    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.0m Views 79 Watching
      Kito Raupp inspiration! πŸ˜‰
      • dereiD Offline
        derei
        A friend of mine just finished a reprap 3d printer and I thought to "celebrate" his achievement, by modeling a boat for him to print...
        • N Offline
          nlipovac
          [attachment=0:10i72gyl]<!-- ia0 -->Mowiti.jpg<!-- ia0 -->[/attachment:10i72gyl]
          It looks great!
          Hove did you do lettering?
          • aarondietzenA Offline
            aarondietzen
            Been a while since I posted anything here!
            Quick model I did earlier this week:
            "Imagination is more important than knowledge..."
            - Albert Einstein
            • dereiD Offline
              derei
              @nlipovac said:
              It looks great!
              I had a jpg image of my friend's logo, I imported it in Inkscape -> Trace Bitmap -> Save as DXF
              Imported in SketchUp + Thomthom Edge Tools -> Simplify curves (I had to weld all curves before), then
              Sandbox Drape + Fredo JPP
              *sandbox drape works only on blue axis, so I had to turn the boat on a side for that operation.
              ** i did the letters on the plain mesh, after using subD and converting it into plain mesh.
              • HornOxxH Offline
                HornOxx
                @derei said:
                ...I had a jpg image of my friend's logo, I imported it in Inkscape -> Trace Bitmap -> Save as DXF.
                Sandbox Drape + Fredo JPP.
                πŸ‘ Great - I love this little boat
                Do I get you right - the 3D text remains a geometry of itΒ΄s own?
                never trust a skinny cook
                • HornOxxH Offline
                  HornOxx
                  @aarondietzen said:
                  ...Quick model I did earlier this week...
                  πŸ‘ Wonderful - what a nice SubD model idea this example is again !
                  To reduce the geometry to what is just necessary always looks so simple but is the challenge πŸ˜‰
                  (would you mind to share this proxy here?)
                  • HornOxxH Offline
                    HornOxx
                    A Little Christmas Contribution and best Wishes
                    Candle Proxy.skp
                    • N Offline
                      nlipovac
                      @derei said:
                      @nlipovac said:
                      It looks great!
                      So is this logo quad also? Is he part of boat geometry or is it by it self another quad model.
                      If it is part of boat geometry how did you do it and maintain quads on boat?
                      I do expect pic of printed boat!? πŸ˜„
                        aarondietzen
                        But of course!
                        I even did a video of the model, for anyone interested...
                        - Albert Einstein
                        • dereiD Offline
                          derei
                          No. The 3D text is "draped" and then extruded from the boat's hull mesh. But that could be done only after the boat was subdivided using subD. After the subdivision, if you right-click on it, you will se a context subD menu that converts the parametric mesh into a plain mesh... that can't be turned back to low poly anymore. Is just a simple standard triangle mesh surface.
                          So, on this surface I used the Drape Tool from Sandbox to imprint the text outline. Then I used Fredo's PushPull over that outline.
                          • HornOxxH Offline
                            HornOxx
                            @aarondietzen said:
                            ...But of course!...
                            Thanks a lot!!
                            This is a great (and hopefully timelapsed πŸ˜„ ) Making Of video !!!
                            Best
                              aarondietzen
                              @hornoxx said:
                              Thanks a lot!!
                              Best
                              Yeah... even though it was a quick model (25 minutes) I did speed it up for the video... but I did leave it all in there! Even several "oops" moments!
                              - Albert Einstein
                              • dereiD Offline
                                derei
                                I definitely expect that too... he promised that he would do that on Monday... due to the reason that he has to fine-tune the printer. Right now he's printing with 0.3mm nozzle and had some speed problems. But he promised to go with 0.1 (which my model deserves).
                                • HornOxxH Offline
                                  HornOxx
                                  @derei said:
                                  ...But he promised to go with 0.1 (which my model deserves)...
                                  πŸ˜„ πŸ˜‰ πŸ˜„ and not only that - I expect floating capability even πŸ˜„
                                  • dereiD Offline
                                    derei
                                    Well, is plastic...and you know that 3D printing software makes that honeycomb structure inside... so I expect it will float... but I can't guarantee it won't be upside down πŸ’š I didn't do any buoyancy calculations, not even to find its center of gravity... (tig has a plugin for that, right?)
                                    • HornOxxH Offline
                                      HornOxx
                                      @derei said:
                                      ... but I can't guarantee it won't be upside down πŸ’š...
                                      πŸ’š πŸ˜‰
                                        pilou, that image doesn't load right to me...
                                          @Aaron! πŸ‘
                                          http://lewebjournal.fr/wp-content/uploads/2013/07/images1.jpg
                                          • BoxB Offline
                                            I haven't had time for ages just to have a play, so this was a relaxing bit of fun.
                                            One interesting thing that came out of it that I was half aware of, you can twist your quads so they are kinda inside out and SUbD will still make beautiful shapes from them.
                                            http://i.imgur.com/ZHe60rD.gif
                                            SUbDFun.skp
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 82
                                            • 83
                                            • 25 / 83
