. I chose the refrain of Bob Dylan's "blowin in the wind".
                            Here is the link :
                            https://drive.google.com/open?id=0B00m7nJr8D_qTnRXX3AyeWVyZmc
                            The video tutorial shows the synchronized movement with a rhythmic tablature made with Guitar Pro MIDI (*.gpx, *.mid ). There is no human, just my voice 😉.
                              I thank you for your attention and information you can communicate to me to help me realize my project.
                              Best regards
                            jean-luc alias luckyvac... lucky guitaR
                            • T
                              TheSniper
                              Anton Awesome Plugin Thanks for the hard work!
                              I add And not to complain but hopefully to help.
                              Platform: Sketchup 2017 on Mac 64 bit
                              Known issues: 1 setting dont get saved in multiple areas for instance in the Joint and Piston Settings: Max and Min wont save always defaults back to -393.7007874, as well as the controller line resets back to default values. Controller name wont transfer over either. In the Servo panel: cannot save custom servo names, Plus Servo Max and MIn wont save either. Just some examples. Hope it helps. -S
                                SynSuka3D
                                Hello
                                Problem of direction axes
                                Xbox Controller
                                Joystick 🙂 righty) is X-XAXIS position on right stick.???
                                Joystick 🙂 rightx) is axes button LT.????
                                No axes Y-XAXIS right stick.???
                                please.
                                • luckyvacL
                                  luckyvac
                                  Great thanks Anton, I wait peacefully while working on other rhythm guitar. 😄
                                  • luckyvacL
                                    luckyvac
                                    Hello, I would like to know how to increase the damping of the servo motor. Thank you 😄
                                      Anton_S
                                      Hi, Luckyvac,
                                      Which of the joints are you referring to, a servo or a motor?
                                      To increase the damping of a motor joint, simply select the desired motor joint, open MSPhysics UI, and increase the Damp parameter.
                                      To increase the damping of a servo joint, that is decrease its angular rate, select the desired servo joint, open MSPhysics UI, and decrease the Angular Rate parameter.
                                      Hope this helps,
                                      Anton
                                        Anton_S
                                        @luckyvac My appologies for not responding any sooner. I am a bit busy. In short, it's possible to have the servo angle correspond to the table values at time t. The table with angles and times must be converted to a Ruby Hash and then the rest is easy. I will examine your model in depth soon and we'll see what can be done to get the guitar stringing.
                                        @TheSniper Apparently there were a few reports about the dialog options not working properly on Mac OS X and that's not good. I will check it out soon.
                                        @SynSuka3D The joystick function accepts four symbols and each of them correspond to an axis on one of the joysticks:
                                        joystick(:leftx) returns X position on left stick.
                                        joystick(:lefty) returns Y position on left stick.
                                        joystick(:rightx) returns X position on right stick.
                                        joystick(:righty) returns Y position on right stick.
                                        The position ranges from -1.0 to 1.0.
                                        Here is the documentation link to the function: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/CommonContext#joystick-instance_method
                                        I suggest you explore the MSPhysics scripting documentation for specs and other functions that might be useful, such as joybutton(button).
                                        • luckyvacL
                                          luckyvac
                                          Hi Anton,
                                          Thank you for your advice it works ... but ... I send you the left hand of the guitarist named "Pierrot".
                                          I feel that the system comes into resonance when I connect several servo motors to each other.
                                          What do you think ? How to decrease the resonance ?
                                          Merci 😉
                                          have a nice week end. 👍
                                          Lucky guitaR
                                          main gauche MOV 03.skp
                                            Anton_S
                                            @SynSuka3D Interesting, I will fix this.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 46
                                            • 47
                                            • 28 / 47
